Electric Outdoor Grills: Best Picks & Buying Guide for 2026
Electric outdoor grills have become a go-to choice for convenient, smoke-free cooking in gardens, balconies, and campsites. They offer quick heat-up times, precise temperature control, and easy maintenance—making them ideal for both beginners and seasoned grill enthusiasts. For off-grid cooking or outdoor adventures, portable power stations add an extra layer of flexibility, allowing you to run electric grills anywhere without relying on fixed power sources. In this guide, we explore the best models for 2026 and what to consider before choosing the right electric grill for your needs.
How do outdoor grills work?
An electric grill outdoors works by using electricity to heat a metal element placed inside the grill. When the grill is plugged into a power source and turned on, the heating element becomes hot and transfers heat to the cooking surface. It helps cook food evenly without using charcoal, wood, or gas.
In practice, an electric grills outdoors provide a simple and clean way to prepare food in open spaces such as patios, balconies, gardens, or campsites where electricity is available. For example, the heated grill plate or grate cooks the food directly, while the lid helps keep heat inside for faster and more even cooking. This makes outdoor electric grills a convenient choice for people who want easy grilling with less smoke and less mess.
How to choose the best outdoor electric grill?
To choose the best electric BBQ grill in the UK, it is important to understand the features that affect performance and durability. Knowing the size, heat control, and power helps in selecting the right grill for your cooking needs. Here are the key aspects to consider when choosing the best outdoor electric grills.
Cooking power and wattage
A higher wattage grill heats up faster and cooks food more evenly. Typical outdoor electric grills range from 1200W to 1800W for portable models, 1500W–2000W for tabletop grills, and up to 2200W for patio or built-in models.
Recommendation: Choose 1500W+ for families or when cooking meat, fish, and vegetables simultaneously. Lower wattage models (~1200W) are ideal for solo or camping use.
Cooking surface size
The size of the grill plate decides how much food you can cook at once comfortably. Bigger surfaces are better for families, friends, or parties, while small grills suit solo or couple use. Pick a size that matches the number of people you usually cook for regularly.
Compact / camping grills: ~145–200 sq in (~930–1,300 cm²), fits 2–4 people.
Tabletop grills: ~200–280 sq in (~1,300–1,800 cm²), suitable for small family meals.
Patio / large grills: 300–500 sq in (~1,900–3,200 cm²), perfect for 6+ people or parties.
Tip: Measure your usual serving needs—larger surfaces avoid repeated batches.
Temperature control and heat distribution
Adjustable temperature settings give you better control over cooking different foods. Even heat across the grill prevents food from accidentally burning in some spots. Look for outdoor electric grills that keep the heat steady for perfect and consistent results every time.
Portable / camping: simple 2–3 temperature settings (120–200 °C).
Tabletop / patio: precise adjustable thermostats, 100–250 °C, sometimes with digital displays.
Material matters: Stainless steel or non-stick coatings conduct heat evenly; cast iron adds heat retention for searing.
Portability and design
A lightweight and compact grill is easy to move, carry, and store anywhere. Some designs include foldable legs or handles for maximum convenience outdoors. Choose a model that fits your space, lifestyle, and outdoor cooking plans perfectly.
Weight: Portable grills: ~2.5–6 kg; Tabletop: ~3–7 kg; Patio grills: 20 kg+
Dimensions: Portable: ~35×25×20 cm; Tabletop: ~50×30×25 cm; Patio: 90×50×50 cm
Tip: If you plan to use the grill at campsites or on balconies, check if it fits in your car or storage space.
Safety and easy cleaning
Grills with cool-touch handles and stable legs reduce accidents very significantly. Removable plates or drip trays make cleaning quick, simple, and much less messy. Prioritize grills that are safe, reliable, and easy to maintain for completely stress-free use.
Top 16 outdoor electric grills in 2026
With so many electric grills for outdoors available, choosing the right one can feel tricky. To make it easier, we've listed the top 16 grills in 2026 and highlighted their main features. This helps you quickly compare options and pick the grill that fits your outdoor cooking needs.
