How to Winterize a Trailer: Step-by-Step Winter Prep Guide
Water left in a trailer's plumbing can freeze, expand and damage a line, fitting, pump or water-heater component. Learning how to winterize a trailer means removing or protecting that water before local temperatures fall below the limits in the owner's manual. The exact procedure varies by plumbing layout and installed equipment.
Winterizing normally includes draining the water system, following the approved RV-antifreeze or compressed-air procedure, checking batteries and propane, and preparing the interior and exterior for storage. Owners asking how to winterize a camper or how to winterize a camper trailer should first use the instructions for their model, then work through the preparation steps below. The same core process used when winterizing an RV applies, but component locations and pressure limits differ.
When Should You Winterize a Trailer?
Winterize before the trailer is exposed to freezing conditions beyond what its systems can tolerate. If you are deciding how to winterize a camper trailer for Canadian storage, use the local hourly forecast together with the trailer and appliance manuals rather than relying on one national date.
Prepare Before the First Hard Freeze
Even a short freeze can damage plumbing when water remains in vulnerable lines or fittings. Do not assume that an enclosed trailer protects every component. Complete the model-specific procedure before the forecast reaches the manufacturer’s winterization threshold, especially if the trailer will be unheated or unattended.
Consider Your Local Canadian Climate
Canada is too large for one winterization date to work everywhere. Compare the local forecast, storage conditions and the trailer manufacturer's instructions.
  • The Prairies (AB, SK, MB): Freezing conditions can arrive early, so monitor forecasts and finish the full procedure before the trailer is exposed.
  • Central and Eastern Canada (ON, QC, Atlantic): Timing varies by location and year. Repeated freeze-thaw cycles also make roof seams, drainage points and moisture control part of the inspection.
  • Coastal British Columbia: Milder conditions do not eliminate freezing or moisture risks. Check the local forecast and plan for ventilation, leaks and condensation during storage.
What Do You Need to Winterize a Trailer?
Required supplies depend on the procedure approved for the trailer. Common items include potable-water-system RV antifreeze, a compatible water-heater bypass arrangement and, when the manual permits it, a blowout adapter and regulated compressor. A portable power station is optional but can run compatible lighting or tools when the storage site has no suitable outlet.
Gather Essential Tools and Supplies
Hunting for an adapter while grey water drips onto the driveway isn’t how anyone wants to spend a Saturday. Have these on hand before you start.
Tool / Supply
What It Does
Blowout Adapter & Air Compressor
Pushes residual water out when the trailer manual permits compressed-air winterization
RV Water Heater Bypass Kit
Routes approved RV antifreeze around the water heater so the tank can remain drained
Water Heater Flush Wand
Flushes sediment and mineral scale off the bottom of the tank
Basic Hand Tools & Teflon Tape
Gets drain plugs and anode rods out, and seals the threads going back in
Moisture Absorbers (e.g., DampRid)
Pulls moisture out of the air inside the trailer over months of storage
Choose the Right RV Antifreeze
Do not use automotive antifreeze in an RV potable-water system. Use only a product labelled for RV or marine potable-water plumbing, and follow its handling, dilution and disposal instructions. Product chemistry varies, so the label and the trailer manufacturer's procedure take priority.
Read the product's burst-protection and freeze-point information carefully; these ratings do not necessarily mean the liquid remains pourable at the stated temperature. Residual water can dilute the product, so use the quantity and procedure specified for the plumbing system and expected storage conditions.
EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)
How to Winterize a Trailer Step by Step
If you are learning how to winterize a travel trailer, organize the work around four areas: drain and protect the water system, inspect exterior seals, prepare batteries and propane, and clean the interior. Follow the component manuals wherever their steps differ from this general sequence The same core sequence applies when winterizing an RV, although component locations and pressure limits vary.
Drain Freshwater and Wastewater Tanks
Empty both holding tanks at an RV sani-dump, black first and then grey, so the grey water rinses out the sewer hose on the way through. Back home on level ground, open the freshwater tank drain and the low-point drains, then open every faucet and the shower so the water trapped in the lines can run out.
Empty the Water Heater Safely
On a tank-style water heater, turn off the electric element and the propane supply, and give the water in the tank time to cool right down. Shut off the water supply and open a hot tap to relieve the pressure, then pull the drain plug or anode rod and let the tank empty. Set the bypass valves so the antifreeze you pump through later goes around the tank, not into it. Your owner’s manual shows which way they turn.
Protect Pipes and Plumbing Fixtures
You can protect the plumbing with compressed air, RV antifreeze, or both. Plenty of owners blow the lines out first and pump antifreeze through after.
  1. Blow Out the Lines: Use a compatible blowout adapter and regulated, oil-free compressor only if the trailer manufacturer permits this method. Set pressure at or below the limit in the owner's manual, then open fixtures in the specified sequence until water is cleared. Do not rely on a universal PSI setting.
  2. Pump RV Antifreeze: After draining the system and setting the water-heater bypass, connect the approved winterizing hose to the pump intake. Run the potable-water-system RV antifreeze through each required fixture in the sequence specified by the manufacturer. Protect the city-water inlet and check valve only by the method in the owner's manual; forcing the valve can damage it.
  3. Protect P-Traps: Pour antifreeze down each sink and shower drain, and a bit into the toilet bowl to protect the seals.
