KW in Joules: How to Convert Kilowatts to Joules & What It Means for Your Energy Use
- Why kW and Joules Matter More Than You Think
- What Is a Joule? Understanding the Basic Unit of Energy
- What Is a Kilowatt (kW)? Power vs Energy Explained
- KW in Joules — How the Conversion Works
- Practical Examples: KW to Joules in Real Life
- KW in Joules and Home Energy Storage — Why It Matters
- Quick Reference: KW to Joules Conversion Table
- Conclusion
- FAQs
The units of energy are baffling. Most people are familiar with the concept of a kilowatt, as it is found on the labels of all appliances and on all electric bills. But joules? A unit we've not considered since school, if ever. Yet joules, watts, kilowatts, and kilowatt-hours are all measuring the same thing: energy and the rate it flows, just in different ways.
Knowing a joule to a kW isn't just a school exercise; it's a real-life thing to know. It aids you in correctly reading battery storage specifications, deciphering solar panel output claims, and understanding what the electricity bill actually measures. If you are considering using home solar and storage solutions, these unit relationships are important.
These units are usually used without the knowledge of most. These are some of the most common real-world examples:
Electrical energy costs are reported in terms of kilowatt-hours (kWh). That is an energy unit, NOT a power unit. It informs you of the usage of energy for a billable period.
Power is indicated on the appliance label, either in watts (W) or kilowatts (kW). A 2kW kettle, a 1.5kW hair dryer, and a 100W light bulb. These indicate the speed at which the appliance consumes energy and not the overall consumption.
The specifications of solar panels will be in watts peak (Wp) or kilowatts (kW) and are again a measure of power. A 400W panel can generate up to 400 joules of energy per second under optimum conditions.
Battery storage systems are indicated in kWh (total amount of energy the system can store). A 3.84 kWh battery can store 3,840 watt-hours, or 13,824,000 joules of energy.
The joule is sometimes used directly with physics textbooks and technical specifications, especially in energy calculations involving small amounts or short periods of time.
Why Confusing kW, kWh, and Joules Leads to Real Mistakes
A confusion of these units can cause real mistakes that cost money or can result in wrong buying decisions.
Confusing kW with kWh: A 10kW solar panel system does not store 10kWh of energy; it can produce up to 10kW of power during peak hours, depending on the amount of sunshine it gets. A 10kW system could produce 30-50kWh of energy on a typical day in the UK.
Misreading battery capacity: Another frequent mistake is misreading battery capacity. A 5kW battery with a storage capacity of 10kWh is quite different from a 2kW battery with 10kWh of storage, as the latter can power appliances twice as long but store the same amount of energy.
Misunderstanding electricity bills: Confusion is caused when people misunderstand electricity bills while comparing tariffs. The unit of electricity is 1kWh, and this is equivalent to 3,600,000 joules. Knowing this will educate you on the real amount of energy you're paying for.
A Plain-English Map of Energy Units — Watts, Joules, kWh, and kW
Consider the units of energy to be a family of related units:
Joule (J) — the basic SI unit of energy. Small. The energy required to lift a small apple 1 metre up is about the same as 1 joule of energy.
Watt (W) — a rate of energy flow. One watt is equivalent to one J/second. Measures power, the rate at which energy can be used or produced.
Kilowatt (kW) — 1,000 watts. 1 kilowatt is equal to 1,000 joules per second. Appliance and power systems use.
Watt-hour (Wh) — unit of energy expended at a rate of one watt for 1 hour. Equals 3,600 joules (since there are 3,600 seconds in an hour).
Kilowatt-hour (kWh) — energy consumed at a rate of 1 kW for 1 hour. Equals 3,600,000 joules. This is part of the electricity meter.
The key sight: watts and kilowatts are units of power, which is the rate of energy flow. Energy (total amount) is measured in joules, watt-hours, or kilowatt-hours. Time is always required to convert from one to the other.
Named after physicist James Prescott Joule, the joule is the International System of Units (SI) base unit of energy. This is the amount of energy transferred by a force of magnitude one newton over a displacement of one metre.
In everyday terms:
Lifting a 100g object (small apple) 1 metre: ~ 1 joule
A single heartbeat: 1 joule of mechanical work.
A camera flash: 1J of electrical energy.
