Beginner Ice Fishing Accessories: What to Buy (and What to Skip)
Ice fishing has a steep gear learning curve, and it can be easy to overspend on fancy, complicated equipment even before your first trip. Don't buy too much too soon or miss a true essential that can make or break your time on the ice.
We're helping you cut through the noise by sharing your ice fishing must-haves for your first trip, comfort upgrades worth considering, and gear you can safely skip for now. For all your energy needs, consider an EcoFlow Portable Power Station.
The Essential Ice Fishing Accessories to Start With
Here are nine core items every ice fishing beginner needs to get on the ice safely and start catching fish.
Ice Auger
An ice auger will drill your holes through the ice. Without it, you can't fish.
A manual hand auger is the best starting point for beginners. It's lighter and cheaper, and you don't need a battery or fuel to get it started.
Look for a 6-inch diameter auger for most species, or upgrade to an 8-inch auger if you're targeting larger fish like lake trout or pike.
Rod and Reel
Next, you'll need a specialized rod and reel.
Ice fishing rods are shorter than open water rods. They're usually 60–90 cm and uniquely designed for fishing through a small hole.
Pair it with a light spinning reel for a versatile beginner setup.
Line
Invest in a light monofilament or fluorocarbon line in the 2–4 kg test range to cover most of your beginner ice fishing situations. Fluorocarbon is nearly invisible underwater and tends to perform better in cold temperatures, so you may want to consider this slightly modest upgrade.
Always match your line weight to your target species and jig sets, too.
Tackle and Bait
Invest in live bait like wax worms, spike larvae, and minnows to increase strike rates as a beginner.
Another option is artificial baits, which eliminate the hassle of keeping the bait alive in the cold.
Tip-Ups
A tip-up is a mechanical device that’ll hold your line in the hole and signal a strike from a fish with a flag.
Start with a standard spring-loaded tip. They're inexpensive and reliable.
Ice Scoop/Skimmer
This will clear the slush and ice chunks from your hole after you drill and throughout your fishing session. Without a skimmer, you'll find that the hole will re-freeze quickly, making your fishing experience frustrating or nearly impossible.
Fish Finder
A basic fish finder will show the water depth and display any fish movement in real time beneath the hole. It’ll help you shorten the learning curve, avoiding any time wasted on an unproductive hole.
Ice Picks
Carry these two sharpened metal picks around your neck so you can use them to pull yourself out of the water if you break through the ice. This safety item is completely non-negotiable.
Bucket
Throw all your gear in a standard 20-liter (5-gallon) bucket. Once you're set up, you can flip it over and use it as a seat.
DELTA 3 Max Plus Portable Power Station
The EcoFlow DELTA 3 Max Plus delivers 3000W of reliable power (6000W surge) with X-Boost™ to handle heavy-duty appliances. Charge to 80% in just 43 minutes, expand up to 10kWh, and control circuits smartly via the app. Durable, whisper-quiet, and backed by up to 5 years of warranty, it’s power you can count on anywhere.
8 Helpful Ice Fishing Accessories That Improve Comfort
Once you’ve covered the essentials, a few extra items can go a long way in making your cold-weather sessions far more comfortable and enjoyable:
  1. Portable Power Station — Think of it as your whole-home generator for the ice hut for all your gear and devices. Options like the EcoFlow DELTA 3 Max Plus provide plenty of capacity in a portable design, making it easier to stay powered throughout extended sessions.
  2. Ice Fishing Shelter — Block the wind and retain any warmth you have. A flip-over hub style is portable and great for beginners.
  3. Insulated Clothes and Boots — Ice fishing suits are waterproof and buoyant, keeping you warmer than standard winter layers. Dedicated boots will keep your feet from freezing, as they’re always the first to get cold.
  4. Propane/Catalytic Heater — Take the edge off the low temperatures inside your fishing shelter. Always follow ventilation guidelines.
  5. Folding Chair — This small upgrade from a bucket is worth it for longer fishing sessions.
  6. Hand Warmers — Pack reusable hand warmers that are easy to stash away until you need them.
  7. Insulated Thermos — Enjoying a hot coffee or a warm soup is an incredible morale booster.
An EcoFlow DELTA 3 Max Series Portable Power Station
Ice Fishing Accessories Beginners Can Skip at First
Don’t fall into the marketing trap. Choose your upgrades based on experience, not anticipation.
  1. Power Auger — You only really need to upgrade from a hand auger to a power auger when drilling volume or thick ice becomes a real problem.
  2. Underwater Camera — You don't need this if you have a reliable fish finder. It only adds costs without proportional benefit for beginners.
  3. Electric Reel — Manual reeling is just fine for most ice fishing species and depths.
  4. Specialized Rod Holders/Cases or Gear Hauler — A bucket is sufficient when you're just starting out.
  5. Electronic Tip-Up Alarms — Standard flag tip-ups are still reliable. Electronic alerts solve a problem that you won't have yet as a beginner.
Smart Gear Choices Make Ice Fishing More Enjoyable
Ice fishing can be one of the most accessible winter activities when you start with the right foundation.
Proper ice fishing gear removes friction, but the wrong fishing gear (or missing essentials) can create it.
If you're a beginner, invest in the core basics and resist the marketing pull of specialty items.
From there, you can build your kit based on what problems you encounter after a few trips. Give yourself a few seasons to gradually accumulate your full setup.
An EcoFlow DELTA 3 Max Series Portable Power Station outside on grass
Do You Need a Fish Finder for Ice Fishing?
A fish finder isn't required, but it's strongly recommended if you're a beginner because it removes the guesswork of trying to locate fish beneath the hole on your own. It can also help you read water depth and bottom structure, dramatically shortening the learning curve. Start with a basic flasher unit as your entry point.
What Safety Equipment Should Ice Anglers Carry?
The most important piece of safety equipment is ice picks. Wear them around your neck for self-rescue in case you break through the ice.
Also, bring a rope to assist others. Never go ice fishing without telling someone where you're going and when you'll be back.
You don't need a full gear overhaul to get started at ice fishing. All you need is the right foundation. Use our nine essentials to get on the ice safely and start fishing effectively. From there, you can make comfort upgrades and decide which special gear is worth it.
When you're ready to add power to your shelter setup, try the EcoFlow DELTA 3 Max Plus with 2048Wh capacity and 3000W output that can reliably handle heaters, electronics, and device charging.
Start simple, fish often, and let your real experience guide what you add next.
Off-Grid Power
