How Much Electricity Does a Dehumidifier Use in the UK?
Dehumidifiers are now more popular in UK households, especially in regions where condensation, dampness and mould are a problem or poor ventilation is an issue. These appliances can help to dehumidify the air, which can lead to better indoor comfort, less damage to property, and a healthier living space.
But with energy costs still a major issue for many households, homeowners often ask how much electricity does a dehumidifier use and and if using it often will have a substantial impact on their electric bills.
Many homeowners are also learning to manage electricity use throughout the house as they become more aware of the cost of running appliances. Solutions such as home energy storage systems can support greater energy flexibility while helping households make better use of available electricity.
Understanding Dehumidifier Electricity Usage
To get a proper estimation of the running costs of the dehumidifier, it is crucial to understand how the dehumidifier consumes electricity and what factors affect the overall electricity consumption of the dehumidifier.
While it is true that dehumidifiers tend to use less energy than other appliances like an electric heater or a tumble dryer, there are still significant differences among dehumidifiers.
Electricity Consumption of Modern Dehumidifiers
The electricity consumption of most modern dehumidifiers ranges from 150W to 700W, depending on the dehumidifier's type, capacity, and operating technology.
Smaller domestic units that are used in bedrooms, bathrooms, or home offices tend to use less electricity, and larger units, designed to control moisture in the whole house can use higher amounts of electricity.
The quantity of electricity consumed by an appliance is, in general, not only related to the size of the appliance (in watts) but also on the number of hours it is in use per day. A more efficient dehumidifier used for a short time can use less energy than a less efficient dehumidifier used for a longer time.
Factors Affecting Dehumidifier Power Usage
Several variables influence how much electric does a dehumidifier use in everyday situations.
Common factors include:
  • Room size and moisture levels
  • Indoor temperature
  • Appliance capacity
  • Humidity settings
  • Frequency of use
  • Ventilation conditions
For instance, a dehumidifier in a room that is very humid must run for a much longer period of time than a dehumidifier for a room that is just used for preventative moisture control and is well-ventilated.
Actual electricity consumption can vary widely from one home to another, due to the individual differences in each home.
Appliance Wattage and Operating Hours
There are two main factors used to calculate electricity consumption:
  1. Appliance wattage
  2. Number of operating hours
An appliance's wattage is a good indicator of its electricity use - the higher the wattage, the more electricity the appliance requires per hour and the longer it is on, the more electricity it requires.
The table below illustrates how operating time can influence electricity usage for a typical 300W dehumidifier.
Daily Usage
Approximate Daily Consumption
2 Hours
0.6 kWh
4 Hours
1.2 kWh
8 Hours
2.4 kWh
12 Hours
3.6 kWh
24 Hours
7.2 kWh
These are only examples of figures, but they show how the length of time it is used can be as important as the power rating on the appliance when calculating running costs.
Estimating Dehumidifier Running Costs
While electricity usage is helpful, many homeowners are more interested in the cost of operating a dehumidifier.
Running costs are estimated by combining electricity usage with electricity price. Tariffs can vary from supplier to supplier, but the calculation method is similar.
How Much Electricity Does a Dehumidifier Use Per Hour?
For homeowners looking how much electricity does a dehumidifier use per hour, this largely relies on the wattage of the dehumidifier.
A 300W dehumidifier operating for one hour consumes approximately:
0.3 kWh of electricity
A larger 500W model would consume approximately:
0.5 kWh of electricity per hour
While these may seem like small amounts of money, the total cost can pile up if the appliance runs for several hours a day.
How Much Electricity Does a Dehumidifier Use Per Day?
The answer to the question of how much does a dehumidifier use per day is largely dependent on how many hours the dehumidifier is in use.
For example:
  • A 300W dehumidifier running for 4 hours uses approximately 1.2 kWh
  • The same appliance running for 8 hours uses approximately 2.4 kWh
  • Continuous operation increases consumption further
If many households use a dehumidifier only when humidity is high, it is possible to use it with less electricity and still get the job done well.
