Motorhomes & Road Trips
Enabling an energy-self-sufficient lifestyle on the road.
Sign up now to enjoy a 5% discount, over $1,000 in coupons, and the latest updates.
* I agree to EcoFlow's Privacy Policy and Terms of Service.
Power Stations
Use portable power stations to charge appliances in your motorhome, tent or even a road trip.
1-Day Power for Road Trips or Car Camping
Several Days Running Motorhome Appliances
Portable Solar Panels
Lightweight folding solar panels perfect for battery charging on a motorhome adventure or road trip.
EcoFlow 400W Lightweight Portable Solar Panel
  • Up to 25% solar conversion efficiency rate
  • Lightweight & Portable
  • 30°/45°/60° 3-Angle adjustable support stand
combination with
DELTA Pro 3/DELTA 2 Max/DELTA 3 Max Plus
EcoFlow 220W Lightweight Portable Solar Panel
  • Up to 25% conversion efficiency rate with a bifacial design
  • Integrated solar angle guide
  • Lightweight and portable
combination with
DELTA 2 Max/DELTA 3 Max Plus/DELTA 3 Series/DELTA 2/DELTA 3 Classic
EcoFlow 160W Lightweight Portable Solar Panel
combination with
EcoFlow 100W Flexible Solar Panel
  • Weighs only 5.1lbs, making it extremely lightweight
  • 258° flexibility, making it easy to fit to any surface
  • An IP68 waterproof rating for added durability
EcoFlow Alternator Charger
500W Alternator Charger
  • 2.1 hours to charge 1kWh
  • Compatible with most third-party portable power stations
800W Alternator Charger
  • Top up 1kWh in only 1.3 hours
  • Triple the value with a 3-in-1 functional design
500W Alternator Charger + DELTA 3 PLUS
  • 1-5kWh Capacity | 1800W Output
Alternator Charger 500W + WAVE 3 + WAVE 3 Add-on Battery
  • 1024Wh LFP Add-On Battery
  • 6100 BTU cooling power & 6800 BTU heating power
Motorhome Power Systems
Don't want to build your motorhome power system from scratch? Consider an integrated energy solution and experience comfort and power self-sufficiency on any road trip you take.
EcoFlow Power Kits
Suitable for
Days away
  • 2kWh
    2kWh
    Semi-Integrated Motorhomes, Alcove Motorhomes, Caravans, Compact Campers
    Up to 3 Days
  • 5kWh
    5kWh
    Up to 5 Days
  • 10kWh
    10kWh
    Integrated Motorhomes, Fifth Wheel
    Up to 10 Days
  • Phone 11Wh
  • Water pump 15W
  • Mobile network 30W
  • Laptop 50W
  • Car fridge 60W
  • Mixer 500W
  • Oven 800W
  • Air conditioner 1000W
  • Coffee maker 1000W
  • Microwave 1300W
EcoFlow Power Kits
2kWh
2kWh
5kWh
5kWh
10kWh
10kWh
Suitable for
Days away
Up to 3 Days
Up to 5 Days
Up to 10 Days
Hear From Our Users
Cut DOWN Your BILLS With The NEW EcoFlow RIVER 2 Pro
EcoFlow DELTA 2: The HONEST Portable Solar Power Station Review!
The ONLY Eco Flow Delta 2 Video You Need To Watch
Eco Flow WAVE 2 - Portable Heating AND Cooling in one device!
Read More From EcoFlow
5 Best Solar Panels for Your Caravan in 2023
Learn More
4 Best Solar Generators for Your Motorhome in 2023 Reviewed
Learn More
What Size Generator Do I Need to Run My Camper?
Learn More
4 Best Power Options For Powering Your Motorhome
Learn More
4 Best Portable Solar Panels For Motorhomes in 2023 Reviewed
Learn More
What Size Inverter Do I Need for My Motorhome?
Learn More
The cost to install solar panels on a motorhome varies widely, typically ranging from $600 to $3,000. This depends on factors like panel quality, system size, and additional components (like batteries). Professional installation can add to the cost, though many opt for DIY installation to save.
To install solar panels on a motorhome, select suitable panels, securely mount them on the roof, and connect to a charge controller. Link the controller to the motorhome's battery system and wire an inverter for power conversion. Ensure all connections are safe and weatherproof for reliable use. Alternatively, use portable solar panels with a plug-and-play portable power station for a flexible power supply.
For a road trip, pack essentials like snacks, water, a first-aid kit, maps/GPS, comfortable clothing, and a portable power source for electrical devices, such as a car fridge. Also, consider weather-appropriate gear and entertainment options like music or audiobooks.
For motorhomes, portable monocrystalline solar panels are often the best choice. They offer high efficiency in a compact, easy-to-move format, ideal for the variable conditions of travel. Their flexibility in setup and tear-down makes them convenient for motorhome owners needing reliable power without permanent installation.
The combination of an EcoFlow DELTA Pro power station and 220W Bifacial Solar Panel forms the ultimate solar kit for vanlife. EcoFlow DELTA Pro's versatile power storage capabilities and the bifacial panel's energy efficiency make it perfect for reliable, eco-friendly energy generation and storage. It's a powerhouse duo for motorhome adventures.
For car camping, choose a spacious tent, bring comfortable bedding, pack sufficient food and water, and have a portable power source for charging devices. Also, include a first-aid kit, cooking gear, and appropriate clothing. Plan your route and campsites for a smooth experience.
