Hydroclimatic Extremes Are the New Norm Across Canada — Are You Ready?
Canada is experiencing an unprecedented frequency of drastic weather events that often combine drought, floods, heat, and wildfires. Known as hydroclimatic extremes (simultaneous or sequential weather disasters), these new conditions are changing the urgency of emergency planning and straining communities and infrastructure.
It’s time to recognize that these patterns have become the new norm. Preparing accordingly is essential to keep your household safe.
How Hydroclimatic Extremes Are Reshaping Risk
These compound weather events can create cascading failures, overwhelming emergency response systems, and deeming traditional risk assessments inaccurate. Such extremes are intensifying faster than infrastructure can adapt, leaving Canadians facing a new reality where preparedness must account for multiple threats simultaneously, rather than isolated disasters.
Regional Signs Across Canada
No corner of Canada is untouched by these hydroclimatic extremes. Coastal areas are especially impacted by a higher frequency of sequential dry-wet and wet-dry extremes.
British Columbia has been experiencing heat domes, immediately followed by atmospheric rivers, which have led to catastrophic flooding. In the prairie provinces, flash droughts are devastating agriculture, only to be hit with sudden storms. Even Atlantic Canada is seeing the impacts via increased hurricane intensity, storm surges, and coastal flooding.
Highly populated areas, such as Ontario and Quebec, have been experiencing extreme heatwaves, unprecedented rainfall, and severe thunderstorms.
Urban areas are particularly vulnerable, as aging stormwater systems are often overwhelmed by intense rainfall.
These Events Reflect a New Reality
Unfortunately, climate data now shows that 100-year flood events are occurring much more frequently, as often as every few decades. As the global climate changes, temperature extremes are already breaking records set just years earlier. Infrastructure explicitly designed for these climate changes wasn’t intended for conditions this extreme.
Seasonal patterns are less predictable, and traditional weather models are struggling to keep up with forecasts.
EcoFlow DELTA 3 Classic
The Science Behind Hydroclimatic Extremes
What’s causing these hydroclimatic extremes? It’s a combination of several factors.
As the atmosphere warms, it holds more moisture—about 7% more per degree Celsius increase in temperature. This creates intense rain. Specifically, the faster warming in the far north, known as arctic amplification, is disrupting traditional atmospheric circulation.
The jet stream is also becoming less direct, creating blocking patterns that can lock weather in place and amplify its impact. And that ocean water is warmer, which can fuel powerful storms when they develop.
When these events occur simultaneously or in sequence, their overall effects are exacerbated to an extreme degree. Climate models are confounded by their underestimation of the rate and severity of observed changes across Canada. Climate scientists simply can’t keep up.
Building Resilience and Preparedness
Preparing your home or building for these unpredictable events will help keep you safe and protect your property.
Start with home weatherization, including water sealing and insulation to reduce your vulnerability to temperature and weather extremes. Consider installing water storage or purification systems to ensure your home has access to safe drinking water during supply disruptions or boil advisories.
Preparing for power outages should be a priority. Assess your critical needs and determine if you want to ensure backup for just your essential appliances and devices, or if you’d rather take a more comprehensive approach with a whole-home backup solution.
Any emergency equipment you have should be regularly tested and closely maintained, including items such as sump pumps and generators.
Practical Readiness for Canadian Households
Practical preparation will allow you to face these hydroclimatic events with confidence and ease.
Emergency Plans and Evacuation Routes
Every household should create a documented emergency and evacuation plan, including multiple exit routes that consider different disaster scenarios, such as fires, floods, snow, and others.
Part of that plan should include where to locate an emergency supply kit, when to restock it, and what it should contain. Essentials include water, non-perishable food, vital documents, and medications.
Your communication plan should account for potential cell tower failures or internet disruptions. Consider safe meeting places in and outside of the home/neighbourhood if you can’t communicate with one another. If communication systems are working, you want to ensure you can use your devices. Invest in a portable power source, such as the EcoFlow DELTA 3 Plus Solar Generator (PV220W), for continuous energy access.
Practice your emergency drills as a family so everyone knows the procedures and how to execute them under stress.
Cooling Spaces and Supporting Vulnerable Neighbours
During extreme heat, consider the well-being of yourself and your neighbours. Designate cooling areas in your homes where you can run portable ACs or use backup power for air conditioning.
If you have elderly, very young, or disabled neighbours nearby, consider how you can help by either inviting them into your space, checking on them, or contacting emergency services on their behalf.
EcoFlow DELTA 3 Plus Solar Generator (PV220W) in office setup
Policy and Planning for a Climate-Ready Future
Policy makers and climate experts are still grappling with how to plan for a climate-ready future, given that this is the new reality. Municipal planning requires new climate adaptations, building codes must evolve, and federal disaster assistance programs are shifting toward prevention and resilience rather than post-disaster recovery to mitigate impacts.
What Are the Main Causes of Hydroclimatic Extremes in Canada?
Hydroclimatic extremes in Canada are primarily caused by global warming, which disrupts established weather patterns; arctic amplification, which changes jet stream behaviour and intensifies extremes; and increased atmospheric moisture, leading to more intense precipitation.
How Do Compound Weather Events Increase Climate Risk?
Compound weather events can overwhelm emergency response services and weaken infrastructure, thereby increasing the vulnerability of communities to climate-related disasters. They can create cascading failures, shortening recovery periods and preventing rebuilding between events.
What Is Blue-Green Infrastructure and How Does It Work?
Blue-green infrastructure combines water management (blue) and vegetation (green) to mimic natural water cycles, encourage filtration to reduce flooding risk, and provide urban cooling. These systems provide multiple benefits beyond disaster avoidance, including better air quality and improved community spaces.
How Can Homeowners Protect Against Flooding and Power Outages?
To protect against power outages, homeowners should invest in whole-home backup systems to ensure continuous power for their essential devices. These devices include sump pumps, which can prevent basement flooding. Other tactics include property grading to direct water away from homes, adding flood barriers, and regular maintenance of these systems.
Hydroclimatic Extremes Demand Awareness, Adaptation, and Resilient Action
Hydroclimatic extremes were once rare events, but in today’s Canada, they’ve become a regular occurrence across all regions. Households must prepare individually as provinces and municipalities struggle to keep up on a large scale. The best place to start is emergency planning. Update your infrastructure with preventive measures, familiarize yourself with your response procedures, and invest in a reliable backup solution, such as the EcoFlow DELTA 3 Classic (1024Wh), to maintain safety during compound disasters.
Home Backup
