Why Is My Electric Bill So High: Causes, Costs, and How to Save
If you’ve opened your latest electricity bill and felt your stomach drop, you’re not alone. Many households across the UK are asking the same question: why is my electric bill so high? From rising energy prices to how and when you use your appliances, there are plenty of factors that can quietly push your costs up.
In this guide, we’ll break down the average energy use for UK homes, explain the common causes of high bills, and share practical ways to reduce them, so you can feel more in control of what you’re paying.
Average Energy Usage Per Household in the UK
When you’re trying to figure out why is my power bill so high, the first thing to check is whether you’re actually using more electricity than a typical UK home. Knowing what’s “normal” helps you see if the problem is high usage, high prices, or both.
The UK energy regulator, Ofgem, publishes something called Typical Domestic Consumption Values (TDCVs). These are benchmarks for annual electricity use based on home size and meter type. They’re reviewed every few years to reflect real trends in household energy consumption, so they stay relevant as our habits and technology change.
Here’s how Ofgem defines the most recent “Low”, “Medium” and “High” electricity use:
Energy Use Category
Home Size
Residents
Typical annual use (single-rate)
Typical annual use (multi-rate, e.g. Economy 7)
Low
Flat or 1-bedroom home
1–2 people
1,800 kWh
2,200 kWh
Medium
2–3-bedroom house
2–3 people
2,700 kWh
3,900 kWh
High
4+ bedroom home
4–5 people
4,100 kWh
6,700 kWh
Source: Ofgem’s Typical Domestic Consumption Values (TDCV) 2023.
If your kWh usage over the past 12 months is close to the figure for your home size, but your bill still feels high, it’s likely the price you’re paying per unit that’s pushing it up. If your usage is well above these benchmarks, it’s a sign there may be opportunities to cut back on consumption.
Why Is My Energy Bill So High in the UK?
If you’ve been wondering “Why is my electricity bill so high?” you’re not alone. The average electricity bill in the UK has gone up, and many households are seeing higher bills even when their habits haven’t changed much. Here are the most common reasons:
Electricity prices have gone up
One of the biggest reasons your power bill is climbing is simply down to price increases. Ofgem sets a price cap that limits how much suppliers can charge per unit of electricity and for the daily standing charge. This cap is reviewed every three months, and when it rises, so do your bills.
For example, from 1 April 2025, the cap increased by 6.4%, pushing the average rate for Direct Debit customers from 24.86p per kWh (Jan–Mar) to 27.03p per kWh (Apr–Jun). That means every time you boil the kettle, run the dishwasher or use the oven, it now costs more than it did just a few months ago.
According to Ofgem, the main cause of the rise was a spike in wholesale electricity costs, which suppliers pass on to consumers. So, if you’re asking, “Why is my electric bill so high in the UK lately?”, this is likely part of the answer, even if your actual usage hasn’t changed much.
You may be using more electricity than you think
Some appliances use a surprising amount of electricity, especially if they heat water or air.
  • Tumble dryers, electric ovens, kettles, washing machines, immersion water heaters, and electric boilers are among the most energy-hungry devices in most homes.
  • Fridges and freezers, though they use less per hour, run 24/7 and can add up over time.
  • Older appliances tend to be less efficient, and overuse of things like electric heaters or heated towel rails can push up your bill.
If your electricity bill has jumped recently, but your habits haven’t, it’s worth reviewing your high-use appliances, especially how often you’re using them and at what settings.
Standby and always-on devices add up
It’s easy to forget how much electricity devices use while they’re just sitting there. TVs, game consoles, routers, smart speakers and chargers all draw power on standby. It’s one of the most common reasons why your electric bill is so high without you even realising.
Colder days can push bills higher
Winter months often bring higher electricity bills. Shorter days mean more lights on, and colder weather often leads to increased use of heaters, kettles, tumble dryers, and hot showers.
If your home relies on electricity for heating rather than gas, your bills will naturally be higher. Poor insulation and draughty windows can make matters worse by forcing your heating system to work harder.
Estimated bills or incorrect readings
Sometimes the problem isn’t your usage; it’s the bill itself.
  • If you haven’t submitted a recent meter reading, your supplier might be estimating your usage based on past data, which can be wildly off.
  • Always check whether your bill is actual or estimated. If it’s estimated and looks too high, submit a reading to correct it.
  • If you have a smart meter and suspect it’s not working properly, get in touch with your supplier.
In fact, many households asking, “Why is electric bill so high suddenly?” discover that the cause is often simple billing errors, easy to fix once they’re found.
What to Do If You Can’t Afford Energy Bills?
If you’re struggling to pay your energy bills, you’re not alone, and the most important thing is to act early. The good news is, there’s help available, and energy suppliers are required by Ofgem to support you.
