Whole-home Backup Power Solution
Power Has Never Been This Easy
Up to $2,807 Off
Smart Control Kit
CLICK HERE TO LEARN MORE
Exclusive deals are powering up
EcoFlow Prime Day Sale is coming soon
Save up to 60%
5.6-16.8kW solar input
1 hour solar for 1 day use
7.2-21.6kW
7.2-21.6kW
Output to power every home appliance
6-90kWh
6-90kWh
Storage for one-month-long backup
Guaranteed peace of mind
X-Cooling
X-Cooling
Proprietary ventilation tech
0 dB
0 dB
Under 2000W¹
With EcoFlow
Smart Home Panel 2
With EcoFlow Smart Home Panel 2
Advanced energy management
Versatile Charging Options
Including generators, EV piles, solar and the grid
0-ms Downtime
0-ms Downtime
Online UPS
6-90kWh
6-90kWh
7.2-21.6kW
7.2-21.6kW
With EcoFlow
Smart Home Panel 2
X-Cooling
X-Cooling
0 dB
0 dB
Under 2000W¹
0-ms Downtime
0-ms Downtime
Online UPS
The EcoFlow Smart Home Panel Series is the center of your home battery solution. With a seamless auto-switchover that's as fast as 10 ms during an outage, Smart Home Panel 2 keeps up to 12 electrical circuits connected, allowing your home appliances to run without interruption. Use Circuit Control mode to prioritize essential circuits. Plus, with Storm Guard, Smart Home Panel 2 makes regular weather checks and prepares your system for an outage when a storm approaches.
  • Outage
Smart Home Energy Management
Smart Control Kits
Take power management to the next level wherever you go with the EcoFlow app.
1 × EcoFlow Smart Home Panel 2 + 1 × EcoFlow DELTA Pro Ultra
6kWh Capacity | 7200W AC Output | 120V & 240V
Powers 3-ton central a/c.
$0$0
Buy now
Learn more
1 × EcoFlow DELTA Pro Ultra + 4 × 400W Rigid Solar Panels + EcoFlow Smart Home Panel 2
High solar efficiency 1-3 days whole-home backup (4 × 400W). 20 ms auto-switchover, prolonged backup time, and energy bill savings with EcoFlow Smart Home Panel 2
$0$0
Buy now
Learn more
1 × EcoFlow DELTA Pro 3 + Manual Transfer Switch
4kWh Capacity | 4000W AC Output | 120V & 240V
Plug & play home backup solution
$0$0
Buy now
Learn more
An Affordable Intergrated Home Energy System
An affordable and user-friendly entry-level solution for integrated home energy systems using the EcoFlow DELTA Pro, or EcoFlow DELTA Pro Ultra. Experience simple, safe, and sustainable home backup power.
    Smart, uninterrupted power.
    Take your home power to the next level and ultimately free yourself from the grid with the Smart Control Kit. Seamlessly integrate EcoFlow DELTA Pro and DELTA Pro Ultra with your home circuits via the Smart Home Panel 2 for uninterrupted power and intelligent energy management. Make smart energy savings by simply connecting to your existing rooftop solar panels to store energy to use day or night. With the EcoFlow app, monitor your power usage from any location, allowing you to maximize your energy bill savings and lower your carbon footprint.
    EcoFlow DELTA Pro Ultra + Smart Home Panel 2
    6kWh Capacity | 7.2kW AC Output | 5.6kW Solar Input
    - High solar efficiency 1-3 days whole-home backup (4 × 400W) - 20 ms auto-switchover, prolonged backup time, and energy bill savings with EcoFlow Smart Home Panel 2
    EcoFlow DELTA Pro 3 + Smart Home Panel 2
    - Expands from 4-48kWh for up to 1 week of power - Automatic 20 ms switchover time for uninterrupted power* - Smart energy management with the EcoFlow app - Avoid peak power rates to lower energy bills
    Uninterrupted backup power supply and smart power management. Take control of your energy and reduce your electricity bills with stored energy
    $0$0
    *Using 1 EcoFlow DELTA Pro 3 unit
    - 4-12kWh expandable capacity with up to 2 extra batteries - Continuous 120/240V, 4000 output while charging - Smart power management with EcoFlow app
    1 × EcoFlow DELTA Pro 3 + 1 × EcoFlow Smart Generator 4000 (Dual Fuel) + Manual Transfer Switch
    12kWh-28kWh* Capacity | 4000W AC Output| 120V & 240V
    - Up to 6000W with X-Boost - Continuous 120/240V, 4000 output while charging - Combine with EcoFlow Smart Generator 4000 (Dual Fuel) for intelligent auto-start/stop to ensure continuous power
    $0$0
    The smart engine produces 8kWh in single gasoline tank or simply plug in a 20lb propone tank and allow you access to a 24kWh power.
