Power Factor Formula: How to Calculate, Correct & Apply It in AC Circuits
Whether you have ever seen an electricity bill and thought to yourself how can you possibly be using more electricity than you're paying for, or you've noticed that the industrial equipment you are using appears to be consuming a lot more current than its nameplate value, you have experienced power factor — without realising it at the time.
One of the concepts that remains in the background of each AC electrical system is the power factor. Knowing it — and the formula for calculating the power factor — gives you insight into how electricity is being used and how some systems use it more efficiently than others, and why. Whether you are considering a home energy management system or simply making choices about the installation of solar and storage, understanding power and energy metrics makes for better decision-making.
This guide starts with the basics of power factor, the necessary formulas, how to determine and improve power factor, and the implications of power factor for home and business energy efficiency.
What Is Power Factor and Why Does It Matter?
Power factor is a measure of how efficiently electrical power is being used in an AC circuit. More precisely, it's the ratio of real power (the power that actually does useful work) to apparent power (the total power drawn from the supply).
A power factor of 1.0 (or unity power factor) represents 100% power efficiency (all the power you take from the supply is used for useful work). If the power factor is less than 1.0, this indicates that some of the power drawn is returned unutilized back to the supply, resulting in an inefficient process and an increase in the power current that the power supply is being asked to supply for the same amount of useful power.
Why Power Factor Matters for Homes and Businesses in the UK
If these consequences are severe, in the UK, a poor power factor will have direct financial implications for large industrial and commercial consumers. Energy suppliers bill commercial customers not only for real power (kWh) but also for apparent power (kVA), so that a site with a low PF fails to save as much energy as one with a high PF. For this reason, power factor correction is a common practice in the commercial electrical engineering world.
Residential users are more affected indirectly. Electricity meters in the UK are normally only used to measure real power (kWh) and do not send homeowners a bill for poor power factor. On the other hand, a low power factor causes heating losses in cables and equipment and may shorten the useful life of electrical equipment in the long run.
As the number of electronics, variable speed drives, and switch-mode power supplies is installed in homes, power factor has become more and more important to overall system efficiency, as devices with low power factor are often found in these homes.
Real Power, Reactive Power, and Apparent Power — Explained Simply
The three terms are the basic concepts of power factor. Imagine them using a simple analogy, a pint of beer.
Real power (P): Real power (P) is the power of the beer itself (in watts (W) or kilowatts (kW)). It's the practical work that is being done, such as getting heat generated, the light is coming out, and the motors are turning.
Reactive power (Q): The froth is called “reactive power” (Q), measured in volt-amperes reactive (VAR). It comes from supply and goes back without being used for any purpose. Requires to magnetise inductive devices (motors, transformers), but it is not part of the useful output.
Apparent power (S): Apparent power (S) is the total volt-ampere (VA or kVA) of beer, froth, and glass. This is the total power the supply is required to supply.
These three are linked to forming the power triangle, and the power factor is the one that connects them.
The Power Factor Formula Explained
Formula for Power Factor — The Basic Equation
The formula of power factor in its simplest form is:
PF = P / S
Where:
  • PF = Power factor (dimensionless, between 0 and 1)
  • P = Real power in watts (W) or kilowatts (kW)
  • S = Apparent power in volt-amperes (VA) or kilovolt-amperes (kVA)
Power factor can also be expressed as a percentage (e.g., 0.85 PF = 85% power factor) or as a decimal.
A power factor of 1.0 is ideal — it means all apparent power is real power, with no reactive component. In practice, most AC systems operate between 0.7 and 0.95.
AC Power Factor Formula and Circuit Power Factor Formula
In AC circuits, power factor is also expressed in terms of the phase angle between voltage and current waveforms:
PF = cos(φ)
Where φ (phi) is the phase angle between the voltage and current waveforms.
These are the AC power factor formula and the circuit power factor formula in their trigonometric forms. When voltage and current are perfectly in phase (φ = 0°), cos(0°) = 1, giving a unity power factor. As the phase angle increases, the power factor decreases.
In a purely resistive circuit (a simple heater or incandescent bulb), voltage and current are in phase, and the power factor is 1.0. In circuits with inductive loads (motors, transformers), current lags behind voltage, reducing the power factor below 1.0.
Electric Power Factor Formula vs Electrical Power Factor Formula
There's no meaningful distinction between the electric power factor formula and the electrical power factor formula. Both terms refer to the same equation: PF = P / S or, equivalently PF = cos(φ). The terminology varies across textbooks and industries, but mathematics is identical.