1. Talk to your energy supplier first
Get in touch with your supplier as soon as possible. They’re legally required to help you find a solution, whether that’s setting up an affordable payment plan, reviewing an existing one, or offering a short payment break.
If you’re on a prepayment meter, ask about emergency credit or additional support credit, especially if you’re in a vulnerable situation. These options are there to help keep your supply on when money is tight.
2. See what discounts and payments you qualify for
You might be eligible for extra help through government-backed schemes, especially during the colder months:
  • Household Support Fund (HSF): A government fund distributed by local councils to help with essentials such as energy and water bills. Support can come as cash, supermarket or energy vouchers, or direct credits. Each council runs the scheme differently, so check your local authority's website for eligibility and application details.
  • Hardship Funds and Energy Grants: Many suppliers have their own support schemes. You can also apply to the British Gas Energy Trust, even if you’re not a British Gas customer, for help paying off arrears.
  • Warm Home Discount: A £150 discount applied to your electricity bill each winter (usually automatically if you qualify).
  • Winter Fuel Payment: Between £100 and £300 if you’re over the State Pension age. In Scotland, it’s handled by Social Security Scotland.
  • Cold Weather Payment: In England and Wales, £25 for each 7-day cold snap between November and March if you’re on qualifying benefits. In Scotland, this is replaced with the Winter Heating Payment.
3. Get independent advice if you’re in debt
If you’re falling behind on payments or worried about growing debt, speak to Citizens Advice. They can help you understand your options, check what support you’re entitled to, and even contact your supplier on your behalf. They can also help you apply for grants and discounts.
You might also be eligible for Breathing Space (Debt Respite Scheme) in England and Wales. This gives you 60 days of legal protection from enforcement action while you work on a debt solution.
4. Challenge Billing Errors or Meter Issues
If your bill seems too high or your meter doesn’t look right:
  • Contact your supplier with a recent reading or report the issue.
  • If they don’t resolve it within 8 weeks, or send a ‘deadlock’ letter, escalate it to the Energy Ombudsman, a free and independent service that can investigate and resolve disputes.
Most Effective Ways to Reduce Your Bill
Now, to save on electricity bill is about tackling two things: how much energy you use (kWh) and the price you pay for each unit. If you focus on the biggest wins first, you’ll see results faster.
Tackle the biggest electricity users
Appliances that heat water or air use the most electricity.
  • Laundry: Wash at 30°C when you can, run full loads, and air-dry clothes instead of using the tumble dryer. Clean the lint filter every time; it helps the dryer run more efficiently.
  • Dishwasher: Use eco cycles and skip the heated dry. Just open the door at the end and let your dishes air-dry.
  • Cooking: Keep preheating short, cook in batches, and use lids to speed up boiling. Microwaves, pressure cookers, and air fryers are generally more efficient than heating a whole oven for small meals.
  • Kettle & electric shower: Only heat the water you need and descale appliances regularly so they work efficiently.
Cut “always-on” and standby waste
Standby power, sometimes called “vampire” energy, can add up to a surprising amount over a month.
  • Turn devices off at the wall when they’re not in use (TVs, consoles, smart speakers, chargers).
  • Use smart plugs or timers to cut overnight power to things like set-top boxes or secondary monitors.
  • Replace any remaining halogen bulbs with LEDs — they use a fraction of the energy and last much longer.
Keep fridges and freezers running efficiently
Fridges and freezers run 24/7, so even small changes can help.
  • Set the fridges to around 3–5°C and freezers to −18°C.
  • Make sure they have space for ventilation and aren’t pushed tight against the wall.
  • Defrost regularly if ice builds up.
  • Check the door seals. If a sheet of paper slides out easily when the door’s shut, the seal might need replacing.
Choose a tariff that fits your lifestyle
If you can shift some usage to off-peak hours, a time-of-use tariff like Economy 7 could save you money.
  • Run washing machines, dishwashers, EV charging, or hot water heating during the cheaper overnight window.
  • If you can’t shift much usage, a single-rate tariff is usually better value.
  • Prepaid electricity plans are often cheaper than Direct Debit, so it’s worth checking if a switch could lower your rates.
Monitor your electricity use in real time
A smart meter and its in-home display can be eye-opening.
  • Monitor home electricity usage in real time as you turn appliances on and off, and you’ll quickly see which ones are driving your bill.
  • Try a “10-minute appliance check”: note your base usage, then switch devices on one at a time to see the jump.
  • Check your supplier’s app for half-hourly graphs. High overnight usage might mean something’s running when it doesn’t need to.
  • For even more detail, plug individual devices (like heaters or tumble dryers) into a plug-in energy monitor to see exactly how many kWh they use over time.
