Best Solar Powered Generators 2025: Top Choices & Buying Guide
Canada’s growing commitment to renewable energy makes it an ideal environment to explore solar power solutions. With electricity prices on the rise and sustainability taking centre stage, solar powered generators are becoming a practical choice for households, campers, and emergency preparedness alike.
In this guide, we’ll highlight the best solar powered generators of 2025, focusing on models that balance efficiency, portability, and long-term reliability. We’ll also break down the most important factors to consider before making your investment. If you’re ready to reduce dependence on the grid and embrace clean energy, let’s dive into the details now!
Best Solar-Powered Generators in 2025
Here we look at the best solar powered generators for home use or businesses in 2025. Whether you are planning for outdoor adventures or preparing for potential malfunctioning of the grid, these models will offer outstanding value.
EcoFlow DELTA 2 Max Solar Generator (PV220W)
The EcoFlow DELTA 2 Max Solar Generator (PV220W) is a versatile choice for those who want a compact yet expandable solar generator.
With 1 to 4x220V portable solar panels and long-lasting LFP batteries, this powerful portable power station system offers 2–6kWh capacity, making it a reliable backup power source for families, campers, and anyone seeking reliable off-grid power
Key Features:
  • Expandable capacity from 2–6kWh to meet changing energy needs
  • Built to last with LFP battery chemistry, offering 3000+ cycles (about 10 years of daily use)
  • Ultra-fast AC recharging and X-Stream dual AC + Solar charging
  • Supports up to 1000W solar input, recharging in as little as 2.3 hours
  • Smart in-app energy management for real-time monitoring and customization
Ideal for:
  • Families needing a reliable backup solution during a power outage
  • Outdoor enthusiasts who want portable, eco-friendly energy
EcoFlow DELTA 2 Max solar generator
EcoFlow DELTA 3 Plus Solar Generator (PV160W)
The EcoFlow DELTA 3 Plus Solar Generator (PV160W) brings robust performance with expandable capacity up to 5kWh and 2200W AC output. Combined with EcoFlow’s high-efficiency bifacial solar panels, it ensures fast charging and enough power to handle almost all household appliances. As one of the best small solar powered generators, it is perfect for those who value portability with power.
Key Features:
  • Expandable storage up to 5kWh for flexible use
  • 2200W output power with X-Boost, running 99% of home appliances
  • Quick solar charging to stay ready in emergencies
  • Lightweight and portable for versatile deployment
Ideal for:
  • Renters or condo dwellers who need portable power backup
  • Outdoor adventurers requiring reliable solar charging for trips
EcoFlow DELTA 3 Plus solar generator
The EcoFlow DELTA Pro 3 Solar Generator (PV400W) is a flagship generator that balances portability with powerful performance. Supporting up to 2600W solar input and expandable to 12kWh capacity, it’s ideal for those who need a dependable, scalable option. With app-based smart controls, managing power has never been more convenient.
Key Features:
  • Expandable capacity up to 48kWh for flexible storage
  • Dual PV ports supporting high-voltage and low-voltage options
  • 2600W solar input for rapid charging
  • Durable LFP battery chemistry ensures long-lasting performance
  • Smart EcoFlow app control for tailored energy management
Ideal for:
  • Tech-savvy homeowners looking for a flexible solar solution
  • Remote workers powering equipment in off-grid locations
EcoFlow DELTA Pro 3 solar generator
The EcoFlow DELTA Pro Solar Generator (PV400W) is a powerful and reliable home backup solution designed to keep your household running smoothly during power outages. With ultra-fast solar charging, robust AC output, and durable weather resistance, it’s the perfect balance of energy independence and convenience.
Key Features:
  • Generates up to 9.3kWh daily with 3×400W portable solar panels.
  • Delivers 4500W AC output with X-Boost for heavy-duty appliances.
  • 23% solar conversion efficiency, recharging in as fast as 3.5 hours.
  • IP68 dust and water resistance for outdoor reliability.
  • Smart remote control via the EcoFlow app for easy monitoring.
Ideal For:
  • Homeowners needing reliable blackout protection
  • Off-grid living enthusiasts, RV and camping users
  • Professionals requiring portable yet powerful energy backup.