Monthly Electricity Costs of Regular Dehumidifier Use
When determining a dehumidifier's monthly electricity consumption, the small amounts used each day can add up.
For instance, if a dehumidifier were to use 2 kWh per day, it would use about:
60 kWh per month
While actual monthly expenses would vary with electricity rates and usage, this example illustrates the potential savings from efficient operation and proper appliance sizing over time.
Factors Influencing Household Operating Costs
The expenses for operating a dehumidifier depend on several factors.
These include:
  • Electricity tariff rates
  • Daily operating hours
  • Humidity levels within the property
  • Appliance efficiency
  • Seasonal weather conditions
Knowing about these factors can help homeowners decide how to use their appliances and maintain a balance between comfort and cost.
Choosing an Energy-Efficient Dehumidifier
Knowing how much electric does a dehumidifier use matters, but purchasing the right model can make a difference in the long-term cost of operating the dehumidifier. All dehumidifiers do not work the same, and choosing a dehumidifier that is suitable for the property conditions can also increase the efficiency and performance.
If it is too large, it will waste energy and if it is too small, it may have to run all the time to maintain the humidity level.
Compressor Versus Desiccant Dehumidifiers
Most domestic dehumidifiers fall into one of two categories: compressor dehumidifiers and desiccant dehumidifiers.
Feature
Compressor Dehumidifier
Best Operating Temperature
Warmer rooms
Cooler rooms
Typical Electricity Usage
Generally lower
Generally higher
Noise Level
Moderate
Often quieter
Moisture Removal in Cold Conditions
Less effective
More effective
Typical UK Usage
Living rooms, bedrooms
Garages, conservatories
In heated homes, the compressor models tend to be more energy-efficient, whereas in colder climates, desiccant units can work better. It is important to understand the area you want to use it in so that you can select the appliance that will best fit your home.
Energy Efficiency Ratings and Performance
When comparing models, it is important to take into account energy efficiency in addition to moisture extraction capacity.
A good dehumidifier can remove a lot of moisture from the air using relatively little electricity. Many new units also boast other features, including:
  • Automatic humidity sensors
  • Programmable timers
  • Eco operating modes
  • Smart controls
These functions reduce the quantity of unnecessary working and can save electricity usage all year round.
Matching Dehumidifier Size to Room Requirements
A typical error is buying a dehumidifier that is too big or too small for the area.
Usually, smaller rooms can be treated with a lesser-capacity unit – larger properties or areas with more serious damp challenges may see the benefits of a more powerful system. Capacity can be matched to the room to ensure that the right amount of energy is being used and performance is optimised.
When homeowners ask how much power does a small dehumidifier require?, they are likely to discover that it consumes considerably less power than larger whole-house dehumidifiers, as it is designed for a smaller space.
Balancing Moisture Control and Electricity Consumption
The aim of a dehumidifier is not to dry out the air, but rather to create a comfortable and healthy indoor climate.
If there is no need for dehumidification, running a dehumidifier constantly is a waste of electricity. Many new appliances can set the moisture level, meaning they run only when required.
This equilibrium allows homeowners to enjoy a comfortable home without breaking the bank on utilities.
Managing Household Energy Consumption More Effectively
While dehumidifiers may not be the largest consumer on a home's electrical bill, they do serve as an example of the many appliances that help drive electricity demand.
While it is common for homeowners to look at the cost of each one of their appliances, they do not consider the overall effect of all the devices in the home. Understanding the broader context of electricity use can help uncover opportunities for electricity efficiency and savings.
Balancing Comfort and Electricity Costs
Many appliances are necessary for a comfortable climate inside and these use energy. Dehumidifiers, heaters, ventilators, and similar appliances contribute to healthy living. For many people, it is a matter of balancing comfort and cost of operation in the home. Even little changes in appliance setups, times and habits can save power without compromising comfort.
This approach is more and more important in the face of changing electricity costs and evolving household energy needs.
Reducing Unnecessary Appliance Energy Usage
There are a number of appliances that use more power than required because they are left on longer than needed or they are not functioning efficiently.
