Solar Panels in Quebec 2026: Hydro-Québec’s New Rebate Program Makes Solar Finally Make Sense
Quebec's new solar rebate has changed the numbers. The province's low electricity rates have historically made solar difficult to justify financially, but the LogisVert Efficient Homes Program now pays $1,000 per kW installed and covers up to 40% of eligible costs, significantly shortening the payback period.
This guide covers what the rebate includes, who qualifies, how to apply, and how to pair it with net metering for additional savings.
What Hydro-Québec’s 2026 Solar Rebate Actually Covers
Quebec’s new solar rebate and grant, which is through the existing LogisVert Efficient Homes Program, pays residents $1,000 per kW installed and covers up to 40% of eligible purchase and installation costs.
The rebate, similar to those offered in other provinces, such as Ontario’s Home Renovation Savings Program, is designed to help make installing and buying solar more affordable and viable for residents and also reduce the payback period of the system.
The funds you get back from this rebate are yours to use as you want, whether you use them to build up your savings, make home upgrades, or even reinvest in more energy efficiency, such as by outfitting your home with an EcoFlow DELTA Pro Ultra to keep you powered during outages.
As for what the rebate specifically covers, this includes:
  • Solar panels
  • Inverters
  • Wiring
  • Mounting
  • Labour costs
How Net Metering Turns Extra Solar Production into Real Savings
In addition to a solar rebate, Hydro-Québec also offers net metering, which helps you turn the solar you produce into financial savings. The way it works is fairly straightforward.
When your solar system generates power, it’s immediately used to power your home.
However, if you generate more than you need, the excess flows back to the grid. Because Hydro-Québec installs a bi-directional meter alongside grid-tied systems, you can measure not only how much grid power you use, but how much electricity you send back to the grid.
Because Quebec has a one-for-one exchange, every kWh of electricity you send to the grid gives you one kWh in credit. You can use these credits to reduce your bill or bank them for future use.
But keep in mind that your credit bank is reset every 24 months. Any unused kWh credit after two years is paid out.
Eligibility and How to Apply without Missing Key Deadlines
However, just like many of the other provincial and federal solar incentives in Canada, there are some important eligibility requirements you need to meet. To be eligible for the new solar rebate in Quebec, your solar panels need to be:
  1. New.
  2. Purchased from a Quebec retailer or a retailer with an address in Quebec.
  3. Installed in an eligible home.
  4. Installed on or after June 30th, 2025.
The work must involve the complete installation of solar panels and needs to be conducted by a company listed on the Registraire des entreprises du Québec. The company must have the appropriate licences issued by the Régie du bâtiment du Québec (RBQ) based on the work required.
Also, all solar panel installations in Quebec must be officially authorized for grid connection by Hydro-Québec and need to comply with CSA 22.2 (No. 61730) and CAN/CSA-IEC 61215.
While being eligible is important, you also want to make sure you apply on time. From the day your installation is complete, you have exactly nine months to apply. If you miss this deadline, you won’t be eligible for the rebate.
To apply, use the LogisVert Efficient Homes Program portal and fill out/provide the information the application requests.
The EcoFlow DELTA Pro Ultra is a ultra-reliable, UL-certified home power solution delivering 7.2–21.6kW output to run heavy loads like central AC. With an expandable 6kWh–90kWh capacity for weeks of backup, it features a self-heating battery, five charging options, and seamless integration with the Smart Home Panel 2 for automated energy savings and switchover.
What Solar Typically Costs in Quebec and How Long Payback Can Take
In Quebec, the cost of installing solar depends on the size and capacity of your system. Generally, these systems cost around $3 per watt in Quebec. So a 5kW system may cost around $15,000, while an 8kW system may be close to $24,000. Also, when determining your costs, make sure to account for things like solar power incentives and tax breaks.
Once you have the total costs, divide by the amount of financial benefits the system provides each year, making sure to consider both electricity bill savings and any net metering benefits. The number you end up with should be your payback period.
For example, if you have a $20,000 system and it saves you $1,000 per year, your payback period is 20 years. Because of the low electricity rates in the province, payback periods in Quebec are generally longer, often anywhere from 12 to 20+ years. However, this new program helps to offset this.
Adding Storage for Backup and Better Solar Control
An important thing to consider when implementing solar is storage. A solar storage system, often a type of rechargeable battery, adds more flexibility and control to your system. It lets you store some of the power you generate to use at night, on cloudy days, or even during outages.
For example, a storage solution like the EcoFlow DELTA 3 ULTRA Plus + 400W Solar Panel lets you not only generate power with panels, but also have a high-capacity backup for peace of mind if a major outage hits your area.
How Much is the Hydro-Québec Solar Rebate in 2026?
The rebate offers $1,000 per kilowatt of installed solar capacity and covers up to 40% of total eligible project costs. On average, this is between $5,000 and $6,000 for residential customers and around $45,000 for businesses.
How do Hydro-Québec Net Metering Credits Work in Quebec?
The net metering credits are a one-for-one exchange, so every kWh of electricity you send to the grid, you get one kWh credit. You can bank these credits month-to-month, but your credit bank is reset to zero every two years. Any unused kWh credit at this time is applied to your bill.
What is the Typical Payback Period for a 5 kW Solar System in Quebec?
While it varies depending on the cost of the system and the annual electrical savings it provides, a typical payback period is often between 12 and 20 years.
Can I Combine Quebec’s Solar Rebate with Other Incentives?
Yes, you can combine the solar rebate with other incentives, as the province allows for stacking to maximize benefits.
Make the Rebate Work Harder for Your Home Energy Plan
Despite years of solar not making much financial sense in Quebec, the province’s new rebate has changed that. It provides a meaningful upfront rebate and covers up to 40% of eligible purchase and installation costs.
To get the most out of it, combine the rebate with net metering credits to bring your payback period down further.
When you're ready to explore your options, EcoFlow solar generators pair panels with battery storage for a complete residential setup. Or, if you're thinking about full energy independence, explore EcoFlow's whole-home generator solutions.
Solar energy