Inspect Exterior Seals and Roof
Go over the roof seams, vents, skylights, windows, and trim for cracked, lifting, or missing sealant. Clean those spots and reseal them: self-levelling lap sealant on the roof, non-sag sealant on window frames and trim, both rated for EPDM, TPO, or fibreglass. Fix any leak now, before snow and ice sit on it.
Prepare Batteries and Propane Systems
Prepare the house battery according to its chemistry and the battery manufacturer's storage instructions. Disconnect parasitic loads where appropriate, use only an approved charger or maintainer, and observe the specified charging and storage temperature range. For propane, close the cylinder valve and have damaged hoses, regulators or fittings inspected by a qualified technician.
A winterized trailer may still be used for dry camping when its plumbing remains protected and the trip follows the manufacturer's cold-weather limits. Size any temporary power source from the connected devices' combined wattage and expected runtime.
For compatible short-trip loads, the EcoFlow DELTA 3 Classic Portable Power Station provides a portable power option. Check every device's rated wattage, the combined load and the product's operating-temperature requirements before use.
1800W Powerful Output: 3600W surge output. With X-Boost™ tech, it supports high-demand devices up to 2600W, such as microwaves, refrigerators, laptops, and heated blankets.
For compatible loads requiring more capacity, the EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) is another option. Runtime depends on the actual load, battery state, temperature and conversion losses rather than capacity alone.
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Keep the unit within its manual’s environmental limits and do not treat portable battery power as a substitute for a winter-rated trailer heating system.
Clean and Protect the Interior
Take out everything that can freeze or attract pests, from the food and drinks to the bottles people forget under the sink. Empty and clean the fridge, then prop the doors open a crack so it doesn’t grow mould. Stand the cushions on edge and tip the mattress up so air can move underneath.
EcoFlow DELTA 3 Classic Portable Power StationEcoFlow DELTA 3 Classic Portable Power Station
How to Store a Trailer Through a Canadian Winter
Once the plumbing is protected, prepare the trailer for the storage location, tires, moisture and pests. Storage is different from winter RV living, where occupied systems remain active and require ongoing heat, water and ventilation management. Outdoor storage needs regular inspection because snow, ice and moisture conditions change through the season.
Choose a Suitable Winter Storage Location
Indoor storage can reduce exposure to snow and ultraviolet light, but the site must still meet ventilation and access needs. For outdoor storage, choose firm, well-drained ground away from overhanging branches. Level and support the trailer according to its manual; do not change its storage angle unless the manufacturer recommends it for drainage. If a power station will be stored separately, follow its manual for charge level, temperature and maintenance intervals.
Protect Tires and Exterior Components
Tires age even when the trailer isn't going anywhere. UV and ozone do the work, and the result is dry rot in the sidewall.
  • Tire Isolation: Set the tires on wide planks, patio stones, or rubber stall mats so the rubber isn't touching bare ground.
  • Inflation: Set cold tire pressure to the trailer or tire manufacturer's storage recommendation and recheck it periodically. Do not substitute the sidewall maximum for the specified operating or storage pressure.
  • Tire Covers: Strap UV-resistant covers over the wheels to keep sun and blowing slush off the rubber.
  • Jack Lubrication: Coat the tongue jack threads and the stabilizer pivots with silicone spray or marine grease so they don't rust and seize.
Manage Moisture and Prevent Pests
Use moisture control that suits the trailer’s size, ventilation and storage conditions, and inspect it at intervals recommended for the product. Remove food and nesting material, then seal accessible entry points with materials suitable for the surrounding wiring, plumbing and structure. Follow local pest-control guidance and check traps or monitoring devices regularly.
Winterizing before the cold arrives can reduce the risk of split lines, cracked fittings and avoidable spring repairs. Before you walk away, do a last pass over the drains, seals, tires, and interior, and check your owner’s manual for anything specific to your model. Come spring, flush the system and give the trailer a once-over before the first trip, which for a lot of owners is the May long weekend. Careful fall preparation can make the first spring trip easier to start.
Can You Winterize Your Own Trailer?
Yes. Most owners can do it themselves with basic tools and not much mechanical experience. You’ll need RV antifreeze, a wrench or socket that fits the water heater drain plug, and either a blowout adapter for a compressor or a winterizing kit for the pump.
How Long Does It Take to Winterize a Trailer?
The time required depends on trailer size, plumbing layout, installed appliances and whether inspection and cleaning are included. Allow extra time on the first attempt and stop to consult the manual whenever a valve, drain or bypass arrangement is unclear.
How Much Does It Cost to Winterize a Trailer in Canada?
Cost varies with trailer size, required antifreeze, tools, replacement sealants and local service rates. Price the materials specified for the model and request a current written quote if a dealer or mobile RV technician will perform the work.
Should I Cover My Trailer in the Winter?
Use a cover only when it is compatible with the trailer, storage site and manufacturer’s instructions. A purpose-built breathable RV cover may reduce weather and UV exposure, while an unsuitable tarp can trap moisture or abrade the exterior. Secure any approved cover without blocking required ventilation.
Can You Live in a Trailer All Winter?
You can, but not in a three-season trailer the way it came from the factory. A Canadian winter takes real modifications and constant attention: insulated skirting around the base, heated freshwater hoses, thermal window coverings inside, a dehumidifier to keep up with the condensation from cooking and breathing, and a heating setup you can count on, with backup power behind it.
