Extreme Hail, Wind & Storms in Canada: Why Your Home Energy System Needs to Be Resilient
Canada experiences some of the most extreme weather in the world, and events like storms are becoming increasingly frequent due to climate change. Your home has unique vulnerabilities depending on your location, and that includes your energy system. Extreme weather events can create outages, leaving you in the dark and cold if you don’t have a backup.
Learn how you can make your home more resilient with a renewable energy backup power system to preserve food, medical equipment, and communications systems whenever disasters strike.
Climate-Driven Storms: What This Means for Your Canadian Home
Climate change is increasing the frequency and intensity of storms across Canada. The warming air can hold more moisture, creating strong weather systems. These events can leave residents without power and damage infrastructure, and the increased frequency makes it harder to repair and recover.
Traditional emergency preparedness strategies aren’t cutting it. We need new tactics to address the longer and more severe outages that sometimes affect entire regions.
If you have home energy independence, you’re no longer reliant on these vulnerable grid systems, and you place the power back in your hands. It’s time we shift from reactive responses to proactive planning to maintain the integrity of Canada’s communities, families, and infrastructure.
EcoFlow DELTA Pro Ultra X on wall
Identifying Your Home’s Climate Vulnerabilities
The climate risks vary depending on your region in Canada. Honing in on what your region faces will allow you to tailor your resilience strategies to local weather patterns.
British Columbia
British Columbia sees everything from wildfire smoke, atmospheric rivers, extreme heat, earthquakes, and drought.
  • Seal your indoor environment and use air filtration systems.
  • Coastal storms and king tides can cause flooding of waterfront properties. Ensure you have flood insurance and a well-defined evacuation plan in place.
  • Consider using electric water pumps for well water and irrigation systems, as drought periods can lead to water scarcity.
Prairie Provinces
The prairie provinces are prone to severe hailstorms, tornado activity, prolonged droughts, flash flooding, extreme temperature fluctuations, derechos, and ice storms.
  • Create a tornado shelter with reliable emergency power for medical supplies and facilitating communication.
  • Flash flooding can overwhelm drainage systems, leading to basement flooding. A sump pump can help.
  • Long-duration power outages caused by derechos (straight-line wind storms) can affect entire provinces. A backup is a necessity.
Ontario
Ontario is highly populated, so the impacts of events like ice storms, severe thunderstorms, freeze-thaw cycles, and flash flooding affect a large number of people.
  • Cities like Toronto face urban heat islands that can overwhelm grid infrastructure, creating widespread or long-lasting power outages. Have a plan in place and a backup ready to go.
  • Ice storms have historically created the most devastating power outages in Canadian history. You don’t want to be left without power for weeks.
  • Peak summer cooling needs often coincide with severe weather, creating a perfect storm for grid failure.
Quebec
Quebec’s primary risks are extreme heat, flooding, ice storms, and coastal erosion.
  • Mitigate urban heat islands with green roofs, shade structures, and cooling strategies.
  • Prepare for ice storms with backup heating systems and emergency supplies.
  • Coastal areas should be protected from erosion.
Atlantic Canada
The Atlantic provinces can experience extreme storms and hurricanes, as well as coastal flooding and erosion, which can contribute to a rise in sea levels as the climate continues to warm.
  • Use hurricane-resistant construction strategies.
  • Protect from coastal floods with elevated foundations and flood barriers.
  • Prepare your evacuation plans for severe weather events.
Northern Canada
The coldest territories and provinces in Canada face permafrost thaw, extreme temperature fluctuations, and changing precipitation patterns.
  • Utilize pile systems, adjustable foundations, and thermal protection to shield against the impacts of permafrost.
  • Infrastructure monitoring systems can detect ground shifting and foundation problems.
  • Use enhanced drainage systems to manage fluctuating precipitation.
Harness up to 2600W of solar input with dual PV ports for versatile setups. Enjoy faster charging with high conversion rates and 99% MPPT efficiency. Power all your essentials with massive AC output and manage everything seamlessly through the app—from charging priorities to real-time energy stats.
Grants and Incentives To Fund Resiliency Upgrades
Canada offers federal and provincial incentives and grants to enhance the resilience of homes and communities.
The Canada Greener Homes Initiative is one example. The grants and loans are currently closed, but the Oil to Heat Pump Affordability program remains available, helping homeowners transition to an eligible heat pump system.
Other community-wide programs include the Greener Neighbourhoods Pilot Program (GNPP), which is currently funding the application of Energiesprong aggregated deep energy retrofits to upgrade community housing on a larger scale. Projects are already underway and will continue over the next several years to determine the program’s impacts and benefits.
Other funding options and programs may be available at a provincial or municipal level where you live. You can also ask your energy provider about available rebates or your insurance company for a discount if you have a backup power system.
Energy Storage and Standby Power: Keeping Your Home Powered During Outages
Home energy battery systems provide backup power during outages. You can choose a smaller system to keep essential circuits running, or opt for a whole-home generator that offers seamless transition to comprehensive backup power. A model like the EcoFlow DELTA Pro Ultra X is perfect for that.
Battery or solar systems provide silent and automatic backup. They have no noise, no emissions, no fuel, and minimal maintenance requirements. Lithium-ion or LiFePO4 battery technology is reliable for days or even weeks when paired with solar, providing continuous and uninterrupted power.
Tie them to the grid to allow for regular operation, or go completely off-grid to achieve complete energy independence.
EcoFlow DELTA Pro 3 with solar panel
What Is the Resilience of the Energy System?
Energy system resilience measures how quickly power infrastructure can recover from damage or disruptions. The best way to achieve resilience in a home battery system is by combining multiple power sources, selecting a system with a large storage capacity, and managing your critical loads effectively.
How To Make Your Home More Resilient?
Install backup systems that automatically turn on when the grid is disrupted, upgrade electrical panels to ensure proper load management, create emergency preparedness plans, and regularly test and maintain your systems. Also, use energy efficiency measures to reduce overall energy use.
Is Canada at Risk of Natural Weather Hazards, Yes or No?
Yes, Canada is vulnerable to natural weather hazards. It faces some of the most extreme weather, including storms, floods, droughts, and fluctuating temperatures. As the climate changes, the weather becomes more volatile, making the risks more severe.
Protect Your Home With EcoFlow’s Resilient Energy Solutions
If you want peace of mind knowing that your home is resilient despite the fluctuating and often extreme weather in Canada, investing in renewable energy systems is invaluable. Modern energy storage, whether through battery backups or solar, such as the EcoFlow DELTA Pro 3 Solar Generator (PV400W), provides superior reliability, convenience, and environmental benefits. Invest in your home’s energy resilience to protect your family in the long term.
Home Backup
