30%EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable)
£118.79
£169.99
38%EcoFlow RAPID Pro Power Bank (20,000mAh, 230W, 100W Built-in Cable)
£79.99
£129.99
-25%RAPID Pro 140W Charger
£99.99
£79.99
52%RAPID Pro 100W Charger
£28.99
£59.99
EcoFlow RAPID Pro USB-C to USB-C Cable (240W, Nylon)
£19.99
One power solution, every situation
- Remote Work
- Travel
- Desktop
- Entertainment
Advanced protection for maximum performance Protected by EcoFlow's X-Guard
RAPID Pro maintains its fast charging levels 24/7 with around-the-clock safety checks. Its NTC chip tests for overheating up to 10 million times everyday, while the V0-level fireproof shell protects externally. Intelligent BMS and EMS systems keep the rest running smoothly.
million
times per day
Customise your power In-app Power Bank Management
Check your RAPID Pro's status even when you're away from it using the EcoFlow app. Turn on battery protection mode to extend the power bank's lifespan, or create your own custom screen display.
EcoFlow Power a New World
EcoFlow is a leading provider of eco-friendly energy solutions, committed to powering a new world. Since its founding in 2017 EcoFlow has aimed to be the FIRST in power solutions Flexible, Innovative, Reliable, Simple, and Thorough-for individuals and families, whether at home, outdoors, or on the go. With a smart manufacturing center in China, and headquarters in the USA, Germany, and Japan, EcoFlow has empowered over 5 million users in 140 markets worldwide.
