EcoFlow OCEAN Smart Electrical Panel 40
Smart energy made easy—data, insights, and control
Up to 40 Smart Circuits
≤10ms Auto Backup Switchover[1]
15-Year Warranty[2]
15-Year Warranty[2]
The EcoFlow Smart Electrical Panel 40 is purpose-built for seamless integration with EcoFlow OCEAN Pro, delivering real-time energy balancing, smart backup, and whole-home power management—so your home stays powered, no matter what the grid brings.
Take full control of your home’s electrical load—no extra panels needed. Designed for homeowners going solar or fully electrifying, the OCEAN Smart Electrical Panel can replace a traditional 200A service panel and serves as your main panel, offering up to 40 smart circuits for seamless control and future-ready flexibility.
Tired of rising bills and energy guesswork? The EcoFlow Smart Electrical Panel 40 displays real-time solar production and home energy use, right down to each circuit. With AI-powered insights[3], you can easily spot waste, optimize usage, and take control of your energy costs—no effort required.
Say goodbye to blackouts and wasted energy. Monitor and manage up to 40 circuits individually—so you can optimize usage, cut waste, and keep essentials running when it matters most.
Storm approaching? Schedule non-essential circuits to shut off. Or prioritize essential loads to maximize battery life. Everything is just a tap away.
Reduce electricity costs by setting custom schedules for each circuit[4]. Run energy-hungry devices during off-peak hours and save effortlessly.
The EcoFlow OCEAN Smart Electrical Panel 40 gives you full-home control from a single app. Seamlessly manage your solar battery, EV charger, and real-time energy data—without juggling multiple platforms. From smart charging to backup power and insights, everything runs through one app. One system. One experience. Just simple, unified energy management.
<10 ms Backup Auto-Switchover
Stay powered through any outage. The EcoFlow OCEAN Smart Electrical Panel 40 instantly detects power loss and switches to backup in under 10ms[5]—so fast, you won’t notice a thing. With Storm Guard[6], your battery is always charged and ready before trouble hits.
Power stays on no matter what with backup plans A, B, and C. Enjoy seamless integration with multiple backup sources—so even when the grid goes down, the smart panel keeps your power running without missing a beat.
Scale up to 160kWh for whole-home backup that can last for weeks. Each OCEAN Pro inverter supports up to 8 batteries—up to 80kWh per system.
Get flexibly scalable battery capacity (up to 24kWh) with EcoFlow portable batteries. [8]
* Compatible with EcoFlow DELTA Pro Ultra and DELTA Pro 3 only.
Tap into up to 24kW of generator power—charge your batteries or run your home directly.
Customizable and Intuitive Design
The panel supports both flush and surface mounting for any home. NEMA 3R rated, it's safe indoors or outdoors. A built-in top light ensures your electrician always has proper lighting, making installation easy in any environment.
All specifications and descriptions shown may differ from the actual product. EcoFlow reserves the right to make changes and amendments to the product shown or described here at any time without prior notice. All functionality, features, specifications, design, and other product information displayed on this webpage—including, but not limited to, components, performance, availability, and capabilities—are subject to change without notice. The contents and simulated images on the screen are for demonstration purposes only. *Performance data is based on tests conducted in controlled environments using pre-configured settings. Actual results may vary depending on the environment, system updates, and individual usage patterns. [1] Performance data is based on testing conducted by EcoFlow Labs. Actual results may vary. [2] Warranty coverage begins once the product is successfully activated online. [3] AI-powered features require users to enable the EcoFlow AI Assistant within the EcoFlow app. [4] A stable Wi-Fi connection and the EcoFlow app installed on a smartphone are required for remote control and smart scheduling. [5] All performance claims are achieved under controlled laboratory conditions. Real-world results may differ. [6] Storm Guard Mode: When severe weather is forecasted within 12 hours, Storm Guard mode automatically charges your battery and sends an alert—so you're always prepared for potential outages. [7] The Smart Electrical Panel 40 is only fully compatible with the OCEAN Pro inverter. DELTA Pro Ultra, DELTA Pro 3, and other portable power stations can be connected as backup power sources, but cannot be managed or controlled via the panel. [8] EcoFlow portable batteries are sold separately and not included with the EcoFlow Smart Electrical Panel 40.
