EcoFlow RIVER 3 Series
Start Small, Power Strong
The ideal starter battery for backup power and outdoor use, that's compact yet powerful in performance.
  • RIVER 3 Max Plus
    858Wh Capacity | 600W Output | 1200W X-Boost
    • <10 ms UPS
    • Up to 2x runtime for light-wattage appliances1
    • Removable Smart Extra Battery
  • RIVER 3 Plus
    286Wh Capacity | 600W Output|1200W X-Boost
    • <10 ms UPS
    • Up to 2× runtime for light-wattage appliances1
    • Expands up to 858Wh
  • RIVER 3 Max
    572Wh Capacity | 600W Output |1200W X-Boost
    • <10 ms UPS
  • RIVER 3 Max Plus
  • RIVER 3 Plus
  • RIVER 3 Max
RIVER 3 Plus: 600W power station | X-Boost to 1200W
RIVER 3: 300W power station | X-Boost to 600W
Seamless home office and gaming experience
<10 ms UPS solution for precision devices
The RIVER 3 Series offers a top-tier UPS solution designed for precision devices with quick <10 ms auto-transfer, robust power output, smart outage alert, and UPS-friendly design, ensuring easy and reliable backup.
<10 ms pro-grade auto-switch
The RIVER 3 Series provides premium protection with a <10 ms switchover, safeguarding sensitive equipment from sudden power loss.
  • Fridge
  • Desktop
  • NAS
  • Wi-Fi Router
  • Gaming Console
Comprehensive UPS solution
Smart data protection
Learn More
Safeguard for work and play
UPS-friendly design
Learn More
UPS-friendly design
Learn More
UPS-friendly design
  • Smart data protection
  • Safeguard for work and play
  • UPS-friendly design
With our specially designed UPS manager software Power Manager, connect RIVER 3 Plus to your PC or NAS via a USB-B port, to view its status and outage time logs. Plus, the software notifies you when RIVER 3 Plus is running low, prompting devices to save data and initiates an automatic shutdown.
Easily handle power outages and extend outdoor stays
Compact design, longer runtime
With groundbreaking X-GaNPower, the RIVER 3 Series taps into superior energy efficiency to extend the operating time of low-wattage devices in a compact design and with a quieter running volume.
Up to 2× light and network runtime
The RIVER 3 Series revolutionizes energy efficiency, delivering up to double runtime for light-wattage appliances, extending use at home and in the great outdoors.1
2× runtime for a 3W light or Wi-Fi router
  • 16.1 hr
    Industry Standard (245Wh)
  • 30.8 hr
    RIVER 3 (245Wh)
  • 35.0 hr
    RIVER 3 Plus (286Wh)
30%
smaller than the industry average
30%
30%
30%
Expandable up to 858Wh with wireless connectivity
Level up your power with the RIVER 3 Plus and an Extra Battery. Handling either the EB300 (286Wh) or the EB600 (572Wh), just stack them to get up to 858Wh of pure energy.
  • RIVER 3 Plus
    • NAS Server (40W)
      5.2 hr
    • Car Fridge (60W)
      3.6 hr
    • Game Console (100W)
      2.2 hr
    • Refrigerator (400W)
      31 min
    • Desktop (600W)
      21 min
    • Small Electric Kettle (900W)
      21 min
  • RIVER 3 Max
    RIVER 3 Plus + Extra Battery EB300 (286Wh)
    • NAS Server (40W)
      10.4 hr
    • Car Fridge (60W)
      7.2 hr
      4.4 hr
      1 hr
    • Desktop (600W)
      42 min
      42 min
  • RIVER 3 Max Plus
    RIVER 3 Plus + Extra Battery EB600 (572Wh)
    • NAS Server (40W)
      15.6 hr
    • Car Fridge (60W)
      10.8 hr
      6.6 hr
      1.6 hr
    • Desktop (600W)
      1 hr
      1 hr
  • 286Wh
  • 572Wh
  • 858Wh
Hassle-free connection
Utilizing Pogo Pin tech, the batteries connect wirelessly, fastening easily with clips instead of cables or screws.
Adds an extra charging and recharging option
Add an extra battery to your RIVER 3 Plus for 140W USB-C charging and recharging, plus the freedom to use it on its own.3
Quickly prepare for power outages and outdoor trips
AC charging
Solar charging
Car charging
Generator charging
AC charging
Solar charging
Car charging
Generator charging
AC charging
Solar charging
Car charging
Generator charging
  • AC charging
  • Solar charging
  • Car charging
  • Generator charging
RIVER 3 Series fast-charges in 1 hour with X-Stream, no battery damage with vehicle-grade cells and trickle charge technology.
RIVER 3 Series has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 Series protects against various current, voltage, temperature, and circuit risks.
With IP54 battery protection, water damage is minimized4. Its robust fire-retardant shell survives rough conditions. Even after a 3.3 ft fall, the RIVER 3 Series won't get damaged.
  • Monitoring
    Enhanced with our upgraded app and a vibrant color display, RIVER 3 Plus offers advanced charging status and battery health insights.
  • Custom settings
    Tailored for personal use, the upgraded app offers versatile charging settings, including speed control, timed charging, power-saving mode, and low-battery alerts.
  • Remote control
    Connect seamlessly with Bluetooth and Wi-Fi. Remote control your unit via a Wi-Fi connection when you're not at home.
3 million families worldwide trust our Simple, Flexible and Reliable power solutions. Discover EcoFlow's latest technologies that will Power a New World.
What's in the box?
  • EcoFlow RIVER 3 Portable Power Station
  • AC Charging Cable
    AC Charging Cable
  • Quick Start Guide and Warranty
    Footnotes:
    All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment and actual user experience may vary. 1. The runtime is based on laboratory tests conducted with common household appliances under normal room temperature conditions. The "double runtime" claim specifically refers to tests using a 3W light or Wi-Fi router. 2. The noise level data is based on laboratory tests conducted at a room temperature of 89.6°F (32°C). Actual use may have slight deviations due to variations in the real environment and the adding of RIVER 3 Plus Smart Extra Battery. 3. The input and output wattage of the Smart Extra Battery will decrease to 100W when environment temperatue is higher than 95°F (35°C). 4. The IP54 water-proof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection Terms and conditions apply. During the promotional period from Dec 6-27, 2024 (PT), you will receive the following benefits with an eligible order: Benefit 1: 30% off EcoFlow RIVER 3 Plus Benefit 2: A free EcoFlow 45W Portable Solar panel (worth $99) with EcoFlow RIVER 3 Plus, RIVER 3 Max and RIVER 3 Max Plus standalone unit (This offer does not apply to the RIVER 3 series bundle). EcoFlow reserves the right to cancel the benefits and any associated orders at any time in cases of dishonesty, fraud, or violation of these terms. When applying for a return and refund, customers must return the accompanying gift (EcoFlow 45W Portable Solar panel) as well or the corresponding amount will be deducted from the refund at the retail price.
    title
    DELTA Pro 3 can run a well pump in an emergency. I am ecstatic that my pressure washer works with the DP3. I absolutely adore the amazing design and game-changing quiet fans.
    Luke L., Monticello, IL
    title
    Off Grid Stackable Solar Battery - So easy its *Almost* Cheating...
