How Many Watts Does a Laptop Use
How many watts does a laptop use? Honestly, there’s no one number that fits every machine. The answer changes with the model, the chip inside it, the graphics card, screen settings, what you’re doing on it, battery level, plugged-in devices, and whether it’s charging. Chargers are all over the map too.
None of that means the laptop is always using that much power. Charger wattage is just the most the adapter can put out, not what the computer is actually pulling at any given moment. For work on the go or backup power, bigger battery packs like the EcoFlow DELTA 3 Plus Portable Power Station and the EcoFlow DELTA 3 Classic (1024Wh) can run laptops along with routers and other must-have gear.
How Many Watts Does a Laptop Use?
A laptop might use just a few watts while asleep or sitting idle, then use a lot more once the chip and graphics card start working hard.
Usage looks different depending on what you’re doing:
Sleep mode: barely any power
Idle: usually just a few watts on efficient laptops
Web browsing and office work: moderate, goes up and down
Video streaming: higher, since the screen, Wi-Fi, and video chip stay busy
Photo or video editing: harder work for the chip and graphics card
Gaming: can be a lot higher
Charging while working: power goes toward running the machine and filling the battery at the same time
ENERGY STAR numbers show how low this can get on light tasks. One 2026-certified Lenovo laptop uses 3.0W in short idle and 0.8W asleep. A Dell laptop certified in 2025 uses 4.9W in short idle and 0.8W asleep. These show why no single number can cover every situation a laptop runs into.
Power use goes up whenever parts like the chip, graphics card, screen, fans, storage, and Wi-Fi have more work to do.
Don’t assume a laptop with a 65W charger is always pulling 65W. That number is just the charger’s top output, while what the laptop actually uses keeps changing minute to minute.
How Many Watts Does a Laptop Charger Use?
It usually matches what that specific computer needs and how fast it can charge. Here’s a simple look at typical charger ranges:
Laptop Type | Common Charger Range |
Lightweight laptop | 30 to 45W |
Productivity laptop | 60 to 70W |
Higher-performance laptop | 90 to 100W |
Mobile workstation/powerful laptop | 130W+ |
Newer MacBook Air models might come with adapters rated 30W, 35W, 67W, or 70W. Dell sells adapters at several ratings too, like 65W, 90W, 100W, and 130W.
Check your original charger, the laptop’s spec sheet, the maker’s website, or the number printed right on the adapter to find the right one for your machine.
How Many Watts Does a Laptop Use While Charging?
Charging can push up total power use since the charger might have to handle a few jobs at once: running the computer, filling the battery, and powering anything plugged into USB.
Power use climbs higher when a laptop is doing heavy work while charging at the same time. Charging power usually drops as the battery gets close to full.
Some laptops can also take stronger adapters to charge faster. Certain MacBook Air models can use 67W or 70W adapters.
That said, using a stronger compatible charger doesn’t mean the laptop is always pulling that charger’s full rated power.
What Affects Laptop Wattage?
Laptop wattage can change a lot throughout the day. Big factors include:
What the chip is doing
Built-in or separate graphics
Screen brightness, screen size, refresh rate, resolution
Gaming, video rendering, battery charging
Wi-Fi and Bluetooth use
Extra monitors and USB devices
Fans and any power-saving settings turned on
A simple laptop built mainly for documents, email, and browsing will use a lot less power than a gaming laptop.
Gaming, 3D programs, AI tasks, and video rendering keep both the chip and graphics card working hard for long stretches. Fans sometimes spin faster as well, adding to the total.
Screen choices matter as well. High brightness, high refresh rates, higher resolutions and multiple external monitors can all push electricity consumption up.
If battery life seems worse than it should be, cutting back on background apps and screen demand might help. Check out why your laptop battery might be draining so fast for more reasons and fixes.
How Much Electricity Does a Laptop Use?
Watts only tell you power at that exact second. If you want to know electricity used over a stretch of time, that’s measured in watt-hours (Wh) or kilowatt-hours (kWh).
Formula:
Laptop Wattage × Hours Used = Watt-Hours Used
Watt-Hours ÷ 1,000 = Kilowatt-Hours (kWh)
Take a laptop running at 60W for eight hours straight:
60W × 8 hours = 480Wh
480Wh ÷ 1,000 = 0.48kWh
So you’re looking at about 0.48kWh for that eight-hour stretch.