A cup of tea: ~130,000 joules (130 kJ) of heat energy
A 60W light bulb is used for 1 second: 60 joules
A joule is a suitable unit of measure for very short periods of time or very small amounts of energy. When talking about how many Joules of electricity are required for a household application (millions per day), we speak of kilowatt-hours instead, again because the numbers are more manageable.
How Joules Relate to Other Energy Units (Wh, kWh, Calories)
Unit | Equivalent in joules | Common use |
1 joule (J) | 1 J | Physics, small energy quantities |
1 watt-hour (Wh) | 3,600 J | Small battery capacities |
1 kilowatt-hour (kWh) | 3,600,000 J | Electricity bills, home storage |
1 calorie (cal) | 4.184 J | Nutrition (food energy) |
1 kilocalorie (kcal) | 4,184 J | Dietary energy (the "Calorie" on food labels) |
1 megajoule (MJ) | 1,000,000 J | Industrial energy, gas billing |
1 British Thermal Unit (BTU) | 1,055 J | Heating systems |
The conversion between joules and kilowatt-hours is the most practical for home energy purposes: 1 kWh = 3,600,000 J = 3.6 MJ.
The Difference Between Power (kW) and Energy (kWh, Joules)
This distinction is initially confusing for virtually everybody, but it becomes easy once you have the correct analogy.
Consider a tap that fills a bath. Power is similar to the flow rate of the tap — that is, the rate at which the water is moving at any given time (litres per minute). Energy is the quantity of water in the bath after a specific time (litres over time).
One kilowatt is a measure of power. It indicates how much energy is being consumed or produced. A kilowatt is 1,000 joules per second — the energy that flows at a rate of 1,000 joules every second.
A kilowatt-hour is a measure of energy. It is used to indicate the overall amount of energy consumed or produced during a given period of time. A kilowatt-hour is the amount of energy that a 1000-watt power source flows over a period of one hour.
Power × time = energy 1 kW × 1 hour = 1 kWh = 3,600,000 joules
Why This Distinction Matters for Home Energy Use
The distinction is important for many practical reasons:
If you're looking at solar panels, the kW rating is indicative of the maximum amount of energy that a panel can generate per hour, not per day. A 4kW system will produce about 3,400–3,800 kWh per year in the UK, depending on the site location and orientation.
The kWh rating is a measure of the amount of storage, and not how fast it can be accessed, when comparing battery storage. A 10 kWh solar energy storage system and 3kW power generation system can supply a 3kW device with energy for approximately 3 hours or a 1kW device with energy for 10 hours.
If you're looking at your electricity bill, the price per unit (pence per kWh) indicates the cost of the energy equivalent to 3,600,000 joules. Multiply that by how much you use, and your bill is calculated.
The Conversion Formula Explained
The relationship between kW and joules always involves time, because kW is a unit of power and joules is a unit of energy.
The fundamental relationship:
1 kW = 1,000 watts = 1,000 joules per second
This means a device rated at 1kW uses 1,000 joules of energy every second it's operating. Over two seconds, it uses 2,000 joules. Over one minute (60 seconds), it uses 60,000 joules. Over one hour (3,600 seconds), it uses 3,600,000 joules, which is 1 kWh.
The conversion formula from kW to joules:
Energy (J) = Power (kW) × 1,000 × Time (seconds)
Or equivalently:
Energy (J) = Power (W) × Time (seconds)
How Many Joules Are in 1 kW?
This is where time dependency becomes important. Strictly speaking, 1 kW is not a fixed number of joules — it depends on the time period.
1 kW for 1 second = 1,000 joules
1 kW for 1 minute = 60,000 joules
1 kW for 1 hour = 3,600,000 joules (= 1 kWh)
When people ask "how many joules in 1 kW," they usually mean: how many joules per second? The answer is 1,000 joules per second. That's the rate of energy flow at 1kW of power.
How Many Joules in a kW — Worked Examples
Example 1: A 2kW electric heater running for 30 minutes energy = 2,000W × (30 × 60 seconds) = 2,000 × 1,800 = 3,600,000 joules (= 1 kWh)
Example 2: A 400W solar panel generating for 5 hours energy = 400W × (5 × 3,600 seconds) = 400 × 18,000 = 7,200,000 joules (= 2 kWh)
Example 3: A 3.84 kWh home battery is fully charged. Energy stored = 3.84 × 3,600,000 = 13,824,000 joules
Example 4: 1 kW for exactly 1 second Energy = 1,000 W × 1 s = 1,000 joules
Joules in kW — Converting Back From Joules to Kilowatts
To convert from joules back to kilowatts, you need to know the time period over which the energy was transferred:
Power (kW) = Energy (J) / (1,000 × Time in seconds)
Example: A device uses 180,000 joules over 3 minutes (180 seconds): Power = 180,000 / (1,000 × 180) = 180,000 / 180,000 = 1 kW
The joule in kW conversion always requires dividing by time — you cannot convert joules to kilowatts without knowing the duration.