Portable electric grills
Portable electric grills are designed for convenience, combining compact size with reliable heating for outdoor cooking. They are ideal for patios, balconies, or campsites where electricity is available. Below, we highlight four popular portable electric grills outdoors to help you choose the right model for your needs.
Model | Power | Cooking Area | Key Features | Price (USD) | Best For |
Weber Q 2400 | 1560W | ~280 sq in | Large cooking space, consistent heat performance | 350–400 | Family cookouts, small patios |
Cuisinart CEG-980 | ~1500W | ~145 sq in | Telescoping stand, compact design | 130–180 | Beginners, picnics |
Artestia Portable Grill | 1800W | ~200 sq in | Fast heating, adjustable temp control | 150–200 | Quick outdoor meals |
Char-Broil Portable Grill | ~1500W | ~240 sq in | Locking lid, easy transport | 120–180 | Small gatherings |
Tabletop electric grills
Tabletop electric grills provide compact, convenient cooking solutions for patios, balconies, or indoor/outdoor use. They provide consistent heat and easy temperature control, making them ideal for small gatherings or family meals. Below, we present four popular tabletop electric grills based on the best outdoor electric grill reviews to help you select the ideal option.
ROVSUN Tabletop Grill | 1600W | ~200 sq in | Stainless steel body, removable drip tray | 100–150 | Balconies, small spaces |
Ninja Foodi 2-in-1 Grill | ~1760W | ~100–150 sq in | Grill + griddle combo, precise control | 180–250 | Versatile home cooking |
Elite Gourmet EMG-980B | ~1250W | ~140 sq in | Smokeless design, glass lid | 90–140 | Indoor/outdoor use |
George Foreman Fit Grill | ~1600W | Large surface | Even heating, variable temp | 150–220 | Family meals |
Electric barbecue grills for patios
Electric barbecue grills for patios are designed for convenient outdoor cooking with reliable heat and simple operation. They are well-suited for patios, decks, and backyard areas where a cleaner grilling setup is preferred. Here are four popular electric barbecue grills for patios to help you compare suitable options.
Model | Power | Type | Key Features | Price (USD) | Best For |
Kenyon Texan Built-In | ~1300–1500W | Built-in | Premium stainless steel, seamless install | ~1060 | Luxury patio setups |
Americana by Meco | 1500W | Freestanding | Foldable side tables, compact design | ~265 | Budget patio grilling |
Coyote 18" Electric Grill | 1300W | Pedestal | Stable base, even heat distribution | ~928 | Permanent patio use |
Blaze 21" Electric Grill | 1500W | Pedestal | Side shelves, large prep space | ~889 | Full outdoor cooking setup |
Compact electric grills for camping
Compact electric grills for camping are small, portable cooking devices designed to bring convenient grilling to outdoor adventures. They usually feature lightweight materials and efficient electric heating elements, making them easy to carry in backpacks or store in tents and RVs. Their compact size enables campers to cook meals without relying on charcoal or gas, providing a cleaner and safer cooking experience.
Model | Power | Size / Weight | Key Features | Price (USD) | Best For |
Weber Lumin Compact Electric Grill | ~1500–1800W | Compact, travel-friendly | High heat searing, premium build, small-space friendly | ~600–700 | Premium camping & van life |
CampGrill 2-in-1 Camping Electric Grill | ~1200–1500W | ~2.8kg | Built-in pan, non-stick surface, adjustable temp | ~60 | Simple campsite cooking |
Techwood 1600W Tabletop Electric Grill | 1600W | Lightweight | Fast heating, portable tabletop design | ~150–180 | Camping + picnic use |
Landmann Pantera Compact Electric Grill | 2000W | Compact body | Even heating, durable build, easy cleaning | ~200–300 | Frequent outdoor campers |
Portable power stations for electric outdoor grilling
Electric grills require a steady power supply for consistent cooking, especially during outdoor gatherings or camping trips. With EcoFlow portable power stations, you can easily run your grill anywhere without relying on traditional outlets. These stations provide reliable, portable energy, ensuring your meals are cooked perfectly every time. Here are two top options to enjoy hassle-free electric outdoor grilling wherever you go.
