Photovoltaic Panel Dimensions: Complete Size, Cost & Buying Guide for UK Homes
One of the first steps you will need to take when considering installing solar panels on your home is deciding how many panels are needed for the solar system. While not as glamorous or exciting as the benefits of solar panels, panel dimensions, roof orientation, and structural load are all factors in whether a solar system can work for your property.
In this guide, you'll learn all about photovoltaic panel sizes, dimensions, photovoltaic panel costs in the UK, the size of photovoltaic panels on a roof, and pairing them up with a home battery storage system for optimum return.
What are photovoltaic panels, and why do dimensions matter?
Photovoltaics, or PV panels, use semiconductor cells, usually silicon, which give off electrons when the solar energy is absorbed by the PV cells. For more details on the science, read about how photovoltaic cells work in simple terms. That flow of electrons turns into direct current (DC) electricity, then an inverter is used to turn that into alternating current (AC) electricity that you can use in your home.
There are several reasons why dimensions are important in practice. The number of panels that can be installed on a particular roof surface depends on the size of the panels. The larger the panels, the greater the potential power yield, but they are also heavier and will place a greater strain on the roof structure. Smaller panels can fit in niche spaces or odd areas, but typically need more panels to produce the same overall output.
When properly planned, you won't have to end up with a system that doesn't perform up to expectations due to not having enough panels (or one that exceeds your roof's load-bearing capacity without knowing it).
Standard photovoltaic panel dimensions and sizes
Photovoltaic panel sizes — Full overview
Residential photovoltaic panels have become fairly standardised over the last decade, though there's still meaningful variation across manufacturers and product ranges.
The most common residential panel size in the UK is approximately 1,700mm × 1,000mm (roughly 1.7m²), with a thickness of around 35–40mm. This applies to most 350W–450W monocrystalline panels — the type used in the vast majority of UK home installations.
Here's a broad overview of photovoltaic panel sizes across different categories:
Panel type
Typical dimensions
Typical wattage
Common use
Standard residential
1,700 × 1,000mm
350–450W
Home rooftop
Large residential/commercial
2,000 × 1,000mm
500–600W
Larger roofs, commercial
Small/compact
800 × 670mm
100–200W
Sheds, outbuildings, off-grid
12V panels
350–670 × 350–540mm
10–100W
Caravans, boats, off-grid
Thin-film
Variable
Variable
Flat roofs, specialist use
The weight of a standard residential panel typically falls between 18 and 22kg. Over a full installation of 10–12 panels, that's 180–264kg of additional load on your roof — which is why a structural survey is an important step before installation.
Small photovoltaic panel dimensions and uses
The use of small photovoltaic panels (100-200W) with a smaller size is for other applications than the common residential photovoltaic panels.
Small photovoltaic panels are typically 670mm × 550mm (for a 100W panel) to 1200mm × 550mm (for a 150-200W panel). They are also easier to handle, more lightweight, and don't have to be constructed in the same way as full-size panels.
In areas where a small panel is appropriate:
  • Garden sheds and outbuildings — powering lighting, tools, or security cameras off-grid
  • Greenhouses — running ventilation fans or small heating elements
  • Campervans and motorhomes — providing charging power for leisure batteries
  • Supplementary installations — filling odd-shaped roof sections that won't accommodate standard panels
  • Educational or trial setups — learning how solar works before committing to a full installation
Small panels are not the best solution for providing the power for an entire house — it would require a lot of panels to have a sufficient power output. Whole-home standard residential panels are always more cost-effective per watt.
12V photovoltaic panel sizes and applications
A particular type of photovoltaic module, which is a 12V photovoltaic module, is used to charge 12V battery systems with no mains inverter in the circuit. They're compact, lightweight, and built for mobile or off-grid applications.
Typical 12V panel dimensions:
  • 10W: approximately 350 × 200mm
  • 20W: approximately 440 × 350mm
  • 50W: approximately 600 × 350mm
  • 100W: approximately 1,020 × 670mm
The biggest use for 12V photovoltaic panels is caravan and campervans, narrowboats, garden lights, remote security cameras, water pumps, and gates in agriculture. If the application is more than a few hundred watts, a 12V system is not advisable because of the higher currents involved, and a 24V or 48V system is better at higher powers.
Solar photovoltaic panel sizes for commercial use
In a commercial photovoltaic installation, the panels are larger so that the output is maximised for each installation. The standard commercial panels are around 2000mm×1000mm in size and have an output of 500-600W per panel.