There are a number of easy ways to reduce energy waste, some of which include:
  • Using timers and programmable settings
  • Maintaining appliances properly
  • Operating equipment only when needed
  • Improving ventilation and insulation
  • Reviewing appliance efficiency ratings before purchase
These are simple habits that can help to decrease electricity use throughout the home.
Monitoring Electricity Consumption Throughout the Home
Knowing where electricity is being consumed is one of the best methods of improving efficiency.
Energy monitoring can help homeowners find:
  • High-energy appliances
  • Peak usage periods
  • Seasonal changes in electricity demand
  • Opportunities for efficiency improvements
Household energy efficiency data can help increase transparency of energy consumption, which in turn can inform decision-making and help identify areas for households to prioritise.
Building Energy-Efficient Household Habits
Often, it’s the little things that add up to big energy savings over the long run. Cumulative, small actions taken regularly will lead to a gradual decrease in electricity use and increase in effectiveness.
These include switching off appliances that are not needed, using energy efficient modes, keeping the humidity right and checking the energy consumption regularly.
A basic understanding of the energy needs of various appliances around the house, such as dehumidifiers, is a first step toward living more energy-efficiently.
Smarter Home Energy Management Solutions
Knowing how much electricity a dehumidifier uses is useful for calculating appliance running costs, but many homes are now looking at energy management as a whole.
Lowering the cost of powering one appliance is beneficial, but significant savings may be obtained by knowing how electricity is being utilized in the entire house. Effective energy management is becoming more critical as more homes are adopting other appliances and smart devices, home offices, electric vehicles, and renewable energy systems.
Instead of just considering the costs of the appliance, many homeowners are looking to reduce costs on a home-wide basis and maximize their use of existing electricity.
Energy Awareness as the Foundation of Efficient Living
The first step in an energy conservation program is to gather information on electricity use and how energy is used throughout the day.
A number of families are shocked to see how much a variety of relatively small appliances can add up to in terms of electrical load when used daily. Consumption habits are further influenced by dehumidifiers, heating systems, entertainment equipment, kitchen appliances, and home office devices.
By raising awareness, homeowners can make informed decisions about their appliance use, identify opportunities to reduce unnecessary consumption, and plan more effectively for future energy needs.
EcoFlow STREAM Ultra/Pro/Max Home Solar Battery for Managing Everyday Household Electricity Consumption
If you're a household seeking to make energy efficient improvements, the hurdle doesn't always lie with just your appliances, including your dehumidifier. The ultimate aim is to move towards a more flexible energy system that can meet the different demands of households throughout the day.
The EcoFlow STREAM Ultra/Pro/Max Home Solar Battery aims to empower homeowners to optimise the use of available electricity and renewable resources for their daily lives.
Expandable capacity from 3.84kWh to 23kWh, allowing the system to adapt as household energy requirements evolve. Supports up to 2000W solar input with 4 MPPTs, helping maximise solar energy generation throughout the day. Helps households make more effective use of self-generated renewable energy rather than relying solely on grid electricity. Supports smarter management of everyday appliance usage, including dehumidifiers, kitchen appliances, and home office equipment. Suitable for households seeking greater flexibility in balancing energy generation, storage, and consumption. Designed to support long-term energy efficiency strategies as household electricity demands change.
EcoFlow STREAM Ultra X Home Solar Battery for Homes with Greater Appliance Usage and Energy Needs
Some households may have more complex energy needs because of the size of the property, number of people living in the home, home offices, electric heating or increased day-to-day use of electrical appliances.
In such cases, energy management becomes more critical since several devices can consume energy simultaneously. The EcoFlow STREAM Ultra X Home Solar Battery caters to families who need more energy and have more complex usage patterns.
Up to 2300W AC output supports a wide range of household appliances and higher-demand electrical loads. Features a 15-year lifespan, supporting long-term reliability and household energy planning. Designed for households with increasing electricity consumption and evolving energy requirements. Helps improve flexibility when managing multiple appliances operating at different times throughout the day. Supports greater integration of renewable energy into everyday household electricity usage. Compatible with third-party devices using Tiber, Matter, and Shelly protocols for broader smart energy management opportunities.
