Why Does My Phone Get Hot When Charging? Causes Explained
Plugging your phone and finding out minutes later that it’s warm leaves you confused. It gets worse when this happens repeatedly. You start to wonder - Why does my phone get hot when charging? Well, it’s normal for a phone to get warm while charging, but constant overheating is a cue for a deeper problem. It could signal a serious issue and can lead to long-term damage if ignored. But don’t worry, you're not alone in this, and the good news is, it’s usually easy to fix.
In this article, we’ll unpack why your phone heats up while charging, what it could mean, and the simple steps you can take to cool things down. Let’s explore them right away!
Common Causes of Your Phone Getting Hot While Charging
Pondering on - why does my phone get so hot when charging? Or why is my phone hot when charging lately, even when I’m not using it? Shows you’re concerned about finding ways to fix it. But before solving the problem, let’s look at the causes:
1. Overcharging
Leaving your phone plugged in for too long, especially overnight, can cause heat to build up. While most modern phones are smart enough to stop charging once the battery hits 100%, some older models or lower-quality chargers continue to pack the charge, and the result is having the extra energy stuck up with nowhere to go. This causes the battery to start heating up.
2. Fast Charging
Yes, many clamour for fast charging because of the convenience, but it can also be the leading cause of your phone getting hot when charging. Why? Because when your phone pulls in power rapidly, it puts extra pressure on the battery and charging circuits. It’s not always dangerous, but if your phone constantly feels too hot to touch, it may be worth switching to standard charging from time to time.
3. Poor Ventilation
Where you place your phone during charging matters more than you might think. When you charge on a bed, couch, or under your pillow, the heat your phone naturally generates gets trapped. And with no airflow to cool it down, your phone starts to overheat.
4. Using Low-Quality Chargers or Cables
Cheap or unbranded chargers often lack proper voltage regulation, which can cause your phone to overheat. It’s best to always go for certified or original accessories recommended by your phone’s manufacturer.
5. Using Your Phone While Charging
When you bury yourself in texting, gaming, scrolling through social media, or watching YouTube while your phone is plugged in, it can make your phone overheat. It doesn’t matter whether you’re charging from a wall socket or using a power bank. Mind you, your phone is trying to recharge while also working hard to keep apps running, especially if they’re heavy on graphics or video.
6. Aging Battery
Like everything, smartphone batteries wear out over time. If your phone is more than two years old and suddenly starts heating up during charging, it could be a sign that your battery’s health is declining.
7. Background Apps and Updates
Even when you're not actively using your phone, some apps may still be running in the background and, as such, syncing data, updating content, or refreshing notifications. On top of that, automatic software updates might be happening while you’re charging. These hidden tasks put pressure on the processor and make the battery heat up.
8. High Screen Brightness
This might seem like a small detail, but charging your phone with the screen brightness cranked all the way up uses more power and generates more heat. Try enabling adaptive brightness or dimming the screen to reduce the strain on your battery.
Hazard of Phone Overheating While Charging
When your phone gets hot while charging, especially constantly, the damage will eventually show up if you keep avoiding it instead of taking action. Here’s what will happen over time:
  • Permanent battery damage: As the most sensitive component of a phone, the battery will have its power storage capacity directly degraded by overheating, eventually losing the ability to hold a full charge entirely.
  • Slower charging speed: To avoid damage from overheating, the phone will automatically reduce charging efficiency. Thus, heat not only fails to speed up charging but also lengthens the process.
  • Accelerated aging of internal components: Sustained high temperatures will accelerate the aging of internal hardware such as the motherboard and chips, which may lead to performance issues over time, or even total hardware failure.
  • Degraded device performance: The phone may experience lag, freezing, or app crashes—though this is a self-protection mechanism of the device, it will severely affect the user experience.
How to Fix Phone Overheating Problems While Charging
Seeing that your phone is overheating when charging should spur you into action. Don’t ignore it before it blows up into something more drastic. There are easy fixes that can help cool things down and protect your phone from damage. Here are some of them:
  1. Unplug It Immediately: The first step is to stop charging it completely. Unplug the charger and give the phone a break. Let it cool down before you plug it in again.
  2. Remove the Case: Yes, phone cases are great for protection, but not so great for airflow. Taking off the case while your phone charges can help heat escape more easily and allow the device to cool down faster.
  3. Move It to a Cooler Spot: Charging your phone near a window or on a soft surface like your bed is not ideal. Try moving it to a hard, cool surface away from heat sources or direct sunlight. A cool, well-ventilated room is perfect.
  4. Use a Fan or Cooling Pad: Just like your laptop, your phone can benefit from a little extra airflow. Try and get a small desk fan or a cooling pad to help push away the heat while your phone charges.
  5. Turn On Airplane Mode: This helps to cut off background connections like Wi-Fi, Bluetooth, and mobile data so your phone uses less power, charges faster, and stays cooler. It’s especially helpful when you’re not expecting any calls or messages.
  6. Close All Running Apps: These apps put pressure on your phone’s processor and battery. So, before charging, close all unused apps to lower your phone’s workload and temperature.
  7. Uninstall Any Problematic Apps: Some apps can misbehave or use too much processing power, even when you’re not using them. If your phone started heating up after installing something new, try removing that app and see if things improve.