EcoFlow DELTA 3 Plus (1 kWh) for portable outdoor cooking power
The EcoFlow DELTA 3 Plus is a compact and powerful portable power station designed to run electric outdoor grills during outdoor cooking adventures. With a 1024Wh battery capacity, it provides enough energy to power small to medium electric grills, along with additional accessories such as lights, fans, or Bluetooth speakers.
One of its main advantages is the high power output, delivering 1800W of continuous AC power with a 3600W surge capacity. This ensures your grill maintains stable heat even for cooking, whether you're grilling burgers, vegetables, or sandwiches during camping or patio sessions.
The DELTA 3 Plus also supports ultra-fast recharging, reaching around 80% in approximately 45 minutes via an AC outlet. It can additionally be charged with solar panels or a car outlet, offering flexibility for remote locations or extended outdoor gatherings.
Power management is simple with multiple output ports, including AC outlets, USB-A, USB-C, and DC connections. The EcoFlow mobile app lets users monitor battery levels, track energy usage, and control power settings remotely, ensuring efficient energy use while cooking outdoors.
Best for: Portable outdoor cooking, small group grilling, camping trips, tailgating, or any situation where reliable off-grid power is needed for outdoor electric grills and accessories.
EcoFlow DELTA 3 Max Plus (2 kWh) for high-power outdoor grill setups
For outdoor cooking that requires running larger electric grills outdoors or multiple appliances simultaneously, the EcoFlow DELTA 3 Max Plus is an ideal solution. With a 2048Wh battery capacity, it can power high-wattage grills, heaters, or multiple small appliances for extended cookouts or backyard events.
The unit delivers 3000W continuous AC output with up to 6000W surge power, accommodating heavy-duty grilling needs and ensuring even cooking across large grill surfaces. Flexible charging options enable recharging via wall outlets, car outlets, generators, or solar panels, making it perfect for long outdoor gatherings.
High-input solar charging support keeps grills running even during extended outdoor events, while expandable battery capacity ensures enough stored energy for all appliances and accessories in multi-grill setups.
Multiple output ports, including AC, USB-A, USB-C, and DC, enable simultaneous use of several devices. The EcoFlow app enables monitoring of power levels, tracking energy usage, and adjusting settings remotely, helping manage energy efficiently during outdoor cooking.
Best for: High-power electric grilling, large backyard cookouts, outdoor parties, tailgating, and setups where multiple appliances or grills need continuous, reliable off-grid power.
How to use an electric barbecue?
To use an electric barbecue grill outdoor effectively, it's important to understand the basics of setup, heating, and safe operation. Proper preparation ensures even cooking, reduces risks, and makes cleanup easier. Following simple steps can help you enjoy delicious grilled meals every time.
Preheat the grill
Turn on the electric BBQ grills outdoors and enable them to heat for 10–15 minutes. This ensures the entire cooking surface reaches an even temperature. Preheating also prevents food from sticking and helps achieve perfect sear marks.
Prepare food
Marinate or season your meat and vegetables to enhance flavor. Let the ingredients reach room temperature before cooking. This helps them cook evenly, avoiding overcooked exteriors and undercooked interiors.
Oil the grill plate
Lightly coat the hot surface with cooking oil to create a non-stick layer. This step ensures food doesn't tear or stick while grilling. Proper oiling also improves searing and makes cleanup much easier afterward.
Grill the food
Place your food carefully on the hot grill, avoiding splatters. Use a lid if your grill has one to retain heat and cook more evenly. Flip or turn items halfway through to ensure both sides are cooked thoroughly.
Check doneness and serve
Use a thermometer to verify meats reach the proper internal temperature. Carefully remove cooked food from the grill to avoid burns. Let the meat rest for a few minutes, so juices redistribute, making them tender and flavorful.
How to clean an electric barbecue?
Cleaning an outdoor electric bbq grill properly keeps it safe, efficient, and long-lasting. Regular maintenance prevents grease buildup, avoids smoke, and ensures your next grilling session is hassle-free. Here are simple steps to remove even stubborn residue effectively.
