Camping Fridge Buyer’s Guide: Top Portable Coolers for 2025
A camping fridge is one of the most valuable tools you can bring on an outdoor adventure. Whether you're heading off-grid, embarking on a road trip, or spending a weekend at your favorite campsite, a reliable portable fridge keeps your food fresh and your drinks cold. But with many models on the market, choosing the right one can be difficult.
In this guide, we’ll walk you through what to look for in a camping fridge and recommend the best options for 2025 to help you make the perfect choice for your next trip.
Features to Look for When Buying a Camping Fridge
Choosing the right camping fridge means finding one that matches your storage needs, power setup, and lifestyle. If you’re planning off-grid adventures like Drakensberg camping, having the right features becomes even more important. Here are the key features to look for:
  • Size: Pick a size based on how much food and drink you need to store and how much space you have.
  • Cooling performance: Check the temperature range and cooling speed to ensure reliable performance.
  • Power source: Make sure the fridge supports the power type you’ll be using, whether it’s a 12V car socket, AC outlet, or external battery. Choose a model that suits your trip length and available power.
  • Energy efficiency: An energy-efficient fridge uses less power, looks for features like low-voltage protection and automatic shut-off.
  • Durability: Go for a sturdy build if you'll be camping in rugged environments.
  • Noise level: Choose a model with quiet operation or noise-reducing features if you’ll be sleeping nearby.
  • Extra features: Consider added convenience like digital displays, LED lights, removable baskets, or built-in battery monitors.
5 Best Camping Fridges in 2025
Wondering what is the best camping fridge freezer for your next trip? Here are five models in 2025 that combine performance, durability, and convenience for life on the road.
EcoFlow GLACIER Portable Refrigerator
The EcoFlow GLACIER Portable Refrigerator is one of the best camping fridge South Africa. Beyond cooling, it also functions as a portable power hub, allowing you to charge devices like smartphones and laptops, keeping you connected wherever you go. It also features the industry's first integrated ice maker, with a powerful 120W compressor that can produce 18 ice cubes in only 12 minutes.
Optional wheels and a handle make the EcoFlow GLACIER easy to transport across paths, dirt, or gravel. Once in place, simply detach them and set the fridge on a countertop, car seat, or other compact space.
Storage capacity:
  • Single zone: 38L
  • Dual zone: 36L
Temperature range: –25°C to 10°C
Refrigeration power rating: 120W
Input:
  • AC: 100–240V, 50/60Hz, 180W
  • Car Charging: 96W/192W (12/24V, 8A Max)
  • Solar Charging: 240W (11-60V, 13A Max)
Dimensions: 776 × 385 × 445 mm
Weight: 23 kg
The EcoFlow GLACIER Portable Refrigerator is a versatile 3-in-1 appliance that combines a fridge, freezer, and integrated ice maker into a single unit. With a 38L capacity and dual-zone cooling, it allows independent temperature control from -25°C to 10°C. Its 120W compressor produces 18 ice cubes in just 12 minutes. The unit offers up to 40 hours of wire-free operation with a plug-in 298Wh battery and supports solar charging. Smart app control via Bluetooth and Wi-Fi provides convenient monitoring and adjustments.
SnoMaster SMDZ-LS25
The SnoMaster SMDZ-LS25 is a compact 25.2L camping fridge designed for convenience on the go. Designed for outdoor use, it comes with built-in bottle openers, cupholders, and an LED light for better visibility in low-light conditions. Choose between Turbo or Eco mode to suit your cooling needs, and monitor performance through the digital display.
Storage capacity:
  • Single zone: 25.2L
  • Dual zone: -
Temperature range: –20°C to 10°C
Refrigeration power rating: 45W
Input:
  • AC: 220V, 0.395A
  • DC: 12V, 3.75A
Dimensions: 616 × 382 × 365 mm
Weight: 13.3 kg
NL 35 Legacy Smart Refrigerator & Freezer
The NL 35 Legacy Smart Refrigerator & Freezer is a camping fridge with a stainless steel exterior. Its multi-directional lid and dual faceplate configuration let you adapt the setup to suit your vehicle or campsite layout. It features adjustable plastic latches for secure closure and automatic switching between AC and DC power for seamless use, whether you're plugged in or running off a vehicle.
Storage capacity:
  • Single zone: 37.7L
  • Dual zone: -
Temperature range: –30°C
Refrigeration power rating: -
Input:
  • AC: 100–240V
  • DC: 9.5–31.5V
Dimensions: 669 × 382 × 430 mm
Weight: 21 kg
Nl 35 legacy smart refrigerator & freezerNl 35 legacy smart refrigerator & freezer
FLEX CF55 Camping Fridge-Freezer
The FLEX CF55 Camping Fridge-Freezer features a high-efficiency compressor that delivers rapid cooling while using minimal power. With Bluetooth app control, you can monitor and adjust settings remotely using your smartphone. Designed for rugged conditions, it includes a 3-stage battery protection system, vibration resistance, and can operate safely on inclines up to 45 degrees, ideal for 4WD and off-road use. Built with sturdy plastic, the FLEX CF55 offers both durability and reliability, making it a trusted choice for any outdoor adventure.
