15 Must-Have Caravan Accessories for Every Traveller
Exploring the Garden Route or the Kruger bushveld often leads travellers to remote spots where power outlets are not available for many kilometres. In places like Tsitsikamma, a fridge that stops running or a phone that loses its charge can create complications, just as being stuck in the Namaqualand sand with a flat tyre causes a major headache.
These common hurdles show that even the most beautiful trip across Mzansi can become difficult without proper preparation. Because these situations happen often on local roads, having the right RV accessories is a practical way to manage unreliable power, cramped living, and unexpected breakdowns. In this guide, you can discover 15 must-have caravan accessories, along with luxury upgrades that help every trip feel more comfortable.
Essential Caravan Accessories for South Africa
These practical caravan accessories tackle the most common road trip headaches—uneven parking, getting stuck, water safety, and more. Tested across South Africa's rugged terrains from coastal dunes to Karoo gravel.
1. Levelling Blocks
Nothing ruins a good campsite faster than a tilting caravan that makes you seasick inside. Levelling blocks ensure stability on uneven ground, protecting appliances and preventing that nauseating wobble. Choose heavy-duty, stackable blocks with high weight capacity (over 5 tons) and non-slip surfaces. They're a 30-second fix that transforms every parking spot into a level home base.
2. Recovery Tracks
South Africa's sandy beaches and desert tracks like Namaqualand can trap any 4x4 caravan setup. MAXTRAX-style recovery tracks give your tyres instant grip to self-extract from sand, mud, or gravel without calling for help. Look for lightweight, durable pairs (under 5kg each) with aggressive tread patterns and lifetime warranties. Every overlander swears by them—one pair has saved me three times.
3. Water Filter System
Remote South African campsites often have questionable water sources. A portable water filter removes bacteria, chemicals, and sediment, preventing traveller's diarrhoea on long trips. Opt for gravity-fed systems like Sawyer or Katadyn with 0.1-micron pores that filter 100,000+ litres. Pair with collapsible 10L jerry cans for easy refills—your health insurance for bushveld adventures.
4. Reverse Camera System
Backing a caravan into tight campsites with an audience watching is pure stress. Wireless reverse cameras with wide-angle lenses and night vision eliminate blind spots, making parking foolproof even solo. Choose IP68 waterproof models with stable 5GHz WiFi signal and caravan-specific mounting brackets. It's embarrassing not to have one in 2026.
5. Tyre Pressure Gauge & Deflator
Varying South African terrains demand different tyre pressures—low for sand, high for tar. Accurate digital gauges with bleed valves let you adjust on the fly for optimal traction and fuel efficiency. Get 4x4-specific kits with automatic deflators that preset pressures (18-35psi range). Flats in remote areas are unforgiving; proper pressure is your first defence.
6. Comprehensive First Aid Kit
South Africa's wildlife and rugged trails mean snake bites, coral cuts, and sprains happen. Build a caravan-specific kit with compression bandages, antihistamines, rehydration salts, and a snake bite pressure immobilisation bandage. Add personal meds, burn gel for cooking mishaps, and trauma shears. Check expiry dates monthly—it's your lifeline when clinics are hours away.
7. Quality Awning
South African sun and showers demand a shaded outdoor living space. A 2.5-3.5m freestanding awning expands your caravan footprint for dining and lounging. Choose UV50+ blockout fabric, wind-rated aluminium arms, and quick-release wall brackets. Pair with LED light strips for evening use. It turns campsite cooking into resort dining.
8. Outdoor Mats (Turf Mats)
Keep sand, dust and mud outside by laying heavy-duty turf mats to define your outdoor kitchen area. Choose 3 x 4 m reversible mats with turf on one side and carpet on the other, brass eyelets for pegging, and a hose-cleanable, UV-stabilised finish. They trap red bush dirt and fine coastal sand while remaining comfortable to walk on barefoot, and quickly pay for themselves by cutting down on interior vacuuming.
Off-Grid Power Essentials for Caravan Travel
After covering the basics, power becomes the make-or-break factor for extended South African caravan trips. Campsites run out of power, generators are noisy, and phone batteries die at the worst moments. These caravan accessories create a complete off-grid energy system.
9. Portable Power Stations
No caravan traveller should be without a portable power station, as it serves as a reliable electricity hub when hookups are not available. These silent units provide power for fridges, lights, fans, and chargers through multiple AC and DC outlets.
For example, the EcoFlow DELTA 2 Max Portable Power Station pairs a LiFePO4 battery with expandable storage and multiple output options, making it practical for extended caravan trips. It supports high-draw appliances, provides app-based monitoring and control, and its combination of capacity and portability suits both short outings and longer off-grid stretches.
