The "Total" Solar Eclipse of August 2026: Chasing Totality from Canada
- What is a Total Solar Eclipse?
- Where to See the 2026 Eclipse in Canada
- Why “Totality” Matters
- Planning a Trip to View the Eclipse: What to Consider
- What to Bring for Eclipse Viewing
- Powering Your Setup During Your Outdoor Solar Eclipse Viewing
- Frequently Asked Questions
- Proper Planning Makes Eclipse Viewing Safer and More Memorable
The next total solar eclipse is set to occur on August 12, 2026. It will primarily be visible across the Arctic, Greenland, Iceland, and Spain. While Canadians won't see totality from within the country, much of eastern Canada will experience a partial eclipse.
However, travel is the only way for committed chasers to see totality. Whether you’re watching from home or travelling for totality, a bit of planning goes a long way.
Here's what you need to know.
A total solar eclipse occurs when the moon passes between the Earth and the sun, completely blocking the sunlight. It creates a brief period of daytime darkness along the narrow path of totality.
Anyone outside the path will see a partial eclipse where the sun is partially covered, but for those within the path of totality, it reveals the sun's corona, an ethereal outer layer of the sun’s atmosphere normally invisible to the human eye.
Event duration varies each time and by location, with the next one expected to offer just over 2 minutes at maximum duration.
Canada will only experience a partial eclipse.
So, for the best Canadian viewing, head to the Atlantic provinces and northern regions such as St. John's, Newfoundland, where you'll see the greatest coverage, with about 53% of the sun obscured.
In comparison, Toronto will see a modest 16% of coverage.
Those in western Canada will have minimal visibility.
The totality experience is fundamentally different from a partial eclipse. During totality, the sky darkens dramatically, revealing the sun’s corona and a 360º sunset glow.
However, even a 99.99% partial eclipse will still only feel like slightly dim daylight. For those who get to experience totality, it often triggers a unique emotional response that many describe as life-changing.
If experiencing totality is a priority for you, it may be worth considering travelling to see it for yourself. Iceland and Spain are two of the best places to travel for totality for the August 2026 event.
If you want to chase the eclipse and experience totality for yourself, this is what you need to think about:
The path of totality will cross Greenland, Iceland, and northern Spain.
Spain has the best weather odds for visibility. Northern Spain will see totality near sunset, with the sun low on the horizon.
Iceland provides longer totality (over 2 minutes), but the climate in August is often cloudy.
If you want to travel, book your accommodations as early as possible, as there will be a surge in demand.
Ensure your home is prepared before you leave for an extended trip. A reliable backup home power solution can help keep essential systems running in case of an outage while you’re away.
Have a contingency plan. Cloud coverage can ruin visibility even in ideal locations.
ISO Certified Eclipse Glasses are required for all partial or full eclipses. They protect your eyes from solar radiation by filtering out almost all visible light and 100% of UV and IR radiation, allowing you to directly view the sun safely.
For more detailed solar observation, bring binoculars or a telescope with proper solar filters.
A camera with a telephoto lens and solar filter will allow you to capture stunning shots.
Bring comfortable seating, as the viewing can last up to 3 hours from start to finish.
Layered weather-appropriate clothing accommodates variable conditions.
An outdoor portable power station to keep your phone, camera, and viewing equipment powered throughout the event.
If you're bringing accessories like cameras, telescopes, and tracking mounts, reliable power is a must, especially for a 2–3-hour event. A portable power station (PPS) helps ensure your equipment stays running without interruption.
A unit like the EcoFlow DELTA 3 Max Plus provides plenty pg capacity to support cameras, phones, and accessories throughout the event, so you don’t miss key moments. You can also take advantage of solar energy — pair your PPS with portable solar panels to top up your battery at remote viewing locations.
It can also power small comforts, like heated clothing in cooler regions, or keep your phone charged for weather updates and communication.
When Is the 2026 Solar Eclipse?
August 12, 2026, is the next total solar eclipse. It falls on Wednesday. The timing will vary by location, with eastern Canada areas like Newfoundland experiencing a partial eclipse from the late morning through the early afternoon.
Where Can You See Totality in Canada?
Totality will not be visible from anywhere in Canada for the August 12, 2026 total solar eclipse. The path of totality crosses the Arctic, Iceland, Greenland, and northern Spain. Canadians must travel internationally to experience totality. However, a partial eclipse will be visible across most of Canada.
What Equipment Do You Need to Watch an Eclipse?
At a minimum, the required equipment includes ISO certified glasses, which are essential for eye safety during partial phases. Optional equipment includes binoculars, telescopes, or cameras with special solar filters. Never look at the sun through unfiltered optics or with the naked eye, except during totality if you're in the path.
Whether you're viewing a partial eclipse from home in Canada or travelling internationally to experience totality, preparation and the right equipment (like eclipse glasses) matter and will make your viewing more memorable.
If heading to a remote viewing location, bring reliable backup power like the EcoFlow DELTA 3 Max Plus. It’ll easily support your camera equipment, phones, or heated gear, so you can stay outside to enjoy the hours-long event.
If travelling, plan early. But if staying home, know that experiencing the partial eclipse will still create a memorable celestial event.