Commercial panels are designed to be installed in large arrays on flat or low-pitch roofs. In most UK homes, commercial-scale panels provide no practical benefit, are more difficult to manage, might not fit domestic roof pitches, and the additional wattage produced is not warranted with extra maintenance.
Photovoltaic panels and roof compatibility
Installing photovoltaic panels on your roof isn't just a matter of square footage. There are several considerations that have to be taken into account when assessing the suitability of a roof for solar.
Orientation. In the UK, roofs with a south-facing aspect get the most steady exposure to sunlight during the day. East or west-facing roofs will yield less but still work. However, panels for roof installations are not usually installed on north-facing roofs since they do not receive enough direct sunlight to offset the cost of the panels.
Pitch angle. The best angle for photovoltaics in the UK is about 30-40 degrees, which is the angle of a lot of traditional British roofs! Tilted mounting frames can be used with flat roofs. Very steep roofs (greater than 50 degrees) are not recommended for output reasons and for installation complexity.
Available area. The average 400W household panel area is 1.7m². Say you have a 4kW house system, 10 panels will then be needed, taking up about 17m² of roof space. Any space lost through skylights, chimneys, roof vents, or access for maintenance also decreases the available space.
Structural load. Each panel, as mentioned above, contributes 18-22kg. Your installer should make sure the roof is able to hold up the extra weight, which is especially crucial for any properties that have a concern with roof or for older properties.
Shading. Just partial shadowing due to nearby trees, a chimney, or an aerial can drastically lower the output from an entire string of panels. This can be addressed by some modern systems, such as microinverters or optimisers, but shading needs to be carefully taken into consideration before deciding on a layout.
Planning permission. In England, the majority of solar panel installations on a home are allowed development and don't need to be planned for, with a couple of requirements. Restrictions may apply to listed buildings and conservation areas. For properties that do not have an appropriate roof or flats, balcony solar panels are growing in popularity.
Note: Planning permission rules and permitted development criteria are subject to change. Always check the latest guidance from your local planning authority or refer to the Planning Portal before installation.
Photovoltaic panels cost and price guide for UK homes
The cost of the photovoltaic panels you can expect to pay will vary according to several factors:
Panel technology. Monocrystalline panels are more efficient, but more costly than polycrystalline. The highest quality monocrystalline solar panels, featuring the most modern cell technology (TOPCon, HJT), are not only more expensive, but they are also more efficient, especially in low-light conditions.
Wattage. The higher the wattage, the more it is going to cost per panel, but often less per watt, so a 400W panel is going to be more cost-effective than two 200W panels to produce the same amount of power.
Brand and warranty. Better-known manufacturers tend to have Tier 1 performance warranties and will be more expensive than lesser-known manufacturers. Warranty is important — a good quality manufacturer with a 25-year performance warranty is more important to you than a lower price from a brand that might not be around in 10 years.
Installation complexity. Installation cost is increased due to difficult access to roofs, non-standard mounting requirements, and distance from the consumer unit.
Cost of photovoltaic panels UK — Typical ranges
The cost of photovoltaic panels that UK homeowners typically pay varies by system size:
System size
Typical panels
Estimated installed cost
3kW
7–8 panels
£5,000–£7,000
4kW
9–10 panels
£6,000–£9,000
6kW
14–15 panels
£8,000–£12,000
10kW
22–25 panels
£14,000–£20,000
Important disclaimer: These figures are indicative estimates based on typical UK market pricing at the time of writing. Solar panel costs vary significantly by region, installer, panel brand, roof complexity, and current market conditions. Always obtain multiple quotes from MCS-certified installers. Prices are subject to change and should not be relied upon for budgeting without current supplier quotes.
Photovoltaic panels calculator — How to estimate your costs and savings
A photovoltaic panel calculator can be used to calculate the cost of a photovoltaic system, as well as the savings that can be realised over time.
In most cases, you'll need to enter:
  • Postcode (impacts solar irradiance calculations)
  • The energy that you use each year (based on your energy bills). This will be in kWh)
  • The angle of your roof and its direction.
  • The unit rate for electricity that you're paying.
The calculator will provide the following: how much electricity your system would produce, how much you would use in your home, how much you may export to the grid under the Smart Export Guarantee and a rough estimated payback period.
Note: Calculator results are estimates based on modelled data. Actual generation will vary depending on weather, shading, panel degradation, and usage patterns. Treat estimates as indicative rather than guaranteed.
