Lion's Head Hike Guide: Distance, Difficulty and Trail Tips
The Lion's Head hike is a free, roughly 5–5.5 km return trail that takes 2–3 hours and reaches a 669 m summit overlooking Table Mountain and Cape Town's Atlantic coast. Starting from Signal Hill Road, the moderately challenging route includes steep rocks and a choice between chains and a longer bypass near the top. This guide covers parking, trail options, the best time to go and the essentials to bring for a safer hike.
Key Takeaway
Parking near the Signal Hill Road trailhead fills quickly around sunrise, sunset and full-moon hikes. Arrive early or arrange a drop-off.
The alternative summit path avoids the steepest chains and staples, but ladders, uneven rocks and exposed sections may still require care.
The standard self-guided hike is free, and there are no water refill points along the route.
Check the weather and SANParks trail notices before setting off. Daylight hiking is the safer option, especially for first-timers.
Lion's Head Hike at a Glance
Here are the key facts in one place:
Detail | What to Expect |
Summit Height | 669m above sea level |
Distance | About 2 km one way; recorded return routes often cover roughly 5–5.5 km |
Elevation Gain | Approximately 350–400 m, depending on the starting point and route |
Hiking Time | 1 to 1.5 hours up; 2 to 3 hours return |
Difficulty | Moderate overall, with steep rocks and some scrambling near the summit |
Entry Fee | Free, no permit needed |
Start Point | Signal Hill Road trailhead |
Water on Route | None, so bring your own |
Dogs | Not recommended |
Lion's Head Hike Route to the Summit
The standard Lion's Head summit trail winds around the mountain before the steeper climb towards the top. Higher up, the route splits between a direct chains section and a longer bypass, giving hikers two options for the final ascent.
The Gravel Track and Spiral Path
The route begins on a broad gravel track through fynbos, with views towards Table Mountain and the Atlantic Seaboard. You may also spot paragliders launching from the nearby slopes. As the path curves around Lion's Head, Camps Bay and the Twelve Apostles come into view. The track eventually narrows into a rocky footpath leading towards the upper slopes.
Difficulty: Easy to moderate, with a steady incline that gets steeper as you climb.
Trail conditions: Gravel paths, uneven stone steps and rocky sections.
The Chains Route and Bypass
Near the upper slopes, the trail splits into two options for reaching the summit. Both involve uneven terrain, but the amount of exposed climbing differs.
Chains route: A more direct and challenging option with fixed chains, metal staples and steep rock sections. Best for confident hikers who are comfortable using their hands and feet to climb.
Bypass route: A longer, less technical path that avoids the steepest chains and staples. It suits hikers who prefer less exposed climbing, although the upper trail still includes steep, uneven rocks.
The Final Summit Climb
The final approach involves steep rock steps and exposed sections where careful footing matters. Take your time, particularly when other hikers are descending along the same narrow path.
From the summit, you'll see Table Mountain, the City Bowl and the Atlantic Seaboard stretching out below. On a clear day, Robben Island is visible across Table Bay.
Lion's Head Hike Parking and Starting Point
The usual Lion's Head trailhead is on Signal Hill Road, just off Kloof Nek Road above Cape Town's City Bowl. The parking area is near GPS coordinates -33.93615, 18.39517, although you should follow the current trail signs if access arrangements have changed.
There is limited parking near the entrance, with additional roadside spaces where parking is permitted. The area gets particularly busy on weekends, around sunset and during full-moon hikes. Allow an extra 30–45 minutes to find a space and prepare for the walk.
Other ways to reach the trailhead include:
Uber or Bolt: A convenient choice if you want to avoid parking difficulties. Arrange your return journey in advance, especially for an early or late hike.
MyCiTi bus: Routes 106 and 107 stop at Kloof Nek, about 600–700 m uphill from the usual trailhead. The first buses may be too late for a sunrise summit hike, so check the timetable when planning your trip.
Guided hikes: Some local operators offer transport as part of their hiking packages, which can be useful for first-time visitors.