Turn off and cool
Always turn off and unplug your electric BBQ before cleaning. Let it cool completely to avoid burns or electrical hazards. Cleaning a cooled grill also prevents damage to surfaces and makes residue easier to remove.
Scrub the grates
Use a stiff brush to remove grease, food particles, and leftover residue from the grates. This keeps the cooking surface clean and ensures even cooking next time. Regular scrubbing also helps extend the life of your outdoor grills electric.
Wipe down the grill
Remove the BBQ plate and use a damp cloth to clean the remaining surfaces. Focus on corners, edges, and areas with grease buildup. Thorough wiping maintains performance and prevents residue from affecting future grilling.
Reassemble and oil
Reassemble the grill and lightly coat the grates with cooking oil. This prevents rust and creates a non-stick surface for your next session. Proper oiling keeps your BBQ in optimal condition for long-term use.
Tips for cooking with outdoor electric grills
Cooking delicious meals with outdoor electric grills requires more than just turning on the power. It involves understanding temperature control, preparing ingredients properly, and using simple techniques for even cooking. Here are some practical tips to help you get the best results from your electric grill.
Preheat before cooking
Always preheat your electric grill for 10–15 minutes before adding food. This ensures the cooking surface reaches an even temperature for consistent results. Preheating also reduces sticking and helps create appealing sear marks on meats and vegetables.
Prepare ingredients properly
Marinate, season, or let your ingredients reach room temperature before grilling. Proper preparation enhances flavor and ensures the food cooks evenly throughout. This prevents the outside from overcooking while the inside stays underdone.
Use the right cooking tools
Employ heat-resistant tongs, spatulas, and brushes for safe and efficient handling of food. Using the correct tools prevents accidental burns and protects the grill surface. Proper tools also make flipping, turning, and serving food much easier.
Monitor temperature and time
Adjust the outdoor grills electric temperature according to the type of food you are cooking. Keep an eye on cooking times to prevent burning or uneven cooking. Careful monitoring ensures tender, juicy, and perfectly cooked results every time.
Maintain clean grill surfaces
Clean the cooking plates and drip trays regularly after use or during long cooking sessions. Removing grease and residue improves flavor and prevents flare-ups. Regular maintenance also extends the life of your electric grill and keeps it ready for future use.
To summarize, choosing the right outdoor grills electric in 2026 is key for easy, safe, and delicious cooking. Considering factors like power, size, temperature control, and portability ensures the grill suits your needs perfectly. Pairing your grill with EcoFlow portable power stations enables you to cook anywhere without worrying about electricity, whether on a patio, campsite, or backyard. Top models provide fast heating, even cooking, and simple cleanup for stress-free grilling. Regular maintenance and proper use keep your grill working efficiently for years. Overall, combining the best electric grills with reliable EcoFlow power solutions guarantees enjoyable and convenient outdoor cooking anytime.
Do electric outdoor grills work?
Yes, electric outdoor grills work efficiently by using electric heating elements to cook food evenly without the need for charcoal or gas. They are easy to start, maintain consistent heat, and are ideal for balconies or patios where open flames are restricted. For remote outdoor use, a portable power station like EcoFlow DELTA 3 can provide the necessary electricity to run the grill safely and reliably.
What is the disadvantage of an electric grill?
The main disadvantage of an outdoor grill electric is that it requires a constant power source, limiting mobility compared to charcoal or gas grills. Some models may have lower heat output, affecting searing and flavor for certain foods. Using a portable solution like EcoFlow DELTA 3 can overcome power limitations, allowing outdoor grilling even in areas without direct electrical access.
Can electric grills be left outside in winter?
It is generally not recommended to leave electric grills outside in winter as exposure to moisture, frost, or snow can damage the electrical components and reduce the grill's lifespan. Proper storage in a covered area or garage helps maintain durability. For outdoor cooking during colder months, a portable power station like EcoFlow DELTA 3 ensures you have safe and consistent electricity wherever you set up your outdoor grills electric.