Best solar photovoltaic panels for UK homes
For standard UK home rooftops: Tier 1 monocrystalline 380-430W PV modules. Seek low-light performance ratings, since the UK weather tends to be cloudy.
For limited roof space: High efficiency panels (21% efficiency and above) generate more electricity per square metre than others for limited roof space. If you have limited space, it is worth it to spend more for a more efficient product.
For flat roofs: Typical panels installed on inclined frames (30-35 degrees). On flat roofs with light-coloured roof surfaces, bifacial panels may provide a slight performance benefit due to reflected light being captured from the roof surface.
For off-grid or outbuilding use: Small photovoltaic panels (100W – 200W) with a leisure battery and charge controller for use in outbuildings or off-grid.
Solar photovoltaic panels UK — What to look for when buying
The solar photovoltaic market in the United Kingdom provides numerous choices of solar photovoltaic panels at a variety of prices. Before signing on, here are some of the important features to look out for:
MCS certification. To benefit from the Solar Grant Schemes and the Smart Export Guarantee (SEG), you must have an MCS-certified installer. Never assume certification; sign a contract.
Panel warranty. You should see a 25-year linear performance warranty that ensures the panel will have at least 80-85% of its rated output after 25 years. Look at the product warranty (usually 10-15 years) for manufacturing defects as well.
Temperature coefficient. A lower temperature coefficient (such as -0.30 per cent per degree C) indicates that the panel has less efficiency drop on hot days. Not as much of an issue in the UK, but it's worth comparing.
Low-light performance. It is given as an efficiency under standard test conditions and performance at low irradiance (200 W/m²). This is particularly relevant in the UK compared to almost any other country.
Key features to compare before buying
In the comparison of solar PV panels that UK suppliers provide, these are the things that are worth taking into consideration:
Efficiency rating. This is an indication of the percentage of sunlight hitting the panel that is turned into electricity. The higher the efficiency, the more power you will be able to produce from the same roof space, which is especially crucial if your available roof space is small.
Wattage at standard test conditions (STC). This is the amount this panel is rated to produce in a controlled laboratory environment. The actual production will be slightly less, but it was the benchmark to compare panels.
Low-irradiance performance. Expressed as efficiency at 200 W/m² irradiance. This is especially important in the UK, as only a small proportion of the days are sunny enough to use the solar panel to its best capacity, and a good panel will generate more electricity usefully on cloudy days when the sun is not at its peak.
Temperature coefficient. As a panel gets hotter, the efficiency or effectiveness of its use decreases. A lower tempco (e.g., -0.30% per °C) translates to less performance degradation during warmer days.
Product warranty. Covers manufacturing defects – usually 10-15 years. This is your safety feature in case of early failure of the panel.
Performance warranty. Forces the panel to deliver at least a certain percentage of its rated output over 25 years — typically 80-85%. Don't be afraid to pay extra for a good performance warranty from a company with a good financial background.
Manufacturer track record. The 25-year warranty is only a promise as long as the manufacturer remains in business for 25 years. Stay with known Tier 1 manufacturers that have a history of being on the market.
Pairing photovoltaic panels with home battery storage
Without solar battery storage, any solar electricity you generate but don't immediately use either gets wasted or exported to the grid via the Smart Export Guarantee. SEG rates are typically much lower than the unit rate you pay for grid electricity, so exporting is significantly less valuable than using the power yourself.
A home battery stores that excess electricity for later in the day—whether to power your evening appliances, charge your devices overnight, or get you through the next morning before the sun rises to use later. This significantly raises the percentage of solar electricity a typical UK household consumes, the main source of savings on bills.
A battery system is also resilient to a certain extent — in the event of a power failure, a battery system can keep providing power to your home when the grid is down.
Best solar battery solutions for UK homes
EcoFlow STREAM Ultra X Home Solar Battery
The STREAM Ultra X is a home inverter-based solar battery, which can be directly installed in a home's electrical circuit. It is charged by solar during daylight hours and provides power to your appliances during the night, which means that the appliances are solar-powered and not from the grid.
