Best Time to Do Laundry in Ontario: Cheapest Hours on Every Price Plan
Laundry is one of the easiest chores to time around Ontario's electricity prices. Washers and dryers use a fair amount of power, and on most plans that power costs more at certain hours. From November 1, 2026, On the Ultra-Low Overnight plan, the highest electricity rate is about ten times the overnight rate. That gap makes a little planning worthwhile. This guide shows when laundry costs least on each plan and what a typical load costs. It also explains how to save without running a dryer while you sleep.
How Ontario's Electricity Price Plans Shape Your Laundry Costs
Most Ontario households pay Regulated Price Plan (RPP) prices set by the Ontario Energy Board (OEB). Your plan decides whether the clock affects what each load costs. New prices take effect on November 1, 2026.
Homes on RPP pricing can choose one of three plans. Time-of-Use (TOU) is the default for most customers. The ultra-low overnight price plan offers very cheap nights but a steep weekday evening peak. Tiered pricing charges the same rate at every hour, up to a monthly limit.
The OEB's current electricity rates page lists these prices from November 1, 2026, in cents per kWh:
Plan | Cheapest price | Middle price | Highest price |
Time-of-Use (TOU) | Off-peak: 9.1 | Mid-peak: 14.6 | On-peak: 18.9 |
Ultra-Low Overnight (ULO) | Overnight: 3.7 (weekend off-peak: 9.1) | Mid-peak: 14.6 | On-peak: 37.7 |
Tiered | Tier 1: 11.2 | Not applicable | Tier 2: 13.2 |
Energy only: Delivery, regulatory charges, HST, and the Ontario Electricity Rebate also appear on your bill.
Rebate change: The Ontario Electricity Rebate becomes 15.7% on November 1, 2026.
Tier limits: Tier 1 covers the first 1,000 kWh a month in winter (November 1 to April 30) and 600 kWh in summer.
Older prices: Prices in effect until October 31, 2026, were higher, with TOU off-peak at 9.8 cents.
You can switch plans by contacting your local utility.
Once you know your plan, the next step is matching laundry day to its cheapest hours.
The Cheapest Time to Do Laundry in Ontario on Each Plan
The cheapest time to do laundry depends entirely on your plan. TOU and ULO reward different habits, and Tiered ignores the clock. Here is how the hours line up, plus what a typical load costs.
Off-peak electricity hours in Ontario follow fixed schedules set by the OEB. Laundry is easy to shift into those windows because it rarely has to happen at a set hour.
Time-of-Use: Weekday Evenings and All Weekend
On TOU, off-peak runs from 7 p.m. to 7 a.m. on weekdays. It also covers weekends and holidays all day. Off-peak hours stay the same all year, while the daytime peak periods swap with the season.
Weekday period | Winter (Nov 1 to Apr 30) | Summer (May 1 to Oct 31) |
Off-peak (9.1¢) | 7 p.m. to 7 a.m. | 7 p.m. to 7 a.m. |
Mid-peak (14.6¢) | 11 a.m. to 5 p.m. | 7 a.m. to 11 a.m. and 5 p.m. to 7 p.m. |
On-peak (18.9¢) | 7 a.m. to 11 a.m. and 5 p.m. to 7 p.m. | 11 a.m. to 5 p.m. |
A weekday load started at 7:30 p.m. and a Saturday afternoon load both get the off-peak price.
Ultra-Low Overnight: 11 p.m. to 7 a.m.
On ULO, the cheapest price applies every day from 11 p.m. to 7 a.m. Weekends and holidays from 7 a.m. to 11 p.m. get the weekend off-peak price. ULO hours do not change by season.
ULO period | Hours | Price |
Ultra-low overnight | Every day, 11 p.m. to 7 a.m. | 3.7¢ |
Weekend off-peak | Weekends and holidays, 7 a.m. to 11 p.m. | 9.1¢ |
Mid-peak | Weekdays, 7 a.m. to 4 p.m. and 9 p.m. to 11 p.m. | 14.6¢ |
On-peak | Weekdays, 4 p.m. to 9 p.m. | 37.7¢ |
A dryer cycle at 6 p.m. on a weekday costs about ten times more than one at 6 a.m.
Tiered: Timing Does Not Change the Price
On Tiered pricing, every hour costs the same. Saving on this plan comes from using less energy per load, not from moving it.
Statutory Holidays Count as Off-Peak
The OEB's TOU and ULO holiday schedule treats 10 holidays as off-peak all day on TOU and weekend off-peak on ULO. They are New Year's Day, Family Day, Good Friday, Victoria Day, Canada Day, Civic Holiday, Labour Day, Thanksgiving, Christmas Day, and Boxing Day. When a holiday falls on a weekend, the next weekday gets holiday pricing. In 2026, Boxing Day pricing applies on Monday, December 28.
What One Load Costs at Different Times
The dryer uses far more electricity than the washer. Natural Resources Canada data on new appliances works out to about 2.1 kWh per load for an electric dryer. A new washer uses roughly 0.5 kWh per load. These are test-cycle averages, so your machines may differ.
