Engineered to Outperform
EcoFlow DELTA Pro Ultra
EcoFlow's Most Powerful Off-Grid Energy Solution*
Get the highlights.
Powerful Enough for All Your Needs
One 6kWh battery
Expands All the Way Up to 30kWh with 5 Stackable Units
Plug-and-Play to Grow Your Power for Weeks of Usage*
Take home power dependability to another level with up to 30kWh battery capacity. For a standard household, that's weeks of essential backup power to keep lights and appliances, like your fridge, running strong (time may vary). Stackable and space-saving, it packs comfortably into a garage or utility cupboard.
* Backup time depends on the appliances used
One 6900W Unit Easily Covers all Your Appliances
With a 6900W output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items, even an EV charger. With X-Fusion, it guarantees a total 6900W output even during charging.
How DELTA Pro Ultra Works For You
5 Ways to Quickly Refill So You're Always in Charge
Grid
Solar
EV Charging Pile
Generator
Multi-charge
24/7 Manage Your Energy with a Tap With EcoFlow OASIS
Build Your Own Energy System
- Washer
- Dryer
- EV - compatible with third-party charging piles
- Utility Room
- Kitchen
- Living Room
Take With You Anywhere*
20 ms UPS, 0 dB under 2000W
Backup You Won't Even Notice
With EcoFlow DELTA Pro Ultra's online UPS, you'll barely notice an outage. EcoFlow DELTA Pro Ultra safeguards your vulnerable electronic equipment round-the-clock, running at a whisper-quiet 0 dB, so you can work from home or sleep peacefully.*
* For low draws under 2000W
.png)
Safe and Reliable Home Power
Peace of mind with an advanced design
EcoFlow X-Cooling
With its flexible plug-and-play design and unrivalled solar input, EcoFlow DELTA Pro Ultra empowers you to tailor your solution to fit your energy needs. EcoFlow DELTA Pro Ultra includes a PV locking feature, assuring safety and a solid energy connection.
11 premium sintered heat pipes
6 dedicated fans
Customised aluminium board
Vertical cooling fins
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra. With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
- Inverter
- Battery
Powers Through the Most Challenging Situations
EcoFlow DELTA Pro Ultra tackles even the most gruelling conditions. Whether it's extreme weather or freezing winters, this giant safeguards your power security, just like usual.
Operating temperatures: -4°F to 113°F
290V high voltage tolerance
EcoFlow DELTA Pro Ultra Compatibility
![]() RIVER 3 Series | ![]() DELTA 3 Series | ![]() Solar Panels | ![]() 500W & 800W Alternator Charger | ![]() WAVE 3 | ![]() GLACIER Classic | ![]() STREAM Series & PowerStream | |
Compatibility | |||||||
DELTA Pro Ultra Outlets | AC Output | AC Output | High&Low PV Ports | AC Output | AC Output | ||
EcoFlow Connection Accessories | EcoFlow AC Charging Cable | EcoFlow AC Charging Cable | High PV: EcoFlow Solar Extension Cable Low PV: EcoFlow Solar to Low-PV Port Charging Cable | / | EcoFlow AC Power Adaptor |
Compare DELTA Pro Models
![]() DELTA Pro | ![]() DELTA Pro 3 | ![]() DELTA Pro Ultra (EU) | |
Capacity | 3.6-7.2kWh | Capacity 4-12kWh | 6-30kWh |
AC Outputs Voltage/Current | 230V/16A | AC Outputs Voltage/Current 230V/17A | 230V/30A |
Output Power | 3600W | Output Power 4000W | 6900W |
High-PV Input | / | High-PV Input 150V, 15A, 1600W Max | 450V, 15A, 4000W Max |
Low-PV Input | 11-150V 15A Max, 1600W Max | Low-PV Input 60V, 20A, 1000W Max | 150V,15A, 1600W Max |
AC Input | 2900W Max | AC Input 2900W Max | 2800W Max |
EV Charger Input | 3400W Max | EV Charger Input 4000W Max | 6900W Max |
UPS | 30ms EPS | UPS <10ms UPS | <20ms UPS |