Make heating and hot water work harder for you
If you use electric heating or water heating:
  • Storage heaters: Charge during off-peak hours and keep the output low during the day so heat lasts into the evening.
  • Panel or oil-filled radiators: Use thermostats and timers to only heat the rooms you’re in.
  • Hot-water cylinders: Fit an insulation jacket if it doesn’t already have one and heat water during cheaper tariff periods.
Upgrade when the time is right
When appliances fail, choose replacements with better efficiency ratings. Look for A- or B-rated appliances with the rescaled UK energy label (A–G) and compare annual kWh usage before buying. Even mid-range models can save a lot over time.
Consider investing in solar panels and storage batteries
If you own your home and have a suitable space, whether that’s a sunny roof, a balcony, or a garden frame, solar panels can help you rely less on the grid and save on peak-time costs. Pairing panels with a battery means you can store daytime generation to use in the evening or even charge the battery overnight at cheaper rates to use later.
If you want a beginner-friendly way to do this without a complex install, the EcoFlow STREAM Ultra X is worth a look. It’s an all-in-one unit with solar battery storage and a built-in microinverter, so it can take power straight from panels and deliver it to your home without extra hardware.
It features a 3.84 kWh LFP battery with a storage capacity expandable to 23 kWh, easily covering evening peak electricity demand. Its 4 MPPTs can make the most of available sunlight even in mixed light conditions. You can mount EcoFlow’s high-efficiency solar panels on balconies, walls, rooftops, or ground frames, making it ideal for homes where traditional rooftop arrays cannot be installed.
The Ultra X can run household appliances directly, export surplus to the grid, and even handle heavy loads up to 2,300W by drawing extra from the grid when needed. Through the EcoFlow app, you can set charging schedules based on tariffs and use solar forecasts to automate when you charge or discharge, so you’re always getting the best value from the system.
The EcoFlow STREAM Ultra X is an all-in-one home solar battery solution, combining a 3.84 kWh LFP battery with a built-in microinverter so it can take power straight from up to 2,000W of solar panels and feed it into your home.
High energy costs can be stressful, but understanding the reasons behind them puts you back in control. If you’ve been asking “why is my electric bill so high in the UK?”, the answer is often a mix of rising unit prices, how and when you use electricity, and the appliances in your home. By knowing your typical usage, spotting waste, and taking advantage of available support, you can start cutting costs straight away. Even small, consistent changes add up, helping you keep your bills manageable now and in the future.
Why is my electricity usage suddenly so high?
A sudden spike in electricity use often has a straightforward cause. First, check whether your bill is based on estimated readings or if your smart meter isn’t sending updates. Both can cause overestimates when your next actual reading comes in.
Think about any recent changes at home, such as extra guests, new or faulty appliances (tumble dryers and immersion heaters are big culprits), or a longer billing period. It’s also worth noting that the price you pay per kWh can go up if Ofgem’s energy price cap changes, your fixed tariff ends, or your supplier adjusts rates.
If you can’t find a clear reason, compare the MPAN on your bill with your meter and ask your supplier to investigate, as a meter fault is possible.
What is the average electricity bill per month in the UK?
There’s no single figure for everyone, but Ofgem’s “typical use” gives a good benchmark. For electricity, the average UK household, defined as around 2–3 people in a home with gas heating, moderate appliance use, and about 2,700 kWh of electricity a year, pays roughly £880 annually, or £74 a month, based on the current (July–September 2025) price cap of 25.73p per kWh plus a ~51p daily standing charge. A typical dual-fuel home pays about £1,720 per year, or £143 a month. Your actual bill may be higher or lower depending on your home’s size, insulation, heating system, and lifestyle.
What runs your electric bill up the most?
Certain appliances and habits have an outsized effect on electricity costs. “Wet” appliances, like washing machines, dishwashers and especially tumble dryers, are big consumers, accounting for around 14% of a typical bill due to the high energy needed to heat water or air.
Fridges and freezers are next at about 13%, as they run constantly. Electronics like TVs, laptops, and gaming consoles contribute roughly 6%, while lighting makes up about 5%. Cooking using ovens, hobs, kettles, and microwaves adds about 4%. If you have electric heating or immersion hot water systems, these can dominate your usage.
What should I do if I think my bill is wrong?
If you suspect your bill isn’t right, start by checking whether the reading is estimated. If it is, take and submit accurate meter readings, ideally with photos for proof. Compare your bill’s meter details—MPAN and serial number—with those on your actual meter to ensure you’re being billed for the right supply. If the figures still don’t make sense, contact your supplier with your evidence and keep a clear record of all communications. They are required to investigate and respond. If you can’t reach an agreement, or eight weeks pass without resolution, you can escalate the complaint to the Energy Ombudsman, who can require corrections, refunds, or compensation.
Saving Bills