    1 × EcoFlow DELTA Pro + Transfer Switch
    3.6kWh Capacity | 3600W AC Output | 120V
    -3.6-10.8kWh expandable capacity with DELTA Pro Smart Extra Battery -Delivers 3.6kW for 99% appliances. -0-100% in as fast as 2.8 hours via solar (1.6kW) and in 1.7 hours via EV charging.
    2 × EcoFlow DELTA Pro + Double Voltage Hub + Transfer Switch + Generator Cord
    - Expands from 7.2-21.6kWh, for up to 1 week of power - 7200W and 240V output - Plug and play - Fully recharged in 5.4 hr
    Easily chain together two DELTA Pros using the Double Voltage Hub to power your entire home through your home's transfer switch. Run almost all home appliances, including high-wattage ones like a clothes dryer (5000W). Add Extra Batteries and Smart Generators to keep your essentials running for up to a week.
    $0$0
    *30 Amp Generator Cord (NEMA TT-30P to L14-30R) is needed to connect the DELTA Pro with your power inlet box.
    What can it power?
    • Light
    • Wi-Fi Router
    • 50" TV
    • Refrigerator
    • Electric Kettle
    • Electric Heater
    • Electric Oven
    • Microwave
    • Air Conditioner
    • Clothes Dryer
    • 1 × EcoFlow DELTA Pro Ultra + 2 × DELTA Pro Ultra Extra Battery
      • 60 days
      • 60 days
      • 131 hrs
      • 5 days
      • 9.6 hrs
      • 6.5 hrs
      • 8.7 hrs
      • 11.1 hrs
      • 8 hrs
      • 9 hrs
    • 1 × EcoFlow DELTA Pro 3 + 1 × DELTA Pro 3 Extra Battery
      • 26 days
      • 26 days
      • 58 hrs
      • 2.2 days
      • 4.3 hrs
      • 2.9 hrs
      • 3.9 hrs
      • 4.9 hrs
      • 3.5 hrs
      • 4 hrs
    • 1 × EcoFlow DELTA Pro + 1 × DELTA Pro Extra Battery
      • 24 days
      • 24 days
      • 52 hrs
      • 2 days
      • 3.8 hrs
      • 2.6 hrs
      • 3.4 hrs
      • 4.4 hrs
      • 3.2 hrs
      • 3.6 hrs
    Need an Energy Boost?
    Explore power independence, harness free energy from the sun with solar panels, and prolong run times with the Smart Generator 4000 (Dual Fuel) or Extra Batteries. Connect these with your EcoFlow DELTA Pro, DELTA Pro 3, or DELTA Pro Ultra during extended blackouts or whenever you need extra power.
    Learn more
(Duel Fuel)
    EcoFlow Smart Generator 4000 (Duel Fuel)
    Learn more
    EcoFlow 400W Portable
Solar Panels
    EcoFlow 400W Portable Solar Panels
    Learn more
    Explore our entire EcoFlow accessory range.
    Hear from Real EcoFlow Users
    Learn more about how the EcoFlow Whole-Home Backup Power Solution works, right from the mouth's of real users.
    Easy Solar Battery-JerryRigEverything
    Goodbye Grid
    Minute Man Prep
    The 8-Bit Guy
    Country View Acres
    Silver Cymbal
  • Join our community
    Explore the next leap forward in energy solution, get exclusive info, chat with 50k+ users and so much more.
    Learn more
  • Learn about power outages
    Prepare your home for winter power outages. Get ready for winter with our power outage-prep checklist.
    Learn more
  • Disclaimer*
    To qualify for the Federal Investment Tax Credit in a particular year, you must install the eligible solar equipment by December 31st of that year. Qualifying battery storage technology of 3kWh or more must be installed by a connection to a dwelling in the United States, lived in by the taxpayer. You should always consult your tax professional about your situation. EcoFlow does not guarantee any tax credit based on our products, and any information we provide is for educational purposes only and should not be considered legal advice. It does not constitute professional tax advice or financial guidance. It should not be used as the only source of information when making purchasing decisions, investment decisions, tax decisions, or execution. Consult a tax professional to evaluate your eligibility. Effective date: Jan 1, 2023
