EcoFlow DELTA 2 Max
Save 5% on all DELTA 2 Max-related bundles with code "EFD2M5OFF"!
DELTA 2 Max Solar Generator
Ditch Gas, Go Solar
DELTA 2 Max
DELTA 2 Max Bag*
*Protects your DELTA 2 Max from water, dust and damage while on the move.
when you buy a DELTA 2 Max (and its bundles) before 12th June.
Buy Now >
No fumes. No noise. No maintenance.
2048Wh Capacity
Power for the entire family.
*Data based on a 120W referigerator.
Fully charge with a 2.6 hour drive
Charge while you drive with the industry's first alternator charger innovation. With 800W turbo alternator, top up your energy storage 8 times faster than using a traditional car 12V outlet. Recharge 1kWh in only 1.3 hours. It's not just a faster charger, it maintains your battery health and works as a jump starter.
1.3 hoursto charge 1kWh
Turbocharge Alternator 800W
Easy Installation
8× Faster
EcoFlow Alternator Charger: 1.3 hr
Traditional 12V Car Outlets: 10 hr+
*Comparison of time needed to fully charge 1kWh
3-in-1
Fast Charger, Maintainer, and Jump Starter
App Smart Control
Durable, Safe, Lightweight
10-year long-lasting LFP battery
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
Stay calm and powered on.
When the power's down, AC Always-On ensures a seamless transition from the grid to backup power and unwavering protection of your fridge and other mission-critical appliances.
Elevated battery lifespan and safety.
By tuning the charging speed to suit various charging environments, it's safe to use, preventing overloading and prolonging its lifespan.
You might also like
View more