Power Formula With Power Factor
Single-Phase Power Formula With Power Factor
The power formula with power factor for a single-phase AC circuit is:
P = V × I × PF
Where:
  • V = RMS voltage in volts (V) — 230V for UK single-phase supply
  • I = RMS current in amps (A)
  • PF = Power factor
Example: A single-phase motor drawing 10A from a 230V supply with a power factor of 0.85 has a real power consumption of: P = 230 × 10 × 0.85 = 1,955W (approximately 2kW)
The apparent power in this example is 230 × 10 = 2,300 VA — the supply must provide 2,300 VA to deliver 1,955W of useful work.
3-Phase Power Factor Formula
For three-phase systems — if you need a refresher on the difference between single-phase and three-phase supply, our single-phase and three-phase power guide covers the basics — the 3-phase power factor formula is:
P = √3 × V × I × PF
Where:
  • √3 = 1.732 (a fixed constant)
  • V = Line voltage in volts (V) — 400V for UK three-phase supply
  • I = Line current in amps (A) per phase
  • PF = Power factor
Example: A three-phase motor drawing 20A per phase from a 400V supply with a power factor of 0.9: P = 1.732 × 400 × 20 × 0.9 = 12,470W (approximately 12.5kW)
Apparent Power, Real Power, and Reactive Power Calculations
The three quantities relate as follows: S = V × I (single-phase) or √3 × V × I (three-phase); P = S × PF; Q = √(S² − P²); PF = P / S = cos(arctan(Q/P)). Knowing any two allows you to calculate the third.
Power Factor Calculation Formula — Step-by-Step
How to Calculate Power Factor From Voltage and Current
If you have access to a power meter or clamp meter that measures real power (W) and apparent power (VA):
  1. Measure real power P in watts
  2. Measure apparent power S in VA (or calculate S = V × I)
  3. Apply: PF = P / S
Example: A motor measures 1,800W real power and draws 8A from a 230V supply. S = 230 × 8 = 1,840 VA PF = 1,800 / 1,840 = 0.978
How to Calculate Power Factor From Real and Apparent Power
If you know the phase angle φ between voltage and current (measurable with an oscilloscope or power quality analyser):
PF = cos(φ)
Example: A clamp meter shows a phase angle of 25.8° PF = cos(25.8°) = 0.9
Worked Examples for Homes and Small Businesses
Home scenario — induction hob: A 2,000W induction hob with PF 0.99 draws I = 2,000 / (230 × 0.99) = 8.77A.
Small business scenario — air conditioning: A 5kW AC unit with PF 0.75 draws S = 5,000 / 0.75 = 6,667 VA apparent power, requiring I = 29A — cables and circuit breakers sized for 29A even though it only does 5kW of useful work. This is why low power factor matters.
Power Factor Correction Formula
What Is Power Factor Correction and When Do You Need It?
Power factor correction (PFC) is the process of improving a system's power factor toward unity by adding reactive components — typically capacitors — to cancel out the inductive reactive power. This reduces apparent power demand, lowers current draw, and reduces losses in cables and switchgear.
In the UK, power factor correction is most relevant for:
  • Industrial sites with large motor loads
  • Commercial premises pay demand charges based on kVA
  • Any site where a low power factor is causing excessive current and cable heating
For domestic properties, PFC is rarely necessary — but understanding the formula is useful for anyone working with electrical systems professionally.
Formula for Power Factor Correction
The formula for power factor correction gives the reactive power (in kVAR) of capacitors needed to improve power factor from an initial value to a target value:
Q_c = P × (tan φ₁ − tan φ₂)
Where:
  • Q_c = Required capacitor reactive power in kVAR
  • P = Real power in kW
  • φ₁ = Phase angle at current (uncorrected) power factor
  • φ₂ = Phase angle at target (corrected) power factor
  • tan φ = √(1 − PF²) / PF
Example: A site drawing 50kW at PF 0.75 wants to be corrected to PF 0.95: tan φ₁ = tan(arccos 0.75) = 0.8819, tan φ₂ = tan(arccos 0.95) = 0.3287, Q_c = 50 × (0.8819 − 0.3287) = 50 × 0.5532 = 27.66 kVAR
A 27.66 kVAR capacitor bank would be required to correct the power factor from 0.75 to 0.95.
3-Phase Power Factor Correction Formula
For three-phase systems, the 3-phase power factor correction formula follows the same logic but applies to the three-phase real power:
Q_c = P₃φ × (tan φ₁ − tan φ₂)
Where P₃φ is the total three-phase real power in kW. The capacitor bank is then split equally across the three phases.
