Igloofest Quebec: Phones, Speakers, Lights, and Heated Gear
This March, the “coldest music festival in the world” returns to Quebec City. Transforming the Place Jean-Beliveau into an electrifying winter playground, Igloofest combines electronic music with sub-zero temperatures.
While the music and atmosphere create unforgettable moments, the harsh winter conditions present serious challenges.
Find out how to keep yourself warm and essential devices powered with backup power.
What Is Igloofest Quebec, and Why Does Power Matter?
Igloofest Quebec is an annual winter music festival taking place at Place Jean-Beliveau in Quebec City, featuring local and international DJs. The electronic music festival takes place at the beginning of March each year, when temperatures regularly drop below 0°C (32°F).
The cold can create unbearable conditions, and power is needed not only to power essential devices but to keep heating devices running. The cold also diminishes battery performance, meaning many devices discharge more rapidly.
Without reliable power solutions for Igloofest, festival-goers risk losing communication, navigation, photography capabilities, and warmth.
What Devices Do You Need to Power at a Winter Festival?
Igloofest attendees rely on multiple devices to stay safe, entertained, and comfortable throughout the cold outdoor festival. Understanding the power demand for each device is essential to packing enough backup power.
Phones and Charging Essentials
Smartphones are at the centre of everything Igloofest. They’re used for photography, navigation, communication, ticket access, payment, and more. While modern smartphones typically consume less than 20Wh per charge, cold weather can increase power consumption as batteries struggle to maintain voltage in freezing conditions.
Most Igloofest attendees go through two to four charging cycles a day. With the EcoFlow DELTA 3 Classic Portable Power Station storing 1024Wh, it can cover that demand for a group of 2–3 people across the full festival day, with enough capacity left over for speakers, smartwatches, and other accessories.
Smartwatches and fitness trackers also need to be charged.
Speakers and Audio Gear
Portable Bluetooth speakers improve the festival experience for groups gathering before entry, during breaks, or at nearby accommodations for pre- and post-festival fun. Cold temperatures reduce battery efficiency, so speakers rated for 10 hours may only deliver up to 4 hours before needing a charge.
Lighting for Visibility and Safety
LED lights serve both practical and creative purposes at Igloofest. Safety lighting, including battery-powered headlamps and flashlights, helps attendees navigate dark areas and helps friends locate each other. Decorative lights, glow accessories, and costume lighting enhance the festival experience.
Most LED lights consume less than 10 watts, depending on the brightness and quantity.
Heated Clothing and Accessories
Heated clothing uses the greatest amount of power but provides essential comfort and safety in Igloofest’s extreme cold. Heated jackets, vests, gloves, and insoles use electrical heating elements to maintain warmth in freezing temperatures.
Heated clothing can consume up to 50 watts of power and last up to eight hours, but batteries often fail in extreme conditions, necessitating external power sources.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
Why Do Batteries Drain Faster in Cold Weather?
Cold weather is known to impair battery chemistry and performance. Lithium-ion batteries, which are used in virtually all modern electronics, rely on chemical reactions that slow as temperatures drop.
Battery capacity can drop in extreme cold temperatures compared to room temperature performance.
The chemical reactions inside batteries require ions to move through an electrolyte solution. Cold temperatures cause the solution to thicken, increasing internal resistance and making ion movement sluggish. The increased resistance means batteries cannot deliver power as effectively, and cause voltage to drop, reducing efficiency and capacity.
Cold also increases self-discharge rates. Batteries lose charge in freezing temperatures even when unused. A fully charged phone might lose a quarter of its charge quickly without any use, purely from cold-induced discharge.
Devices also consume more power as they work harder to maintain function, and touchscreens become less responsive. Cold causes the perfect storm of reduced supply and increased demand.
How Do You Keep Phones and Speakers Powered in Freezing Conditions?
Keeping devices charged at Igloofest requires thermal control and adequate backup power. Portable power stations provide reliable solutions that maintain performance in cold conditions more effectively than power banks.
Keeping phones and other devices in pockets, especially in heated clothing, can keep them much warmer than outside temperatures, improving battery performance. When not actively using your phone, return it to your warm pocket immediately.
Portable power stations can power multiple devices simultaneously from a single source. Their large thermal mass and battery management maintain performance, and they often feature cold-weather features such as temperature monitoring and fast charging that work in freezing conditions.
How Can You Maximize Battery Life at Igloofest?
Strategic device management further extends battery life. Before and during the festival, keep these tips in mind:
  • Enable battery-saving modes on your devices to limit background processes and extend runtime.
  • Disable unnecessary connectivity features, such as Bluetooth, Wi-Fi, and location services, to prevent your phone from constantly searching for connections and draining battery.
  • Download essential content, such as maps, tickets, lineups, and music playlists, before arriving at Igloofest so you don’t need internet connectivity to access them.
  • Prioritize charging phones over other devices and plan charging cycles strategically to keep devices powered throughout the day.
Where Is the Igloofest?
Igloofest takes place at Place Jean-Beliveau in Quebec City. The event also takes place at three other locations — Montreal, Gatineau, and Edmonton — with festival dates starting in January and extending to March.
How Do You Keep Your Phone Alive at Igloofest?
Keeping your phone alive involves thermal protection and reliable backup power. Store your phone in a pocket close to your body to maintain warmth, and bring a cold-resistant portable power station that can deliver multiple full charges in sub-zero temperatures.
Reliable Power Keeps You Warm, Connected, and Ready at Igloofest
Igloofest presents a unique festival experience where normal battery performance is significantly reduced. Festival-goers must be prepared with reliable portable power to outlast the combination of sub-zero temperatures, extended outdoor exposure, and reliance on electronic devices for safety and enjoyment.
EcoFlow DELTA portable power stations are designed for cold-weather performance, delivering optimal performance in extreme conditions. Power your phones, speakers, and heated clothing to maximize your Igloofest experience.
Outdoors
