Best Portable Power Stations for Ice Fishing in Sub-Zero Canadian Winters
Looking forward to ice fishing in the Canadian winter? Ice fishing is about more than just catching fish — it’s a time-honored tradition passed down through the generations.
Even if you’re new to ice fishing, this incredible sport offers you the chance to take in stunning landscapes and waterscapes when the cold climate hits.
However, to make the most of ice fishing, and to stay safe while doing it, you need essential ice fishing gear and access to a continuous source of power. This is where portable power stations with multiple charging options come in handy.
EcoFlow’s Top Portable Power Stations for Sub-Zero Ice Fishing
Best for Extended Solo Fishing: Ecoflow DELTA 3 Classic
The EcoFlow DELTA 3 Classic is the perfect backup power companion for short fishing trips.
This system can hold 1024Wh of stored energy, with 1800W power output and 3600W surge output. It can power items such as LED lights, fish finders, and charging devices for an entire day of fishing with ease.
  • 4 ways to charge
  • 0–80% in 45 minutes
  • 1800W power output
  • 3600W surge output
  • Condensation protection
  • Equipped with automotive-grade full-tab LFP cells
Best for Family Ice-Fishing Adventures: EcoFlow DELTA 3 Max Plus
The EcoFlow DELTA 3 Max Plus holds 2048Wh of power, which is enough for several days of fishing if you only need to power basic equipment such as lights and fish finders.
While the DELTA 3 Max Plus is a bigger unit, it still only weighs just over 20kg, which is 13% less than its predecessor. Like the other models in the EcoFlow DELTA series, it comes with full-tab LFP cells, four ways to charge, and ultra-quiet operation.
  • 5 ways to charge
  • 3000W power output
  • 6000W surge output
  • 2–10 kWh expandable capacity
DELTA 3 Max Plus Portable Power Station
The EcoFlow DELTA 3 Max Plus delivers 3000W of reliable power (6000W surge) with X-Boost™ to handle heavy-duty appliances. Charge to 80% in just 43 minutes, expand up to 10kWh, and control circuits smartly via the app. Durable, whisper-quiet, and backed by up to 5 years of warranty, it’s power you can count on anywhere.
Best for Multi-Day Fishing Trips: EcoFlow DELTA 3 Ultra Plus
If you’re travelling with companions and need something more powerful, the EcoFlow DELTA 3 Ultra Plus packs double the punch with its 3600W of power output and 7200W of surge output.
In addition to all your electrical fishing equipment, this unit supports heavy-duty appliances up to 4600W, meaning you can cook, watch, browse, and listen while fishing.
The EcoFlow DELTA 3 Ultra Plus is even quieter, too, operating at a whisper of just 25dB.
It also features the OASIS 3.0 Smart App Control, enabling you to monitor battery status on the go using a mobile app. Better still, it holds 3072Wh, meaning it can operate for several days without needing recharging.
  • 6 ways to charge
  • 3600W power output
  • 7200W surge output
  • 3–11 kWh expandable capacity
Best for Short Lake Escapes and Solo Fishing: EcoFlow RIVER 3
Hitting the winter lake for a couple of hours of fishing? If you just need to power a couple of light-wattage appliances during your quick outing, the EcoFlow RIVER 3 will prove a worthy fishing companion. It offers 300W rated output, or 600W with X-Boost technology.
Compared to its industry competitors, it’s 30% smaller, too. It also runs at <30dB, which ensures you’ll remain comfortable on the lake without scaring the wildlife away. Moreover, its features include condensation protection and an IP54-rated waterproof battery pack.
  • 4 ways to charge
  • 300W rated power output
  • 600W surge output
  • Fast charging with no battery damage
  • Weight of just 7.8 lbs (3.5 kg)
An EcoFlow RIVER 3 Portable Power Station
Why Does Ice Fishing Require Reliable Power?
Naturally, the most essential items of ice fishing equipment are specialized ice fishing rods. But when you’re fishing in subzero conditions, having access to continuous power is critical for many reasons.
First and foremost is safety. If you’re heading out for a full-day or multi-day fishing trip, you may need a constant source of power for heaters, augers, and lighting.
Without a reliable power source, you face the risk of facing brutal weather conditions without heating, a loss of communication, and navigability.
Besides safety, you’ll need access to reliable power to make sure your ice fishing trip is a success. Power stations that can utilize battery-stored energy and solar power ensure your fish finders, GPS units, and underwater cameras remain functional at all times.
Even when you arrive back at shore, having a portable power station can prove invaluable. You might struggle to access the grid in remote areas.
What to Consider When Choosing a Portable Power Station for Ice Fishing?
Consider these crucial factors when choosing a portable power station for ice fishing:
  • Battery capacity (Wh): The battery capacity gives you insights into how long the power station can run your essential fishing equipment.
  • Output power (W): You need a power station with enough continuous power for all your critical equipment and enough surge power to handle the startup surge of equipment such as heaters and augers.
  • Charging options: The more charging options, the better, particularly given that you won’t have access to the grid while on the lake.
  • Noise level (dB): Ideally, you need a power station that operates at a maximum of 30dB for fishing.
  • Cold-weather performance: Choose a power station that uses LiFePO4 batteries, which drain less easily in subzero conditions.
  • Durability: Make sure the power station holds relevant IP ratings that prove its dust and water resistance.
  • Weight: Pay attention to weight and portability when choosing a power station that you may need to move around frequently.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
How Do You Keep Batteries Warm While Ice Fishing?
For ice fishing, you should choose a portable power station with LiFePO4 batteries that are designed to hold their charge in cold conditions. You should also keep spare batteries stored inside padded bags or insulated cases. Remember that lithium batteries are particularly prone to draining quickly in cold climates.
What Size Power Station Do You Need for Ice Fishing?
The size of the power station you need for ice fishing depends on the gear you need to operate. A power station with 200–600Wh will suffice if you only need to power low-wattage electronics for a day or two. If you need continuous power for heavy-duty items like heaters and augers, you’ll be better off with 2000–3000Wh.
Reliable Power Keeps Ice Fishing Safe, Comfortable, and Productive
If you’re heading out for a day on the wintry lakes to escape the bustle of the city, ice fishing can be an extremely rewarding experience — provided you have your power needs covered.
With a reliable portable power station, you can remain safe, comfortable, and productive as you explore the open waters.
Browse the full EcoFlow portable power station range to find the right fit for your next ice fishing trip.
Outdoors