Creating a More Energy-Efficient Household Strategy
Energy savings of any one appliance are not usually the only energy savings. Knowing how much electricity a dehumidifier uses per month can help control operating expenses but can also be done by taking a broader approach to energy usage in the home.
Energy awareness, energy-efficient appliances, sensible energy use, and flexible energy management solutions can all help households better adapt to fluctuations in electricity demand. As energy usage changes, many homeowners are seeing that more efficient energy management can yield benefits beyond a single piece of equipment.
Practical Ways to Reduce Dehumidifier Energy Costs
Dehumidifiers are a key element in keeping indoor environments healthy, but there are several straightforward changes that can lower operating expenses without affecting performance.
  1. Use Humidity Settings Effectively
Most modern dehumidifiers have humidity settings. If the setting is realistic, the appliance only works as needed and not all the time, which reduces humidity levels.
  1. Improve Ventilation Where Possible
Good ventilation can help reduce moisture accumulation, allowing the dehumidifier to operate less frequently and consume less electricity over time.
  1. Choose the Right Appliance Size
Having the right size dehumidifier for the room will enhance the efficiency and reduce energy waste.
  1. Maintain the Appliance Regularly
Cleaning filters and following manufacturer maintenance recommendations can help ensure that the dehumidifier continues operating efficiently throughout its lifespan.
  1. Monitor Electricity Usage Periodically
A periodic audit of appliance use can help householders realise how much electricity a dehumidifier uses in the UK, how appliances are being used, and what could be done to use them more efficiently.
Understanding how much electricity does a dehumidifier use can help homeowners make more informed decisions about managing both indoor comfort and energy costs. Most dehumidifiers today are fairly efficient, but the actual amount of electricity used depends upon the type of appliance, how long it is used, the amount of moisture, and household conditions.
The bright side is that there are ways to save on running expenses through smart use, correct appliance selection and increased energy awareness. A home battery system like the EcoFlow STREAM Ultra/Pro/Max Home Solar Battery can help you store and optimise your energy use, making it simpler to manage the energy needs of appliances such as dehumidifiers alongside other household devices.
Do Dehumidifiers Use More Electricity in Winter?
Not necessarily. How much electricity a dehumidifier consumes is determined by the operating time, the humidity level, the type of dehumidifier and the room conditions, but not as much the season.
In winter:
  • Homes may experience increased condensation due to reduced ventilation.
  • Dehumidifiers may run more frequently in some properties.
  • Desiccant models often perform better in cooler environments.
Therefore, some households might see increased use in the colder months, depending on the property's moisture content and how they heat their homes.
Does a Larger Dehumidifier Always Use More Electricity?
A larger dehumidifier doesn't necessarily mean higher electricity costs. In some cases, an appropriately sized appliance will run more efficiently because it extracts moisture more rapidly and for a shorter duration.
Homeowners who are comparing models should take into account:
  • Room size
  • Moisture levels
  • Appliance efficiency rating
The right size will affect running costs more than just choosing the cheapest option.
Are Energy-Efficient Dehumidifiers Worth the Investment?
Energy-efficient dehumidifiers can be a long-term investment for many families, helping save energy without sacrificing dehumidification capabilities.
Some features that can enhance efficiency include automatic humidity controls, programmable timers, eco modes, and advanced compressor technology. While some models may be more energy efficient and therefore higher in cost, their operating expenses can help to make up the expense over time.
This is particularly relevant for households concerned about how much electricity does a dehumidifier use per day UK conditions, where the appliance may operate regularly throughout the year.
What Factors Affect Dehumidifier Running Costs the Most?
Several factors influence how much electricity a dehumidifier uses per hour and overall running costs.
The most important include:
  • Appliance wattage
  • Room temperature and humidity
Knowing these factors helps homeowners to better estimate the costs and discover ways to become more efficient.
Home Solutions