Example: A three-phase motor load of 150kW at PF 0.7 to be corrected to PF 0.92: tan φ₁ = tan(arccos 0.7) = 1.0202; tan φ₂ = tan(arccos 0.92) = 0.4261 Q_c = 150 × (1.0202 − 0.4261) = 150 × 0.5941 = 89.1 kVAR
Formula for Power Factor in an AC Circuit — Practical Correction Steps
  1. Measure existing real power (kW) and apparent power (kVA) — or calculate from voltage and current
  2. Calculate existing power factor: PF = P / S
  3. Determine target power factor (typically 0.95 for commercial sites)
  4. Apply the correction formula: Q_c = P × (tan φ₁ − tan φ₂)
  5. Select a capacitor bank rated at or slightly above Q_c
  6. Install and verify the improved power factor with a power quality analyser
Note: Power factor correction equipment must be designed and installed by a qualified electrical engineer. Incorrectly sized capacitors can cause resonance issues and other problems. Always consult a professional for commercial PFC installations.
Power Factor, Energy Efficiency, and Modern Energy Systems
How Poor Power Factor Affects Electrical Efficiency
There is no direct link between poor power factor and the reading on a domestic meter in kWh, but there is a link between poor power factor and the flow of current for a given amount of useful work. The higher the current, the higher the resistive losses in the cables – these losses don't produce useful output; they produce heat. This gradually decreases overall system efficiency and causes wear on electrical components.
The impact on the sizing of cables, ratings of switchgear, and losses of energy due to poor power factor can be significant when sites have heavy inductive loads such as multiple motors, large HVAC systems, industrial machinery, etc.
Power Factor Considerations in Residential and Commercial Systems
Increasingly, modern homes have devices operating with either variable power factor or poor power factor, such as variable speed drives in heat pumps, switch-mode power supplies in electronic systems, LED drivers, and EV chargers. Domestic meters do not charge for reactive power, but the aggregate effect of all the individual meters in a neighbourhood does have an impact on the efficiency of the distribution network.
Commercial properties, on the other hand, are usually charged on top of maximum demand (kVA) and consumption (kWh). These sites are cost considerations for maintaining a power factor above 0.95 (or as high as their supplier desires).
The Role of Smart Energy Management Technologies
The modern energy management systems, such as home battery storage systems with built-in inverters, have smart controls that track energy consumption and optimise the timing of its utilisation. Advanced inverters can be set with a power factor correction function and thus can support reactive power as an integral part of the normal operation of the inverter.
How Battery Storage Can Support Efficient Energy Use
High-quality inverters within a home battery system can allow the stored DC power to be converted to AC power and provide a controlled waveform to connected loads, ensuring a high quality of power. They help to reduce the instantaneous draw on the household circuit by bringing high-draw appliances onto the grid when solar energy is available and off when it is not, thereby aiding overall system efficiency indirectly.
Home Energy Storage as Part of an Energy Management Strategy
How Solar Battery Storage Improves Home Energy Efficiency
A solar battery storage system provides energy storage during the day and supplies it to the home's circuit when required. This means that less power is drawn from the grid, electricity bills are lowered, and with the use of modern battery inverters, which provide clean and consistent AC, good power quality is maintained throughout the home.
If homeowners would like to know how much energy they are consuming in the terms outlined in this article, it is their energy, their apparent power, and their power factor that can be made visible and active by a good home battery system with monitoring. You can see the exact amount of real power your home consumes at any moment in time and how solar generation and storage are helping to meet demand for electricity from the grid.
Comparing Home Battery Systems Using Power and Energy Metrics
The important factors to consider for battery systems are:
  • Power output (kW): The amount of actual power that it can produce in one go — useful for operating high-power-consuming appliances.
  • Storage capacity (kWh): The amount of energy that can be stored in the system — this is important for the duration of time your home can be powered by the system.
  • Inverter efficiency: How much of the stored DC energy is converted to usable AC without losses
The two systems listed below perform well in all three respects and are easy to install in domestic UK houses.
EcoFlow STREAM Ultra X — Smart Home Solar Battery
The STREAM Ultra X is a solar battery for the home that comes with an inverter, directly linked into your home's electrical system. Solar panels are used to recharge it during the day, and it provides energy to the circuit you have in your home, which means that your appliances can be operated by solar energy and not from the grid.