If you're driving, use marked parking spaces, keep valuables out of sight and leave access clear for other vehicles. Before heading out, check the latest SANParks trail updates for any temporary closures or changes to trail access.
What to Pack for the Climb
A small daypack should cover the essentials for most hikers:
At least 1.5 litres of drinking water per person, with extra water in hot weather
Hiking shoes or trail runners with good grip
A light windbreaker and sun protection
A headlamp if you expect low-light conditions
A fully charged phone and a small power bank
Energy snacks, fruit or biltong
A basic first aid kit and any personal medication
An emergency whistle
Keep your hands free for the steeper rock sections. If you're heading to a campsite after the hike, pack your camping equipment separately so your daypack stays light.
Extra Power for Camping and Road Trips
A charged phone and a small power bank are usually enough for the Lion's Head climb itself. If you're continuing to a campsite or spending the weekend on the road, a portable power station can help keep your equipment running once you're back at your vehicle or settled at camp.
For shorter trips, the EcoFlow RIVER 3 Portable Power Station is a compact option for charging phones, camera batteries and campsite lights. Its portable design suits simple camping setups where you only need power for everyday essentials.
If you're planning a longer camping weekend or travelling with a group, the EcoFlow DELTA 2 Portable Power Station offers more flexibility for a portable fridge, shared device charging and other campsite essentials. You can also recharge it with compatible solar panels during the day, making it useful for longer off-grid trips.
Safety Tips for the Lion's Head Hike
The exposed rocks near Lion's Head's summit can make the descent difficult in strong wind or poor visibility. Good weather and an early enough start make a real difference on this trail:
Hike in a group: Go with a group of four or more where possible, and let someone back home know your route and when you expect to return.
Check the weather: Strong south-easterly winds, rain and low cloud can make the upper rocks slippery or difficult to navigate. Turn back if conditions deteriorate.
Plan for daylight: Sunrise, sunset and full-moon hikes are popular, but the rocky descent becomes riskier in darkness.
Stay on marked trails: Avoid shortcuts and isolated paths. Follow any temporary diversions and take extra care on narrow, exposed sections.
Stay aware of your surroundings: Keep valuables discreet and pay attention to other hikers and activity around the trailhead.
Emergency assistance: Keep the Table Mountain National Park emergency number (086 110 6417) handy in case you need help on the trail.
Before your hike, download the Lion's Head Summit trail map for offline navigation. Make sure you've selected the summit route, as some nearby trails circle the mountain without reaching the top.
The Lion's Head hike offers some of Cape Town's most memorable views, and the climb is manageable for many hikers with reasonable fitness and preparation. The rocky summit approach deserves care, particularly when the weather changes or daylight starts to fade. Once you've explored Lion's Head, there are plenty of other hiking trails across South Africa worth adding to your next outdoor trip.
Is Lion's Head suitable for beginners?
Yes, many reasonably fit beginners can complete the hike in good weather. The upper sections require balance, steady footing and some scrambling. If you're uncomfortable with heights, consider hiking with an experienced group and assess the final climb before attempting the summit.
What is the best time to hike Lion's Head?
A morning start after first light is a good choice on most clear days. You'll avoid the midday heat during Cape Town's warmer months and have plenty of daylight for the descent. Check the wind forecast before heading out.
Do I need a guide to hike Lion's Head?
No, you can hike Lion's Head independently without a guide. However, a local guide can be helpful if you're unfamiliar with the rocky terrain or visiting for the first time. It's also best to go with a group.
How long is the hike to Lion's Head Lookout?
If you mean the summit viewpoint, allow around 1–1.5 hours to reach it from the usual trailhead. The full return hike generally takes 2–3 hours, depending on your pace and how busy the trail is.
Is it better to hike Lion's Head at sunrise or sunset?
Sunrise often brings quieter conditions and soft morning light, but reaching the summit by sunrise usually means climbing in the dark. Sunset offers warm views over the Atlantic, followed by a darker descent. For your first hike, start after daybreak and aim to finish before sunset.
