Off-Grid Living Explained: Your Path to Total Energy Independence
Off-grid living in Canada is a big adventure. It gives you the freedom to do what you want without relying on local utilities, although it does mean you’re responsible for generating your own power and water.
Self-reliance is a must for off-gridders, so if you’re interested in this lifestyle, you need a solid system that allows you to live independently. Learn why off-grid living is on the rise in Canada, as well as how to plan your path to an off-grid life.
Understanding the Core Benefits of Off-Grid Living
When you live off-grid, you live in an area without public utilities, like water or electricity. Instead, you generate and manage your own resources. That might mean digging a well for fresh water and installing a solar array to power your home.
Off-grid living comes in so many forms, whether you want to live in a rustic cabin in the woods or an eco-friendly geodesic dome. Regardless of what your ideal off-grid lifestyle looks like, there are a lot of benefits to living on your own terms, including:
  • Independence: As an off-gridder, you don’t rely on the city or state to provide you with water or energy. You’re no longer vulnerable to grid outages or infrastructure failures. Instead, you rely on renewable resources like solar to meet your household’s needs.
  • Lower long-term costs: Building an off-grid property requires an upfront investment to buy land and install your own systems. Still, you don’t pay for utility fees or rent, which means more savings in the long term.
  • Mindful living: You’ll naturally ditch consumerist culture by living off-grid. This lifestyle requires being much more conscious about the food, water, and energy you consume. You have to live more intentionally, which requires sustainable habits that leave a smaller environmental footprint.
EcoFlow DELTA Pro Ultra in garden
Planning Your Path: Land, Costs, and Legal Considerations
Off-gridding may sound romantic, but this lifestyle requires meticulous planning. Factor in these considerations to go off-grid without the stress.
Location and Land
Not all Canadian provinces allow off-grid living. Some areas have strict zoning laws, while others are more flexible. Generally speaking, rural areas tend to have more lax laws. British Columbia has several off-grid communities, particularly on Lasqueti, Hornby, and Quadra islands. Newfoundland and Labrador are also popular choices because they have minimal building regulations and lower property taxes.
Once you’ve found a suitable location, look for properties compatible with off-grid living. They should have good solar exposure and access to groundwater, at a minimum. They should also meet your space requirements, especially if you plan homesteading for complete self-sufficiency.
Costs
The upfront cost of off-gridding varies a lot. It depends on your property’s location, size, and the type of structure you want to build (e.g., RV vs. a tiny home). You’ll need to account for land, construction materials, energy systems, and water or waste infrastructure. Generally speaking, getting set up can cost anywhere from $10,000 to over $70,000 CAD.
Fortunately, Canada’s Greener Homes Initiative can bring down solar installation costs. Over 30,000 families have already taken advantage of the program, so apply if you plan to use solar energy.
Laws
Aside from picking a province that’s off-grid friendly, you also need to consider more specific local laws. For example, some areas permit rain catchment systems, while others only allow wells. Some places allow farming, while others limit which types (and quantities) of animals you can have. When in doubt, chat with your local zoning representative to understand what’s allowed for your off-grid property.
Building Your System: Solar, Storage, and Water
To live off the grid successfully, you’ll need energy and water, at a minimum. Follow these tips to set yourself up for off-grid comfort.
Solar
Off-grid solar is projected to increase by 5% annually in Canada, so there’s a lot of demand for this technology. You can’t just buy solar panels and meet your energy needs, though; you need an entire solar system. This includes several components, including:
  • Solar panels: Carefully mounted solar panels capture sunlight and convert it into electricity. The number of panels you’ll need depends on your home’s energy consumption, sunlight hours, and your lifestyle.
  • Battery storage: Without a battery, you can only use solar energy when the sun is out. You need a storage solution to store excess energy made during sunny hours so you can power your home at night or during cloudy weather.
  • Inverter: An inverter transforms stored solar energy into alternating current (AC) that your home appliances use.
  • Monitoring system: To maximize your setup, a monitoring system (like the EcoFlow app) lets you track energy production and usage in real time.
Energy Storage
Battery capacity determines how self-reliant you can be. As an off-gridder, you need a more robust solution since you can’t connect to the grid. The EcoFlow DELTA 3 Ultra Plus is a whole-home solution that will keep your off-grid setup running for days without a recharge.
Water
Off-grid homes typically use wells or rainwater collection systems for water. However, this water isn’t treated, so you need a filter to stay safe. If you have a tiny home, you’ll also need an electric pump to bring water into your house. Keep in mind that, if you run out of power, you’ll also run out of water, because the pump requires energy to operate.
Living Arrangements: Where to Start (Communities, RVs, and Homes)
The great thing about going off-grid is that you don’t have to go all-in at first. You can embrace certain aspects of off-gridding, learn as you go, and try new things as you get more experience.
If you’re new to this lifestyle, consider joining an off-grid community or eco-village. These shared spaces have collective knowledge and established systems that are perfect for newcomers. You’ll learn hands-on, practical skills from like-minded folks, like how to grow food or manage a solar system. There were over 280 off-grid communities in Canada as of 2023, so there are plenty of areas to choose from.
You don’t have to build a cabin, either. Before building a permanent home, you can ease into off-grid life with an RV, camper, or tent setup. Spend weekends or short stretches off the grid to see how it feels. For example, you might camp in an off-grid RV while drilling a well or installing a solar array on your property.
What Are Some Off-Grid Living Mistakes?
Off-grid living can be tough. Failing to plan for adequate power and water can quickly become an emergency. Other issues, like poorly planning food consumption and failing to bring in medical supplies, can lead to life-threatening situations. Ultimately, off-gridding requires having a backup, and backups for your backups.
Can You Legally Go Live In the Woods?
In some areas, yes. It’s legal to live off-grid on land you own, provided you follow local zoning laws. However, setting up camp on Crown land or forested public land isn’t the same as ownership. If the area allows it, you need a permit to stay there. Still, most public lands don’t allow long-term residency. When in doubt, check with your municipality for guidance.
Discover True Independence With EcoFlow’s Portable Power Solutions
Off-gridding can feel intimidating at first, but it’s a rewarding experience if you’re an independent-minded free spirit. Proper planning makes all the difference, whether you’re powering a remote cabin or just trying out off-gridding in an RV.
To live off-grid, you need a reliable source of energy, and the EcoFlow DELTA 3 Ultra Plus provides whole-home energy suited to homesteading. With high-capacity battery storage, seamless solar integration, and smart app-based monitoring, it delivers dependable energy wherever you are.
Off-Grid Power