Up to 2,300W AC output in dual-unit configuration 2,000W solar input with 4 MPPTs and Low-Light Cells — captures useful energy even on cloudy days Expandable from 3.84 kWh up to 23 kWh by adding extra batteries 15-year lifespan with high safety standards Compatible with Tiber, Matter, and Shelly smart home protocols Save up to £1,729 annually on electricity bills
EcoFlow STREAM Ultra X All-in-One Home Storage Kit
This kit comes with solar panels, a battery, and installation hardware for households requiring a solar power and storage system. The EcoFlow app allows you to monitor your generation, storage and consumption in real-time, meaning that you can see how you're using power in terms of this article.
Save up to £1,729 annually on your electricity bills. Enjoy up to 2300W AC output, easily powering high-demand appliances. Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night. With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy. Features a 15-year lifespan, ensuring high safety and long-term reliability. Set up is effortless and requires no electricity. Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
Common Mistakes When Applying the Power Factor Formula
  • Confusing kW and kVA. Real power (kW) cannot be converted to apparent power (kVA) and vice versa. When using any formula, define the unit before using it.
  • Assuming the power factor is always fixed. Power factor is dependent on load. The partial load motor power factor is less than the full load motor power factor. Always measure under operating conditions.
  • Forgetting the √3 factor for the three-phase. The 3-phase power formula has a multiplier of 1.732 (or √3). Its omission results in an answer that is much lower than what would actually occur — a common and expensive error in electrical engineering calculations.
  • Overcorrecting the power factor. Large amounts of capacitance can cause the power factor to be leading (greater than 1.0 in some measurement systems), resulting in voltage rise and resonance problems. Target 0.95–0.98, not 1.0.
  • Using nameplate data instead of measured values. Nameplate ratings are for normal operating conditions at full load. Actual operating power factor depends on the real load; never take a guess.
Quick Reference: Power Factor Formulas at a Glance
Formula
Expression
Use
Basic power factor
PF = P / S
From real and apparent power
AC power factor
PF = cos(φ)
From the phase angle
Single-phase real power
P = V × I × PF
Calculate real power
Three-phase real power
P = √3 × V × I × PF
Three-phase circuits
Apparent power
S = V × I
Single-phase
Three-phase apparent power
S = √3 × V × I
Reactive power
Q = √(S² − P²)
From S and P
PF correction capacitance
Capacitor bank sizing
Formula of power factor
PF = cos(arctan(Q/P))
From reactive and real power
Power factor is at the core of AC electrical efficiency, and it links real power, apparent power, and reactive power into a single measurement that quantifies the efficiency of a power system in converting electrical energy into useful work. The formulas in this guide provide all the tools needed for calculating power factors for a single-phase home circuit, as well as for sizing a three-phase power factor correction bank on a commercial installation.
The bottom line for the homeowner: When reading battery storage specifications, knowing the difference between real power (kW) and apparent power (kVA) is essential to understanding what you're looking at and how you are using your electricity, and to selecting energy management solutions that will give you real energy savings. One of the easiest ways to make your home more energy efficient is to install a solar battery system and a high-quality inverter to minimise reliance on the grid and keep the electricity running and clean. Our energy-saving tips guide will go through a few more tips on how to conserve electricity around the house.
What is the formula for power factor?
The basic formula for power factor is PF = P / S, where P is real power in watts (W), and S is apparent power in volt-amperes (VA). It can also be expressed as PF = cos(φ), where φ is the phase angle between the voltage and current waveforms in an AC circuit.
How do I calculate power factor in an AC circuit?
Measure the real power (W) using a power meter and the apparent power (VA) by multiplying the RMS voltage by the RMS current. Divide real power by apparent power: PF = P / S. Alternatively, measure the phase angle φ between voltage and current waveforms and calculate PF = cos(φ).
What is the power factor correction formula?
The formula for power factor correction is Q_c = P × (tan φ₁ − tan φ₂), where Q_c is the reactive power of capacitors needed (in kVAR), P is the real power load (in kW), φ₁ is the phase angle at the current power factor, and φ₂ is the phase angle at the target power factor. This gives the capacitor bank size required to improve the power factor to the desired level.
What is the 3-phase power factor formula?
The 3-phase power factor formula for real power is P = √3 × V × I × PF, where V is the line voltage (400V in the UK), I is the line current per phase, and PF is the power factor. For apparent power in a three-phase system, S = √3 × V × I.
What is the difference between real power, apparent power, and reactive power?
Real power (P, in kW) is the power that does useful work — heating, lighting, or driving a motor. Apparent power (S, in kVA) is the total power drawn from the supply, including both useful and non-useful components. Reactive power (Q, in kVAR) is the portion that oscillates between the supply and inductive or capacitive loads without doing useful work. Power factor is the ratio of real to apparent power: PF = P / S.
Home Solutions
