What to Look for in a Portable Generator for Summer Camping, Blackouts, and Tailgates
Summer is all about long days filled with sunshine, warm weather, and making memories. With so many fun activities to be experienced outside, it's important to set yourself up with the right tools to enjoy the season to the fullest.
Whether your annual camping adventure is drawing near or you’re prepping to host an upcoming tailgate party, we’ve got you covered. Below, we’ll discuss the benefits of portable generators and help you find the perfect one for your needs.
Why Do You Need a Portable Generator This Summer?
While reconnecting with nature during the summer season is wonderful, having access to a reliable power source helps to heighten the overall experience and make it more enjoyable for everyone.
A portable generator elevates camping trips, tailgating parties, and other outdoor gatherings. These devices are strong enough to power fans, portable coolers, and so much more, making them a great addition to any outdoor celebration.
Not only are these devices great for the fun activities listed above, but they’re also excellent in emergencies. If a blackout were to strike or severe weather were to limit your access to the power grid, you can rest easy knowing the EcoFlow RIVER 3 Max is up to the challenge and will keep you connected and powered up all season long.
What Types of Portable Generators Are Available?
With so many different manufacturers, choosing the right generator can be overwhelming. Here’s a breakdown of the typical types of generators you’ll see when browsing the market.
Gas-powered
An old-fashioned generator is typically gas-powered and requires a certain level of knowledge to operate safely. These generators can get the job done, but they tend to run at a louder decibel and must be used in a fully outdoor setting away from people or poorly ventilated areas.
Gas-powered generators cost between $300 and $2,000, depending on the size and power of your chosen device.
Battery-powered
Another style of generator is the battery-powered option. These devices are typically rechargeable and generally a cleaner, more sustainable source of backup power.
The EcoFlow RIVER 3 Max Plus + 220W Solar Panel, for example, is fully rechargeable and operates by pulling energy from the attached solar panels. Devices like these do not emit the dangerous fumes that come from gas-powered generators and can be used anywhere.
Dual-fuel
As the name suggests, dual-fuel generators are usually powered by two different types of fuel: gasoline and propane. These generators' dual capabilities allow for some flexibility in the fuel you choose to purchase and can help extend the shelf life of your fuel source, as propane can sit idly for longer than gasoline.
Each of these generator types serves an important purpose. To figure out which option is best for you, consider how you plan to use it and which features are most important to you.
What Features Should You Look for in a Portable Generator?
Portability
The beauty of a portable generator is that you can take it on the go. Pay attention to the weight, size, and overall portability of the generator you purchase to ensure you can bring it with you on your adventures.
Safety Features
The different types of generators listed above require knowledge and skill to run safely. Do your research and find a device equipped with safety features that you are most comfortable with. Be willing to shop around to find exactly what you are looking for.
Fuel Type
If you plan to purchase a more traditional generator, you must know what fuel type is required. You will need to purchase fuel to keep your device running, so ensure you have easy access to the required fuel type for your selected generator.
Charging Capabilities
Battery-powered generators run off a charge rather than a specific fuel type. Do your research to find a device with a charge time that matches your expectations and ensures the battery life is what you’re looking for.
Noise Level
Fuel-powered generators are quite noisy when in use. If this is a problem for you, consider investing in a battery-powered option that will run at a much lower decibel level.
Under 10ms UPS keeps sensitive devices safe, with 600W output and 1200W X-Boost. Expandable, ultra-quiet, and lightweight—with fast 1-hour charging and up to 220W solar input for all-day, anywhere use.
What Size Portable Generator Do I Need for Summer?
The size of the generator you will need fully depends on what you plan on using it for. Small outdoor activities that require minimal power output would allow you to purchase a smaller generator. On the other hand, if you’re looking for a backup power solution to keep your entire home connected, you would need to invest in a larger, more powerful generator.
Will Heat Affect the Performance of My Portable Generator?
Increased temperatures can impact the overall performance of your generator. When temperatures reach their peak, you may notice reduced energy output as well as an increased risk of your device overheating. Keeping your generator in a shaded location away from direct sunlight can help reduce these concerns.
Portable Generators Upgrade Your Summer Outdoor Experiences
Having a portable generator to bring along for all of your summer adventures can make your experience all the more enjoyable. With our guide, you’re one step closer to finding the perfect generator for your needs.
Are you ready to bring home your very own generator? The EcoFlow RIVER 3 Plus is perfect for summer get-togethers and is guaranteed to provide you with all of the backup power you need.
Portable Power Stations