How Many Joules Does a Typical Home Appliance Use?
Appliance | Typical power | Energy per hour | Energy per hour in joules |
Kettle | 2,000–3,000W | 2–3 kWh | 7,200,000–10,800,000 J |
Washing machine | 1,500–2,500W | 1.5–2.5 kWh | 5,400,000–9,000,000 J |
Refrigerator | 100–200W | 0.1–0.2 kWh | 360,000–720,000 J |
LED bulb | 8–12W | 0.008–0.012 kWh | 28,800–43,200 J |
Electric oven | 2,000–3,500W | 2–3.5 kWh | 7,200,000–12,600,000 J |
Laptop | 40–80W | 0.04–0.08 kWh | 144,000–288,000 J |
These figures illustrate why kilowatt-hours — rather than joules — are used for household energy. The numbers in joules become unwieldy for everyday appliances.
Joules and kW in Solar Panels and Battery Storage
Solar panels are rated in watts peak (Wp) — the maximum power output under standard test conditions. A 400Wp panel generates 400 joules per second at peak output, or 1,440,000 joules (0.4 kWh) over one hour at peak generation.
In practice, UK solar panels achieve around 850–1,100 full-load hours per year. A 400W panel would generate approximately: 400W × 1,000 hours = 400,000 Wh = 400 kWh = 1,440,000,000 joules per year
Solar battery storage systems are rated in kWh — the total joules they can store are divided by 3,600,000. A 3.84 kWh battery stores 13,824,000 joules of electrical energy, which it can release at a rate determined by its power output rating (kW).
Using Conversion to Understand Your Electricity Bill
Your electricity bill charges you per kWh — per 3,600,000 joules of energy. If you're curious about typical household consumption figures, our guide to average electricity usage in the UK gives a useful benchmark. At a typical UK unit rate of around 24p per kWh, you pay approximately 24p for 3.6 million joules of electrical energy.
To find the cost of running any appliance:
Find its power rating in watts (W)
Decide how long you'll run it (hours)
Calculate kWh = (W × hours) / 1,000
Multiply by your unit rate in pence
Example: Running a 2,500W electric shower for 8 minutes (0.133 hours): kWh = (2,500 × 0.133) / 1,000 = 0.333 kWh Cost = 0.333 × 24p = approximately 8p per shower
How kW and Joules Are Used in Home Battery Storage Systems
Home battery storage systems are specified using two key metrics, and understanding both in terms of joules clarifies exactly what you're buying:
Power output (kW): How quickly the battery can release energy. A 1.2kW output means 1,200 joules per second available to your home's circuit. A 2.3kW output means 2,300 joules per second.
Storage capacity (kWh): Total energy the battery can hold. A 3.84 kWh battery holds 13,824,000 joules. A 23 kWh system (maximum expansion) holds 82,800,000 joules.
Runtime calculation: Divide storage capacity (kWh) by power demand (kW) to find runtime in hours. Example: 3.84 kWh ÷ 1.2kW = 3.2 hours at full output
Understanding these numbers in joule terms demystifies the specifications — you're simply asking how many joules the system stores and how many joules per second it can deliver.
Comparing Home Battery Systems Using Energy Metrics
The most useful metrics to compare home battery systems are power output (kW), storage capacity (kWh), and the ratio of power to storage. A system that has a high storage capacity but low output will be able to provide power for a long time for low-demand appliances. A high-output, moderate-storage system can operate heavy-use appliances for a shorter length of time.
Both systems mentioned have impressive power generation capabilities and storage options, making them viable alternatives for households in the UK to store solar energy and lessen their reliance on the grid.
EcoFlow STREAM Ultra X — Home Solar Battery Storage
The STREAM Ultra X is an integrated solar battery that is designed for home use. Each unit contains 3.84 kWh (13,824,000 joules) and can provide up to 1,200 watts (1,200 joules per second) of continuous power. In dual-unit mode, the output is increased to 2,300W while storage capacity is increased to 7.68 kWh (expanded up to 23 kWh with additional batteries).
