French Beach Camping: Portable Power Tips for Coastal Campers with EcoFlow
French Beach is about an hour from Victoria, and it’s worth the drive. The 1,600-metre sand and pebble beach backs up against second-growth forest, the Strait of Juan de Fuca stretches out in front of you, and on a clear day, you can see the Olympic Mountains across the water.
It's an incredible campground, but it has zero electrical hookups, generator restrictions at most sites, and it's far enough from the nearest town that you can't easily run back for anything you forgot. If power isn't part of your planning, you'll feel it.
Here’s how to include thoughtful power planning for a comfortable and convenient trip.
Why Is French Beach a Popular Camping Destination?
French Beach Provincial Park has been part of BC's provincial system since 1974 and covers 59 hectares on the Strait of Juan de Fuca. Its 69 campsites sit in gorgeous forest a short walk from the beach, with a grassy day-use area, playground, and accessible trails rounding out the facilities. Reservations open from May through September.
The wildlife is also a draw. Gray whales migrate north past the park each spring and return south in the fall, but that’s not all. Resident orca pods, sea lions, seals, otters, bald eagles, and ospreys are all regular sightings offshore.
The beach itself is open all year, making it one of the few provincial parks that remains accessible even in winter. Full services run from May to October, so that’s the time to camp.
After that, water and sanitation shut off, rates drop, and the park quiets down considerably. Storm watchers and anyone who'd rather skip the summer crowds especially appreciate this off-season time.
What Power Challenges Do Coastal Campers Face?
Every campsite at French Beach has a gravel pad, fire pit, and picnic table, but that’s it. Without electrical hookups and with generator use strictly limited to specific hours at accessible sites only, power can become a problem.
On top of that, the coastal environment’s salt air can corrode batteries and cause electronics to drain faster than you might expect. Pacific sea fog and overcast skies limit solar generation, and chilly winds and temperatures can encourage campers to bring heated gear, which draws even more power.
The nearest town of Sooke is more than 20km away, so there’s no convenient fallback if your power falls short.
Preparation is truly make or break.
Why Is Portable Power Essential for French Beach Camping?
A portable power station is the most practical answer when there's no campsite power and traditional generators aren't a reliable option due to limited hours.
The EcoFlow DELTA 3 Classic suits this kind of trip well. It holds 1,024 Wh, puts out 1,800W, and charges from flat to 80% in 45 minutes at home before you leave. Internally, the LFP battery chemistry holds up better than standard lithium-ion in humid, temperature-variable conditions (which describes French Beach most of the year).
Because it’s not a normal generator, it’s not beholden to the standard restrictions and timing.
And when it is running, it sits around 30 dB under light load, quiet enough that neighbouring campsites won't notice it's on.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
What Devices Should You Power While Camping?
While your whole-home backup power handles everything without your intervention, power while camping requires a bit more thought.
Start by figuring out what you can’t do without, and then scale up from there using the capacity and output available.
At French Beach, the list of essentials usually includes phones, navigation devices like GPS, lighting, and a cooler.
Phones and Navigation Devices
Cellphone service along the Highway 14 corridor (on the way to French Beach) is unreliable at best, so you’ll want to have a charged phone with offline maps loaded rather than rely on data in the moment.
Once you’re there, GPS devices, weather radios, and GoPro cameras all draw a modest wattage and can run comfortably off a well-sized power station for a few nights.
Lighting and Campsite Gear
LED camp lanterns typically draw 5–15W. Run one all evening, and you've barely touched the station. A rechargeable lantern at the picnic table does a better job than a headlamp for camp tasks, and it saves the headlamp for trail use. A USB fan draws very little and makes a tent noticeably more comfortable on warmer nights.
Coolers and Comfort Devices
A portable electric cooler averages around 40–60W and keeps food safe across multiple nights, much better than ice bags in coastal humidity. A heated blanket or vest handles cool evenings without the fuel management of a propane heater, and as a bonus, they're quieter.
Before you pack, check off a solid camping checklist to make sure you’re accounting for everything that will draw power from your PPS.
How Do You Set Up Portable Power at the Beach?
Make sure you have your camping portable power station packed before you head for the beach. Once there, use these tips and instructions to get set up.
  1. Charge before you leave. There’s no way to top up once you get there unless you have solar panels and get lucky with the weather.
  2. Keep the station somewhere protected, like inside your tent or in a weatherproof bag, to avoid salt spray and overnight condensation.
  3. When solar charging, angle the panels south and keep them out of the wind. Expect variable output in a cloudy area like French Beach.
Can You Camp at French Beach Year-Round?
French Beach stays open for vehicle camping through winter, which isn't common among BC provincial parks. Full services are available roughly May through October. In winter, those shut off, fees drop, and campers need to be self-sufficient. Highway 14 conditions can be variable in colder months, so check before heading out.
What Power Do You Need for Beach Camping?
For a 2 to 3-night trip, around 1,000 Wh covers phones, LED lighting, and a small cooler without much stress. If you’re adding heated devices, a cooler, or have multiple people using the same station, step up your capacity. Treat car charging as a backup, not your plan.
An An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
Portable Power Makes Coastal Camping More Comfortable and Reliable
French Beach is worth the trip despite the lack of electrical hookups, because a fully charged power station can resolve the issue entirely.
You don’t have to cut the trip short or leave gear behind.
Bring the EcoFlow DELTA 3 Classic to handle your camping essentials. Charge it before you leave, and the beach will handle the rest!
Camping