Up to 2,300W AC output in dual-unit configuration 2,000W solar input with 4 MPPTs and Low-Light Cells — captures useful energy even on cloudy days Expandable from 3.84 kWh up to 23 kWh by adding extra batteries 15-year lifespan with high safety standards Compatible with Tiber, Matter, and Shelly smart home protocols Save up to £1,729 annually on electricity bills
4×400W Rigid Solar Panel + STREAM Ultra — Best for Higher Output
This package includes four rigid 400W solar panels and the STREAM Ultra battery system for homes with greater energy needs or for those seeking to generate as much electricity as possible from the solar panels. A four-panel system would produce a lot more power than a two-panel system, especially from the summer heat or from a well-oriented south-facing roof.
Higher solar generation with four 400W panels — well-suited for larger homes STREAM Ultra handles grid connection and intelligent energy management Compatible with EcoFlow's full STREAM expansion range Slash up to £963 off your electricity bills AI-driven monitoring and control via the EcoFlow app Works seamlessly with over 99% of solar panels on the market
Common mistakes when choosing photovoltaic panel sizes
Choosing panels based on price alone. The lowest cost panel per watt may not necessarily be the best option. Unbranded, low-efficiency panels can wear out more quickly than others, perform less well in low-light situations, and be harder to support under warranty.
Not accounting for roof losses. Always, the usable portion of the roof surface is less than the total roof surface. The decrease in space is due to the chimneys, vents, skylights, and other required access areas. Design for the actual usable area, not the roof size.
Ignoring shading. Partial shading due to a small shade object can significantly affect the performance of an entire string of panels. If there is no way to avoid shading, talk to your installer about using microinverters or power optimisers.
Oversizing the system for your consumption. Since less electricity will be saved or consumed, much of the electricity produced by a larger system is exported at low SEG rates. Match the system size with the real consumption and storage requirements.
Underestimating roof structural requirements. Always ensure a structural assessment has been performed before installing, especially on older buildings. This is a much larger issue than a missed opportunity for solar when the installation compromises roof integrity.
Not checking installer credentials. Use only MCS Certified Installers. It is necessary to gain access to the Smart Export Guarantee and most grant schemes, which will act as a safety net, should something go wrong.
The size of the photovoltaic panels is the first step in any solar planning discussion — but not the last. The feasibility of a solar installation and the amount of savings you can expect depend on some factors, including roof orientation, available roof space, structural load, solar panel technology, and battery storage.
The UK solar market has come a long way. It's now much easier to obtain quality panels, costs have decreased, and storage has become more viable, meaning that storing the electricity generated by your solar panels, instead of selling it off cheaply, is becoming more practical for the average home.
If you're planning to buy a solar power system, you should read our guide to solar panels and battery storage along with this article. Start with the roof. Know the principles of what will fit, what is facing the correct direction, and what your structure can support. Thereafter, select panels based on the space and consumption areas. Seriously, think about battery storage from the get-go — it's the difference between a system that produces electricity and a system that saves you money.
  1. What are standard photovoltaic panel dimensions?
The most prevalent residential PV module size in the UK is about 1,700 x 1,000mm, roughly 35mm thick, and 18-22kg. The majority of “350 to 450W” monocrystalline panels installed in homes have this. Usually, commercial panels have dimensions of around 2000mm × 1000mm.
  1. How many solar photovoltaic panels do I need for my UK home?
The average UK home uses around 3,500 kWh of electricity per year. Under typical UK conditions, a 4kW system (typically 9-10 panels of 400W) will produce around 3,400 – 3,800 kWh per year, which represents a large proportion of the average household consumption. Bigger systems will be useful for larger homes or those with EVs or heat pumps.
  1. What is the cost of photovoltaic panels in the UK?
The costs of a fully installed 4kW PV system are likely to be between £6,000 and £9,000 in the UK, depending on the type of solar panels, the complexity of the roof, and the installer. The more power, the more expensive the system is, but the less expensive per kilowatt. Never rely on the first quote, and make sure to see if there are any grant schemes available at purchase time (which may vary).
  1. Can small photovoltaic panels power the whole home?
Not practically. Small PV panels (100W to 200W) are not intended for home power, but can be used off the grid or in addition to existing power systems. The 3500kWh per year required by a typical UK home would require many more small panels than typical home panels, making them more space-efficient and cost-effective for home use.
  1. What size photovoltaic panel do I need for my roof?
The first step is to assess the amount of roof space available (south-facing roofs without chimneys, vents or shade). To determine the max number of panels that will fit, divide by the number of square metres of a standard residential panel, 1.7m². Multiply by the panel wattage of your choice to determine the total capacity of the system. A qualified MCS-certified installer can conduct a proper roof survey and make an accurate roof layout recommendation.
Home Solutions