10. Alternator Chargers
Driving long distances between Kruger and the Garden Route often means hours on the road before reaching your next campsite. The EcoFlow 800W Alternator Charger transforms that drive time into productive charging time. Instead of arriving at camp with half-drained batteries, you arrive fully powered. This charger refills your power station significantly faster than standard vehicle outlets while you are behind the wheel, which removes the need for engine idling or using noisy generators once you have parked.
11. Portable Solar Panels
South Africa enjoys over 2,500 hours of sunshine annually — making solar one of the smartest caravan upgrades you can make. The EcoFlow 110W Portable Solar Panel allows you to turn natural light into energy for your gear, helping you stay away from noisy generators and reducing how much fuel you need to carry for the trip. Since the unit is light and folds up easily, you can pack it on your roof rack or set it up right next to your awning once you reach your campsite.
With its IP68 rating, the panel is built to handle dust and rain while it charges your power station during a stay in the Karoo or at a coastal camp. When you pair it with the DELTA 2 Max, you create a quiet system that collects power during the day so that you have electricity available after the sun goes down. For those exploring the different landscapes of Mzansi, this solar setup offers a reliable way to maintain power while staying off the grid.
Luxury Caravan Accessories for Comfort
With essentials covered, these RV accessories add comfort and joy that turn good trips into unforgettable ones. They're worth the investment for frequent travellers.
12. Mattress Topper & Bedding
Caravan mattresses are notoriously thin and uncomfortable. A memory foam topper (5-8cm thick) plus breathable cotton sheets transform your sleeping area into hotel quality. Choose vacuum-compressible options for storage and anti-slip bases to prevent sliding. Add cooling gel-infused toppers for hot South African nights. Wake up refreshed, not sore.
13. Outdoor Dining Set
Ditch flimsy camp chairs for padded recliners with cup holders and side tables, paired with a lightweight aluminium table. Weather-resistant fabrics and sturdy frames handle coastal winds and Kruger rains. Look for sets under 15kg total that pack into dedicated bags. Starlit dinners become the highlight of every evening.
14. Smart Storage Solutions
Transform cramped quarters into cosy living spaces with smart storage hacks, mood lighting, and privacy screens. Learn how to make your caravan more like home with practical upgrades like collapsible furniture, magnetic spice racks, and under-bed storage drawers. These touches make weeks on the road feel sustainable and inviting.
15. Starlink Internet Kit
Remote work or streaming in Namaqualand? Compact Starlink kits deliver 100-200Mbps anywhere with a clear sky view. Low-power draw (40-100W) pairs perfectly with solar setups, and the detachable dish stores easily. Forget dead zones—stay connected from beach camps to mountain passes. Essential for modern nomads.
Upgrade your journeys with these must-have caravan accessories that blend practicality and comfort. From power solutions to luxury touches, the right caravan gear ensures every trip—coastal or outback—feels effortless and enjoyable. Pack smart, travel happy, and make unforgettable memories on South Africa's open roads!
What is the 28 day rule for caravans?
In South Africa, the 28-day rule typically refers to the billing and booking cycles used by many local caravan parks, such as those managed by the Knysna Municipality. While long-stay options exist, many parks operate on a 28-day (four-week) cycle for their monthly rates.
What is a good gift for someone who lives in a caravan?
Braai Accessories: A high-quality braai grid cover or heavy-duty tongs are essentials for any Mzansi campsite.
Compact Kitchenware: Collapsible basins, silicone kettles, or a 12V pressure cooker help save valuable cupboard space.
Portable Lighting: Solar-powered lanterns or high-lumen headlamps are perfect for those nights in the bush.
Power Solutions: For a bigger gesture, a portable power station like an EcoFlow unit is a game-changer for staying powered during load shedding or off-grid stays.
Personalised Gear: Custom caravan signs or durable outdoor mats to keep the Karoo dust out of the living area.
How to accessorise a caravan?
Accessorise systematically: first install levelling blocks, water filters, and recovery tracks for basic functionality. Add power solutions like portable stations and solar panels for off-grid reliability. Enhance comfort with mattress toppers, quality bedding, and awnings for outdoor living. Safety gear includes first aid kits, fire extinguishers, and reverse cameras. Organise with collapsible storage and magnetic organisers. Match accessories to terrain—more recovery gear for off-road, solar emphasis for sunny regions. Choose lightweight, pack-flat items with multi-use functionality to maximise limited caravan storage while minimising weight for better towing efficiency.
