How to Charge Apple Pencil: Simple Fixes, Smart Tips, and Real Power Solutions
Keeping your Apple Pencil charged should feel simple. But in real life, it often doesn’t. Maybe your Pencil stopped responding. Maybe you’re unsure how to charge it. Maybe you’re switching to a new iPad and wondering if your Pencil still works.
This guide shows you how to charge the Apple Pencil clearly, step by step. It includes all three current models, power tips, and one clever way to charge it even when you don’t have an iPad around. If you’re tired of guessing, read on.
How to Charge Apple Pencil (1st Gen): A Step-by-Step Breakdown
If you use the first-generation Apple Pencil, it charges using a Lightning connector. But there’s more than one way to do it.
Option 1: Plug into your iPad’s Lightning port
Remove the cap from your Apple Pencil. Plug the silver Lightning end into your iPad. A charging icon should appear shortly. Most iPads will show the current battery level in a pop-up bubble or in the batteries widget.
Option 2: Use the Lightning adapter and a USB wall charger
Your Pencil originally came with a small adapter. It lets you plug the Pencil into a normal lightning cable. If you lost the adapter, replacements are available online. Use a quality charger and expect a full charge in about 30 minutes.
Option 3: Connect to a USB port with a USB-to-Lightning cable
You can use a power bank or plug it into a laptop. As long as you use a working Lightning cable, it works.
Common issues:
  • The adapter is missing or damaged
  • Your iPad port is dirty
  • The Pencil is fully drained and takes longer to charge
How to Charge Apple Pencil (2nd Gen & Pro): Wireless Charging Tips
Second-generation and Pro models use magnetic charging. They attach them to the side of your iPad to charge wirelessly.
To charge properly:
  • Place the flat side of your Apple Pencil against the magnetic strip on the iPad’s right edge
  • You should feel a small click when it connects
  • A brief battery icon or animation will appear on screen
Apple Pencil Pro, launched in 2024, uses the same magnetic charging. It also adds new features like squeeze gestures, rotation sensitivity, haptic feedback, and Find My support. These additions do not change how it charges, but make it more useful for professionals.
Make sure of these:
  • Your iPad is compatible (M2 or M4 iPad Pro/Air)
  • Bluetooth is turned on EcoFlow RIVER 2
  • You remove any magnetic case or cover that blocks the strip
If it doesn’t charge:
  • Restart your iPad
  • Re-pair your Pencil in Bluetooth settings
  • Try again after 5–10 minutes of contact
Charging this way usually takes 15–20 minutes for a solid top-up.
How to Check Apple Pencil Charging Status and Battery Life
There are no lights on the Pencil itself. To check the charge level:
On iPad:
  • Swipe right from the Home Screen to open the “Today View.”
  • Tap “Edit” at the bottom
  • Add the “Batteries” widget
  • The battery status of your iPad and Apple Pencil will appear here
If nothing shows:
  • Unpair and re-pair your Pencil
  • Try reconnecting or reattaching
  • Keep your iPad screen unlocked when checking
This works for both the first and second-generation Pencils, as well as the Pro model.
How to Charge Apple Pencil Without an iPad: Power Options That Work Anywhere
Sometimes you need to charge your Apple Pencil, but your iPad isn’t around. In that case, the first-gen Pencil can still be charged using a Lightning adapter and a power source.
One versatile option is the EcoFlow RIVER 2, a portable power station that offers both USB-A and USB-C ports. You can plug in your Lightning cable directly and charge your Apple Pencil alongside your iPad or phone. This is useful in outdoor setups, power outages, or studio setups without wall outlets.
EcoFlow RIVER 2 is light, compact, and fast-charging. It offers flexible power on the go, especially for digital artists or students who work in changing environments.
Why Your Apple Pencil Is Not Charging: Common Causes and Real Fixes
When your Apple Pencil isn’t charging, don’t panic. It usually comes down to a few reasons:
For all models:
  • Bluetooth is off
  • iPadOS is outdated
  • The pencil is not paired or needs to be re-paired
  • The battery is fully drained and needs a few minutes before showing signs of life
For 1st-gen:
  • The Lightning connector is dirty or bent
  • The cable or adapter is damaged or unsupported
For 2nd-gen and Pro:
  • The magnetic case interferes
  • The pencil is not aligned properly on the charging area
  • Contacts on the iPad are dusty or oily
Try cleaning the ends, restarting your iPad, and leaving it connected for at least 15 minutes.
A woman works diligently at a sunlit desk, notebook in hand, with the EcoFlow portable solar generator powering her laptop amid books and plantsA woman works diligently at a sunlit desk, notebook in hand, with the EcoFlow portable solar generator powering her laptop amid books and plants
How to Extend Apple Pencil Battery Life Between Charges
If your Apple Pencil always seems to be dead when you need it, a few habits can help:
  • Charge once a week, even when not in use
  • Keep it connected to the iPad (for 2nd Gen and Pro)
  • Avoid draining it to 0%
  • Turn off Bluetooth if you won't use it for days
  • Always store it in a clean, dry place
These tips reduce the chance of deep battery sleep, which can prevent the Pencil from turning back on.
Charging Your Apple Pencil Should Be Easy: Once You Know What Works Best
Now you know how to charge the Apple Pencil no matter which version you have. First generation, second generation, or Pro, each one has a specific method and compatible iPads.
If you're often working away from a plug, a power station like EcoFlow RIVER 2 helps keep your tools charged and ready. For most users, though, once the Pencil is paired and attached correctly, charging becomes second nature.
When your tools work, your ideas flow. And charging them should never get in the way of creating something great.
EcoFlow RIVER 2 Portable Power Station
Charges in 60 mins to power 99% of appliances. Built for 10 years of use, it's your grab-and-go source & reliable home backup with a 30ms switch-over.
FAQs About Charging Apple Pencil
Q1. Can I charge an Apple Pencil using an iPhone charger?
A: Yes, you can charge the first-generation Apple Pencil using an iPhone charger if you have the proper Lightning adapter. Make sure the charger delivers enough power, and use an MFi-certified cable to avoid damage. This method is ideal when you don’t have access to your iPad or need a quick top-up on the go.
Q2. Is it safe to charge my Apple Pencil overnight?
A: It’s safe enough to leave the Apple Pencil charged overnight. Its internal battery management system will stop charging when it is full. However, it’s good form to unplug it when not in use to save battery life. This may also reduce long-term wear on both the iPad port and the Pencil battery.
Q3. How do I know if my Apple Pencil battery is damaged?
A: If your Pencil won’t work even after a long charge, or if it doesn’t show any Bluetooth signal, its internal battery might have degraded. Battery replacement isn’t user-serviceable in these situations, and you might need Apple service. Act sooner rather than later if you see declining performance, because waiting too long will result in permanent failure.
Q4. Can I use a wireless charging pad for the Apple Pencil Pro?
A: No, Apple Pencil Pro can only charge magnetically through a supporting iPad. It does not support universal wireless charging like Qi pads. Charge safely with the correct device always. Trying other unsupported ways will not just fail, but also harm the internal components of the Pencil.
Q5. Why does my Apple Pencil disconnect after a full charge?
A: This can be due to unstable Bluetooth pairing, iPadOS issues, or magnetic accessory interference. Attempt to remove any magnetic case, unpair and re-pair the Pencil, or restart your iPad. Updating to the newest iPadOS usually fixes this problem. Keeping software up to date and your device contacts clean can enhance stability in the long run.
Smart Devices