Estimated energy cost per load (2.6 kWh in total):
Plan and time | Washer only | Dryer only | Full load (both) |
ULO overnight (3.7¢) | about 2¢ | about 8¢ | about 10¢ |
TOU off-peak or ULO weekend (9.1¢) | about 5¢ | about 19¢ | about 24¢ |
Tiered, Tier 1 (11.2¢) | about 6¢ | about 24¢ | about 29¢ |
TOU or ULO mid-peak (14.6¢) | about 7¢ | about 31¢ | about 38¢ |
TOU on-peak (18.9¢) | about 9¢ | about 40¢ | about 49¢ |
ULO on-peak (37.7¢) | about 19¢ | about 79¢ | about 98¢ |
Costs cover the energy price only, before delivery, regulatory charges, HST, and the rebate.
Across several loads a week, those cents add up over a year.
Shifting laundry to cheaper hours works well, but it does not suit every schedule.
Using a Home Battery to Shift Laundry Energy
Some households cannot always wait until evening or the weekend to do laundry. A home battery can store electricity at off-peak prices and supply it later. It can help in the laundry room, but how it connects matters.
The battery charges during off-peak hours, such as 11 p.m. to 7 a.m. on ULO. Your home then draws on stored energy during pricier hours. Since washing machine wattage varies by model, check your washer's label first.
Be clear about the limits before you buy:
How it connects: Plug-in devices run directly from the battery. Home circuits and hard-wired appliances, such as most dryers, need the compatible SHP10 installed by a qualified electrician.
Selected circuits only: The SHP10 covers up to 10 selected circuits, not every appliance at once.
Savings vary: Some energy is lost in charging and discharging, and results depend on your plan and loads.
Plan matters: The price gap is widest on ULO, at 3.7¢ overnight versus 37.7¢ on weekday evenings. On TOU, the gap is smaller.
The TITAN 5000 Plus is built for this kind of load shifting. It works with the grid, charging off-peak and supplying power during peak hours.
The TITAN 5000 uses the same off-peak charging approach with 7.2kW of output.
The savings figures on these cards are modelled estimates for Toronto homes on Ontario's ULO plan, and results vary. Both units need an indoor, dry location, and runtime depends on the load.
Small changes to how you wash and dry also trim the cost of every load.
Laundry Habits That Lower Costs Safely
How you wash and dry clothes changes how much energy each load uses. Safe timing matters too, because the cheapest hours often fall while you sleep.
Washer Tips
Natural Resources Canada's tips for a more efficient laundry day start with the washer.
Wash in cold water: This saves the energy that would go into heating water.
Run full loads: Fewer, fuller loads use less energy than several small ones, as long as you do not overfill.
Use delay-start: Set the washer to finish shortly before you wake up. Many smart home tools that save energy pair well with an appliance's own delay-start setting.
Pick high-speed or extended spin: Drier clothes need less time in the dryer.
Choose ENERGY STAR when replacing: NRCan says certified washers use about 25% less energy and 33% less water than standard models.
Dryer Tips
Clean the lint trap after every load: Better airflow helps the dryer work efficiently and lowers fire risk.
Air dry when you can: A drying rack or outdoor line uses no electricity at all.
Choose ENERGY STAR when replacing: NRCan says certified dryers use about 20% less energy than standard models.
Do Not Run the Dryer While You Sleep or Leave Home
The City of Toronto's clothes dryer fire safety tips say to turn the dryer off if you leave home or go to bed. Ontario's Office of the Fire Marshal shares the same advice. This matters because ULO's cheapest hours run overnight.
A safer schedule keeps the savings without the risk:
Delay-start the washer so it finishes near the end of the overnight window.
Move clothes to the dryer when you get up, before 7 a.m. on ULO.
On TOU, dry clothes on weekday evenings after 7 p.m. while you are still awake.
Save big dryer loads for weekends, when TOU off-peak prices last all day.
The best time to do laundry in Ontario depends on your price plan. On TOU, weekday evenings after 7 p.m. and weekends cost least. On ULO, 11 p.m. to 7 a.m. is cheapest, and weekday evenings are priciest. On Tiered, timing makes no difference. Cold washes, full loads, and a clean lint trap help on any plan. To use cheaper overnight power during pricier hours, an EcoFlow TITAN 5000 Plus can store energy off-peak.
When Is the Cheapest Time to Do Laundry in Ontario?
On ULO, it is 11 p.m. to 7 a.m. every day, at 3.7 cents per kWh. On TOU, it is weekdays from 7 p.m. to 7 a.m., plus weekends and holidays, at 9.1 cents. On Tiered, every hour costs the same.
Is It Cheaper to Do Laundry on Weekends in Ontario?
Yes, on TOU and ULO. TOU charges off-peak prices all weekend. ULO charges 9.1 cents from 7 a.m. to 11 p.m. on weekends, and 3.7 cents overnight.
Is It Safe to Run the Dryer Overnight to Get Cheaper Rates?
No. Fire safety officials advise turning the dryer off when you go to bed or leave home. Run the washer overnight with delay-start, then dry the clothes once you are up.
Does Doing Laundry at Night Save Money on Tiered Pricing?
No. Tiered prices do not change by time of day. You save on this plan by using less energy, such as washing in cold water and air drying.
Can a Home Battery Run a Clothes Dryer?
Only through the right setup. Most electric dryers are on a 240V circuit, which needs the compatible SHP10 installed by a qualified electrician. The dryer circuit must also be one of the selected circuits.