Key specs and benefits:
Up to 2,300W AC output in dual-unit configuration
2,000W solar input with 4 MPPTs and Low-Light Cells
Expandable from 3.84 kWh up to 23 kWh
15-year lifespan with high safety standards
Compatible with Tiber, Matter, and Shelly smart home protocols
Flexible indoor placement — units sit independently, no stacking required
EcoFlow STREAM Ultra X All-in-One Home Storage Kit
Full Solar and Storage solution, including panels, battery, and hardware. The EcoFlow app provides real-time monitoring of energy generation, storage, and consumption, all in kW and kWh, offering a direct view of the energy flows in the home. Easy to set up and no hassle with any building activity.
Key benefits:
Complete system — panels, battery, and hardware included
Built-in inverter, straightforward installation
Real-time monitoring and AI-driven energy management via app
Expandable storage as energy needs grow
Works seamlessly with over 99% of solar panels on the market
Power | Time | Energy (joules) | Energy (kWh) |
1 kW (1,000W) | 1 second | 1,000 J | 0.000278 kWh |
1 kW (1,000W) | 1 minute | 60,000 J | 0.01667 kWh |
1 kW (1,000W) | 1 hour | 3,600,000 J | 1 kWh |
2 kW (2,000W) | 1 hour | 7,200,000 J | 2 kWh |
3.84 kW (3,840W) | 1 hour | 13,824,000 J | 3.84 kWh |
10 kW (10,000W) | 1 hour | 36,000,000 J | 10 kWh |
0.4 kW (400W) | 5 hours | 7,200,000 J | 2 kWh |
2.5 kW (2,500W) | 30 minutes | 4,500,000 J | 1.25 kWh |
Key conversion factors:
1 kW = 1,000 joules per second
1 kWh = 3,600,000 joules (3.6 MJ)
1 joule = 0.001 watt-seconds = 0.000000278 kWh
To convert kWh to joules: multiply by 3,600,000
To convert joules to kWh: divide by 3,600,000
Understanding that kW is a measure of the rate at which energy is flowing makes the relationship between kW and joules very easy to understand. The conversions follow naturally from one kilowatt = 1,000 joules per second.
You won't work with joules day to day, such as when reading your electricity bill, comparing solar panels, etc., you will work with kW and kWh instead. However, if you know how the units relate to joules, you will have a better base to understand the numbers.
A 3.84 kWh battery-powered house stores almost 14 million joules of electricity. If you are looking for direct methods to decrease the number of those joules you have to purchase from the grid monthly, our energy-saving tips guide is a valuable read next. Over a trillion joules of energy would be recorded on your electric meter if your bill read 300 kWh for the month. The numbers are big — that's why it's standard practice to use kWh, but the joule is still there under all the numbers, keeping things just right.
How many joules are in 1 kW?
Strictly speaking, 1 kW is equal to 1,000 joules per second, which is a measure of power, or rate of energy flow, not energy. In a time of one second, 1 kW gives 1,000 joules. In one minute, 60,000 Joules. Over one hour, 3,600,000 joules (which equals 1 kWh). There must always be a time period for the conversion.
What is the difference between a joule and a kilowatt?
The joule is a unit of energy — it's a unit that measures a quantity of energy. A kilowatt is a unit of power — the rate at which energy is being generated or consumed (1000 joules per second). They measure the same type of things, but differently. They must be connected, and the relationship between them is energy (joules) = power (watts) x time (seconds).
How do I convert kW to joules?
Use the formula: Energy (J) = Power (W) × Time (seconds). First convert kW to watts by multiplying by 1,000, then multiply by the time in seconds. For example, 2kW running for 5 minutes: 2,000W × 300 seconds = 600,000 joules.
How many joules are in a kWh?
One kilowatt-hour equals 3,600,000 joules (3.6 megajoules). This comes from: 1 kW = 1,000 J/s, and 1 hour = 3,600 seconds, so 1 kWh = 1,000 × 3,600 = 3,600,000 joules.
Why does the kW to joules conversion depend on time?
You can't convert between a kilowatt and a joule since they are units of different physical quantities. A kilowatt is a measure of the rate of energy flow at a particular instant – similar to the speed of a car. A joule is a total amount of energy (e.g., distance travelled). To convert speed to distance, you need to know how long you travelled. Likewise, to calculate the number of joules from kW, you must know the time for which this power was flowing.