Storage capacity:
  • Single zone: 52L
  • Dual zone: -
Temperature range: –20°C to 20°C
Refrigeration power rating: 60W
Input:
  • DC: 12/24V, 2.5A – 5A.
Dimensions: 690 × 345 × 524 mm
Weight: 13.86 kg
Flex cf55 camping fridge freezerFlex cf55 camping fridge freezer
Engel 57 Litre Combi Portable Fridge and Freezer
The Engel 57 Litre Combi Portable Fridge and Freezer stands out with its unique combination of features designed for rugged adventures. It features a dual-compartment layout that functions as both a fridge and freezer, with a thermostatically controlled fan efficiently circulating cold air between sections for consistent cooling. At its core is Engel’s renowned Sawafuji Swing Motor, known for its exceptional reliability and ultra-low power consumption, making it one of the most energy-efficient options on the market.
Storage capacity:
  • Single zone (dual compartment): 57L
  • Dual zone: -
Temperature range: -
Refrigeration power rating: 0.5 – 3.6 Amps
Input:
  • AC: 240V
  • DC: 12/24V
Dimensions: 790 × 490 × 441 mm
Weight: 34 kg
Engel 57 litre combi portable fridge and freezerEngel 57 litre combi portable fridge and freezer
Tips for Using Your Camping Fridge Effectively
Whether you're heading to remote trails or well-equipped camping sites in Cape Town, using your camping fridge efficiently will help extend its lifespan and reduce energy use. Here are some practical tips:
  • Defrost meat in the fridge compartment overnight to help keep the fridge cool.
  • Use the fridge's basket to improve air circulation and cooling efficiency.
  • Make sure the fridge latches are securely closed to preserve the seal.
  • Stack frozen food in the order you plan to eat it, and open the freezer only once a day if possible. This minimizes lid opening time and lowers fridge power consumption.
  • Avoid blocking the ventilation slots, as this raises the internal temperature and forces the fridge to use more battery power.
  • Always strap down your fridge securely to protect it from damage caused by bumps and vibrations.
  • Avoid setting the freezer too low. Unless storing ice cream at –18ºC, most items can be kept at around –10ºC to save power.
  • Keep your fridge as full as possible because it runs more efficiently than an empty one.
  • Carry spare fuses in case of electrical issues during your trip.
  • Don’t place hot leftovers directly inside the fridge. Let them cool first to prevent overworking the unit.
  • Vacuum-packed meat stays fresh longer and often doesn’t need to be frozen. This helps you use less electricity and makes more room in your fridge or cooler.
A reliable camping fridge can make all the difference in how enjoyable your outdoor adventures are. Choosing the right model will keep your food fresh, your drinks cold, and your power usage efficient throughout your trip. By focusing on key features like cooling ability, energy use, and durability, you can choose the fridge that best suits your camping needs. With smart planning and the tips shared in this guide, your camping fridge will be a reliable part of every adventure.
What size portable fridge is best for camping?
The ideal size of a portable fridge for camping depends on how long you plan to stay, how many people are in your group, and what you need to store. For solo or couple campers on short trips, a 20 to 30-liter fridge is usually enough. Families should consider a 40 to 50 liter option for weekend trips. If you are camping for more than three days, a fridge with 50 liters or more is recommended.
How do I choose a camping fridge?
When choosing a camping fridge, consider the following:
  • Capacity: Use a 35-liter fridge for solo trips or up to 90 liters for families.
  • Power use: Pick models with low power draw and adjustable voltage cut-off.
  • Portability: Choose compact, lightweight units for easier transport.
  • Durability: Look for strong, outdoor-ready construction.
  • Temperature control: Ensure adjustable and reliable cooling performance.
What is the best power source for a camping fridge?
The best power source for a camping fridge depends on your trip length and energy needs:
  • For short trips (1–3 days): Portable power stations are the top choice. These typically have a capacity of 500–1000Wh, and are lightweight and easy to carry, and can directly power the fridge without relying on a vehicle or mains electricity. They meet the temporary power needs of scenarios like weekend camping or day trips, and can also charge small devices such as phones and lamps, offering better cost-effectiveness.
  • For long trips (3+ days): Large-capacity portable generators or solar generators are more reliable options. Solar generators collect and store energy via solar panels, charging during the day and supplying power at night. Theoretically, they can achieve "unlimited runtime," minimizing energy anxiety while balancing environmental friendliness and practicality.