  8. Turn Off Background App Refresh: Your phone keeps some apps updated in the background, even when you’re not using them. While helpful, it also adds to the heat. You can disable this setting to ease the strain on your phone during charging.
  9. Charge in Short Bursts: Instead of keeping your phone plugged in for long hours, try charging it in shorter sessions. This gives your phone a chance to rest and cool down in between. Consider having the best portable battery charger for phone, so you can easily plug in and charge a bit while on the move.
Preventive Tips to Avoid Future Overheating Problems
You can always fix your phone’s overheating problem, but preventing it is even better. It saves you from impending danger that can’t be reversed if you have just fixed the issue. Here are a few smart habits to keep in mind while charging:
  1. Unplug your phone immediately once it’s fully charged to avoid prolonged charging. If you often charge it overnight, iPhone users can enable the "Optimized Battery Charging" feature to reduce constant strain on the battery.
  2. Prioritize using certified, model-matched authentic chargers to ensure safe, cool charging. The same applies to power banks—opt for high-quality, portable options like the EcoFlow RAPID Pro Power Bank (20,000mAh, 230W, 100W Built-in Cable). It not only boasts large capacity and multiple ports but also supports a battery optimization mode, extending the lifespan of both itself and your phone.
The EcoFlow RAPID Pro Power Bank is a compact powerhouse with a 20,000mAh capacity (72Wh), powerful enough to charge laptops, phones, and tablets. When paired with the EcoFlow RAPID Pro 320W Charging Station, it recharges up to 80% in just 47 minutes. And with a total output of 230W spread across four USB-C ports, including a 100W built-in retractable cable, it can charge multiple devices at once without slowing down. A smart LCD screen showcases the real-time battery info and allows for customization of the standby display.
  1. Turn off unused features like Wi-Fi, Bluetooth, and GPS before charging to reduce background power consumption.
  2. Keep your phone’s system updated to fix bugs and optimize performance promptly.
  3. Uninstall apps with abnormal power consumption to cut unnecessary energy use.
  4. Regularly check your battery health in settings and replace it if it shows signs of aging.
  5. Lower screen brightness before charging, or enable adaptive brightness, to prevent overheating caused by high screen load.
  6. Avoid heavy usage such as streaming or gaming while charging; use apps once charging is complete.
  7. If your phone tends to overheat with wired charging, try wireless charging. Though slightly slower, it’s gentler on the device and maintains a stable temperature.
If you ask, Why does my phone get hot when charging, understand that a little warmth is normal, but when it overheats consistently, then that’s a red flag to be addressed immediately. Thankfully, the fixes are usually simple. From unplugging at the right time to using the right accessories and keeping your phone updated. And if you’re always on the go, investing in a reliable, high-quality charging solution can also help manage heat better and keep your phone healthier for longer. EcoFlow’s power bank is worth considering, especially as it’s compact enough to fit your small bag and also air-travel friendly.
In the end, treating your phone gently while it charges doesn’t just protect the battery; it helps extend the life of the device itself. Take the necessary measures to keep it in good shape.
Is it normal for my phone to get hot when charging?
Mild warmth is normal, but significant heat requires intervention. If your phone gets noticeably hot while charging, you should stop charging immediately, close background apps, and move the phone to a cool place to cool down. If high temperatures, abnormal charging, or similar issues occur frequently, check whether the charger is authentic and the battery health status (viewable in "Settings - Battery" on your phone). If necessary, contact official after-sales services for inspection and repair to avoid prolonged high temperatures impairing the device's lifespan or causing safety risks.
How do I stop my phone from overheating?
The core of preventing a phone from overheating boils down to three things: reducing unnecessary power consumption, improving its heat dissipation environment, and maintaining normal hardware conditions.
In daily use, if you find your phone overheats frequently, accompanied by lagging or a sudden drop in battery life, it may indicate a hardware failure (such as a short circuit on the motherboard). It is advisable to contact official after-sales services for inspection promptly to avoid safety risks.
How do I cool down my phone while charging?
There are four ways to keep your phone cool while charging:
  • Reduce load: Avoid using power-hungry apps while charging; close background programs and features like Bluetooth and GPS; lower the screen brightness.
  • Optimize environment: Charge in a cool, well-ventilated area; remove thick phone cases; avoid placing it on soft/high-temperature surfaces or stacking it with other devices.
  • Aid heat dissipation: Use a fan to speed up air circulation, or place it on objects with good thermal conductivity such as metal or ceramics; if overheating occurs, briefly disconnect it from the charger and restart the device.
  • Check hardware: Use original/certified chargers; inspect battery health; replace aging batteries promptly.
Is fast charging bad for the battery?
Fast charging is not absolutely harmful, especially since modern phones can effectively suppress heat through intelligent temperature control technology, reducing its impact on the battery. However, long-term and frequent use of fast charging may indeed cause certain battery wear. Thanks to technological optimizations, this wear is now controllable.
For most users, the value of the efficient charging experience brought by fast charging far outweighs the slight impact it has on battery lifespan—under normal usage, a phone battery typically lasts 2-3 years, which is sufficient to cover most people’s device replacement cycles. Simply avoid fast charging in high or low temperature environments and avoid over-reliance on high-power modes (e.g., alternating between fast and slow charging), and you can enjoy the convenience while minimizing wear and protecting battery health.
Power Banks