EcoFlow Delta Pro solar generator
What to Look for When Choosing the Best Solar-Powered Generator
Still wondering which solar generator is right for your needs? Choosing the best solar-powered generator requires balancing power, capacity, and versatility to ensure your home or lifestyle runs smoothly during outages or off-grid living. Here are the key factors to consider:
Power Output and Capacity
Look at both wattage and storage. Smaller units of 1-4kWh are ideal for camping or short outages, while for whole-home coverage, options like the EcoFlow DELTA Pro Ultra Whole-Home Backup Power stand out. By pairing the DELTA Pro Ultra with EcoFlow’s Transfer Switch, it provides households with a complete, reliable backup solution, capable of powering everything from central AC to refrigerators. With up to 21.6kW output and a 90kWh capacity, it’s a long-term solution for any home.
Take control of your energy future with the EcoFlow DELTA Pro Ultra Whole-Home Backup Power. With up to 90kWh capacity and 21.6kW output, it keeps your home powered during outages, supports central AC, and ensures reliable and efficient energy independence in Canada.
Charging Flexibility
The best solar-powered generators should support multiple charging methods, from solar panels to gas or standard outlets. This ensures power reliability even in bad weather.
Battery Chemistry and Lifespan
Lithium iron phosphate (LFP) batteries stand out for safety and durability, offering thousands of cycles. This translates into years of dependable use without the performance degradation common in older battery types.
Portability and Smart Features
A good solar generator balances power with usability. Compact design, wheeled units, and app-based monitoring all contribute to flexibility, whether you’re travelling, working remotely, or simply storing it at home.
Integration with Smart Panels
A generator’s performance improves dramatically when paired with intelligent control. The EcoFlow Smart Home Panel 2 enables auto-switchover during outages and optimizes energy usage based on time-of-use rates. This not only extends backup duration but also helps reduce your utility bills.
Durability and Safety
Look for UL-certified systems and features like self-heating batteries for cold climates. Reliability is essential when powering critical appliances.
The best solar powered generators in 2025 blend multiple advantages, such as large capacity and output, smart app control, and fast charging. The 4 models we recommended above, as we have seen, each bring something different to the table depending on your needs. From compact and portable designs perfect for camping, to powerful whole-home backup systems for long outages, there is a solution for every situation.
If you are considering going solar this year, it’s best to start now. Keep in mind that many solar battery rebates and incentives are currently available in Canada, making it easier and more affordable to invest in clean energy.
What brand of solar generator is the best?
While the best brand depends on your specific needs, EcoFlow is widely recognized as one of the leading solar generator manufacturers in 2025. Known for innovation and reliability, EcoFlow’s DELTA series offers models that balance portability, scalability, and performance. Options like the DELTA 2 Max and DELTA Pro 3 provide expandable storage, fast solar input, and smart app control, making them suitable for everything from camping trips to whole-home backup. Their use of long-lasting LFP batteries further enhances safety and durability, making EcoFlow a trusted choice among solar enthusiasts across Canada and beyond.
Are solar power generators worth it?
Yes, solar power generators are definitely worth it for many households and outdoor users. They provide clean, renewable energy without the noise or fumes of gas-powered generators, and they reduce long-term energy costs. Key benefits include:
  • Sustainable and eco-friendly operation
  • Low maintenance with no fuel costs
  • Portable and versatile for different environments
  • Reliable backup power during outages
  • Expandable capacity for long-term flexibility
By combining affordability, convenience, and sustainability, solar generators prove to be a smart investment for anyone seeking reliable, off-grid power solutions in 2025.
What size solar generator will run a house?
Running an entire house requires a solar generator with significant capacity and output. Typically, you’ll need at least a 5000–7000W unit with expandable battery storage between 10–20kWh or more, depending on your household’s energy demand. For extended outages or full energy independence, models like the EcoFlow DELTA Pro Ultra, which scales up to 90kWh and delivers over 20kW output, are well-suited. Smaller portable generators can keep essentials like lights, laptops, and refrigerators running, but only whole-home backup systems can reliably power large appliances such as central air conditioning, washers, dryers, and electric stoves.
What will a 3000 watt solar generator run?
A 3000W solar generator is powerful enough to support most everyday essentials during a blackout or outdoor trip. With proper storage capacity, it can comfortably run refrigerators, freezers, laptops, televisions, lights, and routers. It can also power smaller appliances like coffee makers, microwaves, and medical devices such as CPAP machines.
However, it may struggle with larger appliances that require more surge wattage, such as electric ovens or central air units. For households that need to maintain the continuous operation of multiple heavy-duty appliances, a higher-output model or expandable solar generator system would be a better fit.
