Portability
With a rugged, luggage-like handle, DELTA Pro can be wheeled around with ease.
3600W-7200W
Portable RV & EV Power
3.6-25kWh
Expandable Ecosystem
6500W Multiple
Charging Methods
Whole Home Backup Power Solution
1600W Solar Input
LFP Battery Built to Last
Stay prepared no matter what. DELTA Pro introduces FlowCharge. Now, you can charge anytime, anywhere and at the fastest speeds.
Charge up at thousands of AC level 2 EV stations worldwide to get up to 3400W of input. Enough to charge to full in 1.7 hours.
DELTA Pro is compatible with 90% of portable solar panels. And with a 1600W input, you can charge up in as fast as 2.8-5.6 hours. Integrate DELTA Pro with your home using the Smart Home Panel and use your rooftop panels to charge up too.
And of course, you can plug in at home to charge while the grid is online. Get a full charge in as fast as 1.9 hours.
When integrated with your home circuits via the Smart Home Panel, DELTA Pro charges at a rapid pace of 0-100% of 1.7hrs.
Plug directly into your car outlet to get a top up on-the-go. Ideal for when you need an extra few percent in a pinch.
Use EcoFlow's Smart Generator as a backup for your backup. It's smarter, more efficient and can charge your DELTA Pro in severe outages when you're all out of other options.
MultiCharge
technology.
We've raised the bar when it comes to charging speeds. Combine AC, solar, and the Smart Generator at the same time to get record-breaking 6500W charging speeds.
* Require DELTA Pro to be connected to a DELTA Pro Smart Extra Battery.
DELTA Pro's unique infinity port combines both AC input and output into one. It doesn't just enable the world's fastest charging and EV station charging, it also serves as a connection point for the Smart Home Panel and Double Voltage Hub. That means less adapters and cables for your setup.
The extra battery port serves as a way to connect an extra battery, or even the Smart Generator to your DELTA Pro. It can discharge and recharge the Extra Battery simultaneously so you only have to operate one unit, saving you time and effort. The port also communicates with the Smart Generator to enable auto-start up when your battery levels drop to a predefined level.
Batteries come in different shapes, sizes, and chemistries. DELTA Pro picks the best of the bunch for home backup with a LiFePO4 battery chemistry. That'll give you 6500+ cycles¹ so your battery will stand the test of time.
¹Approx. 6500+ cycles at 50% capacity.
Not only will your battery last years of heavy-duty use, it puts safety first too. Our advanced battery management system regulates voltage, current, and temperature in real time to ensure safe and optimal performance.
DELTA Pro is designed inside and out for ease of use, durability and safety. Take a closer look.
Each wire is secured and plated in copper, a key consideration in case of knocks and jolts, all while providing extra cooling. The 4 fans up auto-regulate to breathe ventilation through the unit for extra cooling.
Designed with tough ABS plastic, the exterior of DELTA Pro can take a tumble. As an added measure, we made it fire resistant too.
DELTA Pro is the first portable power station with a remote control. Mount it up, wire it up and control from a distance.
Use the remote control via bluetooth to control without wires. Or, link the EcoFlow app and control from anywhere with a wi-fi connection.
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
Stay calm and powered on.
When the power's down, AC Always-On ensures a seamless transition from the grid to backup power and unwavering protection of your fridge and other mission-critical appliances.
Elevated battery lifespan and safety.
By tuning the charging speed to suit various charging environments, it's safe to use, preventing overloading and prolonging its lifespan.
DELTA Pro's tactile buttons on the front of the unit pair with a bright LCD screen to give you all the control and information you need.
