DELTA
DELTA
You're In Charge
1800W
400W max
400W max
AC Fast Input
1,6h
AC Fast Input
BMS
BMS
1.2kWh Capacity
1.2kWh Capacity
Never lose power again.
Stay in charge of any situation with the EcoFlow DELTA. A single unit packs a 1.2kWh capacity, perfect for powering mutiple essentials devices for hours on end during a blackout.
*For DELTA 1000, the capacity of a single unit is 1kWh
Appliances that
Power almost anything
  • Light
    Light
    • 30   Hrs
  • Refrigerator
    Refrigerator
    • 6,3-12,6   Hrs
  • Microwave
    Microwave
    • 0,9   Hrs
  • Washer
    Washer
    • 2,1   Hrs
  • Electric Frying Pan
    Electric Frying Pan
    • 0,9   Hrs
  • 50" TV
    50" TV
    • 13   Hrs
  • Hair Dryer
    Hair Dryer
    • 0,7   Hrs
  • Coffee Maker
    Coffee Maker
    • 1,1   Hrs
1800W AC Output
Maximum power,
minimum fuss.
Power 90% of essential devices.
Need power for the whole family? No problem. DELTA can power up to 13 devices at the same time.
*The AC output of DELTA 1000 is 1600W.
Charging up just got faster.
DELTA charges up from 0-80% with X-Stream — the world's fastest portable power station charging technology. Going off-grid? Connect up to three 160W solar panels to charge up as quick as 3.5 hours. ** And when you're ready to hit the road, charge DELTA with your car outlet.
  • 3,5Hrs**Solar charging
  • 1,6Hrs0-80% capacitys
**Solar charging time ranges from 3.5-7 hours depending on sunlight conditions.
Never get caught in the dark
Stay powered on quicker than a blink of an eye. When used as an emergency power source during a blackout, DELTA kicks in automatically and provides you with power in less than 30 milliseconds**
**Requires DELTA to be in standby mode.
Pure power with no compromise
Unlike a traditional gas generator, DELTA operates with next to no noise, no fumes, and no maintenance. Our battery management system has a proven track record in challenging environments, regulating current, voltage, and temperature in real time.
    You might also like
    View more
    • EcoFlow