This is just an example, of course. Real use should come from the laptop’s actual average power draw, not just the top number printed on its charger.
How Much Does It Cost to Run a Laptop?
Once you know energy consumption, figuring out electricity cost gets pretty simple:
Energy Used (kWh) × Electricity Rate ($/kWh) = Electricity Cost
Say a laptop uses 0.48kWh over an eight-hour workday and electricity runs $0.18 per kWh:
0.48 × $0.18 = $0.0864
That works out to roughly $0.09 per working day.
Stretch that across 22 working days, and the hypothetical electricity cost lands around $1.90.
Actual cost depends on average laptop wattage, daily operating hours, working days and your local electricity rate. A high-performance laptop crunching demanding applications may cost more to run, while an efficient notebook doing light office work may burn through considerably less.
Can a Portable Power Station Run a Laptop?
Yes. Laptops generally pair well with portable power stations since their power needs sit way below high-wattage appliances like heaters, kettles, or cooking gear.
When picking out portable power, compare the laptop charger’s wattage against the power station’s output. Then think about battery size along with any other gadgets you want to run at the same time.
Here’s the key difference.
Watts (W) tell you if a power station can give enough power right now.
Watt-hours (Wh) show how much energy is stored, which helps you guess how long your gear can run.
A simple runtime formula looks like this:
Power Station Capacity (Wh) × Efficiency ÷ Average Laptop Wattage = Roughly Runtime
For example, real runtime from a 1,024Wh power station comes out lower than just dividing 1,024 by the laptop’s wattage, since power conversion causes some loss along the way. Laptop power use also keeps shifting.
A 1kWh-class power station holds a lot more than most laptop batteries. That’s handy for running a laptop along with monitors, phones, routers, or other gear during an outage or while working away from home.
You can also read more about off-grid power for laptops and gadgets or check out a bigger solar power station for longer off-grid use.
The EcoFlow DELTA 3 Plus Portable Power Station offers 1024Wh capacity and 1800W AC output, according to EcoFlow.
That mix works well for remote work, road trips, RV travel, camping, outages, and times when a laptop needs to run with several other devices at once.
Its 1024Wh battery holds plenty compared to a laptop battery alone, while 1800W output leaves lots of room for laptops, monitors, and networking gear.
EcoFlow lists the DELTA 3 Classic with 1024Wh capacity and 1800W output.
Its output goes way past what a normal laptop charger needs, while the bigger battery comes in handy when several gadgets need backup power at once.
There’s no single answer to how many watts does a laptop use. Power use shifts with hardware, workload, screen settings, plugged-in gear, and charging status.
The most important thing to remember is the difference between what a laptop actually uses and the top wattage printed on its charger. A laptop with a 65W, 100W, or 130W adapter won’t necessarily use that much all the time.
For extra laptop and gadget backup during remote work, camping, travel, or outages, the EcoFlow DELTA 3 Plus and DELTA 3 Classic (1024Wh) offer 1kWh-class battery power plus enough output for laptops and other compatible gear.
Is 65 watts enough to charge a laptop?
Yes, plenty of laptops built to work with a 65W power supply. That said, high-performance laptops might need 90W, 100W, 130W, or more. Always check what the maker says your laptop needs before assuming.
Does a laptop use the full wattage of its charger?
No. The charger’s rating just shows the most it can put out. What the laptop actually uses shifts based on what you’re doing, battery charging, screen settings, and what’s plugged in.
How many watts does a gaming laptop use?
Gaming laptops need more power than basic laptops, plain and simple; they’re built around beefier chips and graphics cards. The exact number depends on the hardware and how heavy the game is, and beefier models may need chargers rated well above 100W.
How much watts does a laptop use in 8 hours?
It depends on average wattage. A laptop averaging 60W for eight hours would use 480Wh, or 0.48kWh. A laptop averaging less power would use correspondingly less energy over that same stretch.
Can a 1,000Wh power station run a laptop?
Yes. A 1,000Wh-class power station can typically deliver solid laptop runtime. Actual runtime hinges on the laptop’s average wattage, conversion efficiency, battery health, and whatever else is drawing power alongside it.
