From rooftops to balconies, gardens to walls—designed to fit your space.
Buy Now
Buy Now
Buy Now
Buy Now
Buy Now
Choose Your Solar System
The Limits of Traditional Balcony Solar Systems
Low Power?
Limited savings and low efficiency—especially during mornings, evenings, and winter months.
Small Balcony?
Two 400W panels require 4 metres of space. My 2-metre balcony isn’t large enough.
No Balcony?
Nowhere to install. Traditional balcony solar systems can't help.
Break Limits. Make Any Space into a Solar Station.
More Power Efficiency
More Solar Panel Options
More Mounting Solutions
Save 20 % vs Market-Standard
£88
Annual electricity bill savings
10
Fits 10 Scenarios · Easy Self-Install
The New STREAM Microinverter:
More Efficient. More Powerful.
Dawn to Dusk, Cloud or Shine: Power Your Home Even in Low Light
The EcoFlow STREAM Solar System excels even in low light. The microinverter activates with just 3W of solar input, ensuring a steady power supply to your home, even during early morning or dusk hours.
3W
activation watt
EcoFlow AI Assistant: No Math. Just Savings.
Your AI Assistant simplifies energy management by doing the hard work for you—analyzing data, spotting inefficiencies, and giving clear, actionable recommendations. No calculations, no guesswork—just smart, easy decisions.
Status Overview
AI Assistant
Savings Calendar
Remote Control
Seamless Smart Home Integration
Effortlessly connect with multiple third-party smart meters and digital energy platforms for real-time monitoring of your home’s energy usage via the EcoFlow app.
Tough Against Dust, Water, Heat, and Cold. Always Reliable.
IP67 Dust & Water Resistance Operating Range: -40°C to 65°C
65°C
-40°C
New Solar Panels: More Sizes, More Materials
More options designed for your space, to maximise your solar power.
NEW
250W Solar Panel
N-type
Cell Type
TopCon
Technology
Yes
Bifacial
1157×1165×20 mm
Size
~10 kg
Weight
≥24.7%
Efficiency
IP Rating
Bifacial + compact design, ideal for small balconies
Key Benefit
400W Solar Panel
P-type
Cell Type
PERC
Technology
No
Bifacial
1722×1134×34 mm
Size
21.8 kg
Weight
≥23%
Efficiency
IP Rating
Compact size for limited spaces
Key Benefit
450W Solar Panel
P-type
Cell Type
PERC
Technology
No
Bifacial
1908×1134×30 mm
Size
22.4 kg
Weight
≥23.3%
Efficiency
IP Rating
Higher output for more daily power
Key Benefit
NEW
520W Solar Panel
N-type
Cell Type
TopCon
Technology
Yes
Bifacial
2094×1134×30 mm
Size
24.6 kg
Weight
≥24.8%
Efficiency
IP Rating
Bifacial + high power for maximum energy yield
Key Benefit
The total panel capacity exceeds 800W slightly, ensuring your system consistently approaches the 800W input limit—even in low-light conditions or with power losses.
Bifacial Power-Generation Technology Captures More Sunlight
N-type bifacial panels use the front for direct sunlight and the back for reflected light; the higher their double-sided efficiency, the more total power they produce.
7.21%
Grass
9.54%
Cement
9.84%
Sandy Land
14.83%
Snow
24.85%
Mirror
More Power in Low Light with N-Type Technology
N-type solar cells catch weak light better than P-type ones, so at dawn, dusk, or on cloudy days they grab more light and make more power.
P-Type
N-Type
Solar Power Production Time
P-Type
07:0018:00
N-Type
06:0019:00
New Mounting Brackets:
Perfectly DIY for Any Space
Generate Your Own Power in Just 30 Minutes
No Drilling:
A drill-free design offers flexible positioning and is easily moved—perfect for renters.
DIY Solar System: Easy Setup, No Electrician Needed
9 Basic Solar Panel Mounting Brackets to Suit Every Installation Scenario
Balcony Mount – Hook Type
Metal railing balcony, wood, or glass panels
Balcony Mount – Tube Clamp Type
Metal railing balconies
Balcony Mount – Cement Base Type
Solid concrete balconies
Ballasted Mount
Flat roofs or gardens
Vertical Wall Mount – Adjustable Type
Concrete vertical walls
Vertical Wall Mount – Z-Bracket Type
Concrete sloped surfaces
Sloped Roof Mount
Tiled sloped roofs
Lightweight Vertical Wall Mount
Lightweight Balcony Hook Mount
60% More Power with Smart Tracker Technology
The EcoFlow Single Axis Solar Tracker 2 maximises solar efficiency even on limited balconies. Automatically adjusting angles to changing sunlight conditions and adapting to shadows from nearby trees or buildings, it optimises your energy production.
Seamless Energy Storage Upgrade—Save Even More
Easily integrate with the EcoFlow STREAM Series battery for simple energy storage, lowering your energy bills even further.
Notes:
* EcoFlow STREAM Solar System generates 858kWh of solar energy annually. Based on Germany's average household consumption (3,113kWh/year) and the electricity price of £0.33/kWh, this results in annual savings of £115. Actual savings may vary depending on consumption patterns and local energy rates.
*Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow APP for details on subscription plans and feature availability.
*The AI-TOU and AI Power Prediction features require connectivity to the EcoFlow STREAM Series Solar Plant. Certain AI functionalities are available through premium subscriptions. For detailed specifications and pricing, please visit the EcoFlow APP.
*Estimates use the PVGIS calculator (https://re.jrc.ec.europa.eu/pvg_tools/en/) for Munich, Germany (48.1 ° N, 11.6 ° E), south-facing array, 30 ° tilt, 14 % system losses, and assume that 40 % of the PV energy is self-consumed at a retail rate of £0.257 /kWh (25.7 p, Ofgem price-cap July–Sept 2025).
• EcoFlow STREAM Solar System: 858 kWh / yr → savings ≈ £88.
• Market-standard 800 W balcony kit: 715 kWh / yr → savings ≈ £74.
EcoFlow therefore delivers ≈ 20 % higher annual bill savings. Results vary with location, orientation, shading, weather, self-consumption ratio and local tariffs.
Online 24 hours
