The Best Portable Battery Charger for Phones (Apple/Android)
Running out of battery when you’re on the go can be a major headache, especially when your phone is essential for staying connected. A portable battery charger provides the perfect solution, ensuring you never get stuck with a dead phone. But with so many options available, how do you know which one is the best for your needs?
That is where this blog comes in. By highlighting the 5 best portable battery chargers for phones and explaining what key factors to consider when choosing one, we aim to help you find the perfect solution to keep your devices powered up. Keep reading to say goodbye to low-battery anxiety!
5 Best Portable Battery Chargers for Phones in 2025
Looking for the best way to keep your phone charged on the go? Check out our top picks for portable battery chargers in 2025. These options will make sure you never run out of power, no matter where you are!
1. EcoFlow RAPID Magnetic Power Bank
Combining wireless and wired charging into one, EcoFlow RAPID Magnetic Power Bankranks top as your best portable battery phone charger for iPhones. Featuring Qi2-certified wireless charging, it has a maximum output of 15W. It also has a built-in USB-C cable for 30W/65W wired charging.
By using a 65W GaN charger, the power bank itself will be charged from 0 to 70% in just 33 minutes. You don’t have to worry about insufficient power when rushing to get out. Plus, the built-in kickstand can also be used as a desktop stand. It offers an upright and a side view. You can always have the most comfortable angle when watching watch videos or making video calls.
In addition, the 10000mAh version also provides real-time information on charging speed, power output, and other essential charging insights. You can even customize the display via the intelligent app, making this power bank one-of-a-kind.
2. Omnicharge Omni 30C+
The Omni 30C+ is arguably the most powerful all-in-one portable battery charger. It carefully customizes charging ports of different powers. You can benefit from the 2 USB-C ports (with a staggering 100W each), a 100W DC port, and 2 USB-A ports, and wireless charging (10W for smartphones, 5W for earbuds, and 3W wireless for Apple Watches) just in one power bank. This ensures charging efficiency while protecting the battery life of each device. Whether you’re working remotely or charging your laptop and phone when camping, the 25,600mAh battery capacity is up to the task of charging multiple devices 1-2 times. So, you no longer need to be in a dilemma when it comes toportable power stations vs power banks for one day out. Plus, a protective case and a 100W USB-C braided cable are included for each order.
3. UGREEN Nexode Power Bank 25000mAh 200W
You can trust it as a reliable high-capacity portable battery charger for Samsung phones or other Android/Apple devices. The 25,000mAh high capacity takes low-battery worry away and ensures charges for multiple devices. It is also equipped with dual 100W PD 3.1 ports, which means you can fast charge two laptops or devices at the same time. With the intelligent TFT display, you can catch the remaining battery and real-time voltage, current, and input & output for each port. This surely gives you peace of mind.
4. Baseus Magnetic Foldable Power Bank 20W 10000mAh
You’ll never go wrong with a budget-friendly portable charger for iPhones and other phones/devices. Even for devices that have no magnetic features, this magnetic power bank is also compatible. The 20W fast charging capability reduces your charging time while the 10000mAh capacity can charge the iPhone 13 1.8 times. You can stay powered throughout the day. The foldable stand supports your phone horizontally and vertically. You can enjoy the best angle for video calls or watching. It is the ideal choice that offers great value for money.
5. Anker Nano 22.5W Power Bank
If you need a true portable battery charger for phones, look at Anker’s Nano 22.5W Power Bank. Packing the foldable USB-C ports inside, it measures 3.0 x 1.4 x 1.0 inches and weighs just 3.5 ounces. Whether putting it in your pocket or holding it in your hand, it’s effortless. This 22.5-watt power bank, with a 5,000mAh capacity, ensures your devices stay charged wherever you are, which can be a lifesaver to save your low-battery worry when you’re out. Besides regular colors like black and white, it has eye-catching choices including blue, green, and pink. You can select the one for your phone’s color scheme.
What to Look for in a Portable Battery Charger for Phones
When choosing a portable battery charger for phones, please consider the following key factors.
  • Battery Capacity: Measure in milliamp-hours (mAh), the battery capacitydetermines how much charge the portable battery charger can hold. Higher capacity means more charges for your devices. For example, a 10,000mAh power bank is typically regarded as high-capacity because it can charge a smartphone 2-3 times.
  • Portability: Check the size and weight before making a purchase. Compact and lightweight power banks are more convenient for daily use and travel. However, a portablepower stationwould be better if you need massive power in a fixed location.
  • Output Power: Look for a power bank with sufficient output power (measured in watts) to fast-charge your device. For example, at least 15W output is required for iPhones and higher for Android devices.
  • Number of Ports: Ensure the charger has enough ports to charge multiple devices simultaneously. The mainstream options include USB-A and USB-C.
  • Safety Features: Look for built-in protections like overcharge, over-discharge, short-circuit, and temperature protection to ensure safe use.
A reliable portable battery charger keeps you connected at all times. It’s worth spending time finding out the best portable battery charger for cell phones and other devices. If you don’t know where to start, this blog is a must-read. It reveals the key factors you should pay the most attention to and contains detailed descriptions of the 5 best portable battery chargers for Android phones and iPhones. After reading, you’re sure to make a more informed decision.
Which is better, a power bank or a portable charger?
A power bank and portable charger are essentially the same, both providing backup power on the go. However, “power bank” typically refers to a larger capacity, while “portable charger” can be a more compact option. Choose based on your needs: higher capacity for longer use or portability for convenience.
Does Powerbank reduce battery life?
No. Using a power bank doesn’t directly reduce your device’s battery life. However, frequent charging or charging while the device is in use can generate heat, which may degrade battery health over time. It’s important to avoid overcharging and unplug when your device reaches 100% to maintain battery longevity.
