How To Charge Laptop Without Charger: 6 Best Solutions
Have you ever worked outdoors on your laptop, only to see the battery drop fast and those low-power warnings start flashing, even though your work isn’t done yet?
Don't worry. This guide covers several easy ways on how to charge laptop without charger. From using a USB-C cable to an HDMI cord or other handy tools, these methods can help you get your laptop powered up again when you need it most. Keep reading!
How to Charge Laptop Without Laptop Charger?
Before trying to charge your laptop without its original charger, it helps to know how laptop charging works. Your laptop’s power adapter connects to a wall socket on one end and to your laptop on the other. It converts the electricity from your home into a safe level that your laptop battery can store.
With that in mind, alternative charging methods simply mean finding other safe ways to supply power to your laptop using compatible cables and devices.
Here are some practical ways to charge your laptop when you don’t have the original charger.
1. Use a USB-C Power Delivery (PD) Charger
One of the simplest ways to charge your laptop without its original charger is by using a USB-C to USB-C cable. Most modern laptops include at least one USB-C port. You can often find USB outlets in cafés, libraries, and hotels. Plug your laptop into the power source, and it should start charging.
Before you try this, check your laptop’s manual or online details to make sure it supports USB-C charging and Power Delivery, since not every model does.
2. Use a High-Capacity Laptop Power Bank or USB-C Power Bank
If you might not have access to a USB power outlet, carrying a reliable power bank can save you from running out of battery mid-task. Since laptops use much more energy than phones, it’s best to choose one with a high capacity and strong output that matches your laptop’s power needs.
A top choice is the EcoFlow RAPIDPro Power Bank (27,650mAh, 300W, 140W Built-in Cable). With a high-capacity 27,650 mAh battery, 300 W total output, and blazing-fast 140 W built-in cable support, you can charge a laptop quickly and even run cameras or tablets in tandem. The handy LCD display keeps you informed of remaining power, and the unit is flight-safe for easy travel.
EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable)
The EcoFlow RAPID Pro Power Bank (27,650mAh, 300W, 140W Built-in Cable) offers exceptional capacity in a compact, flight-safe size. With a built-in 60cm cable, there's no need for extras, and an intelligent LCD screen lets you monitor power levels at a glance.
If you want something lighter, the EcoFlow RAPID Pro Power Bank (20,000mAh, 230W, 100W Built-in Cable) is compact yet powerful. It supports fast 100W USB-C charging and recharges quickly, keeping your laptop ready during travel or outdoor work. Its portable size and smart power management make it perfect for daily use.
Use a lighter power bank to charge your laptop: the EcoFlow RAPID Pro Power Bank (20,000 mAh) weighs just 563.8 g and delivers a 230 W total output with a built-in 100 W USB-C cable and an intelligent LCD — enough to charge laptops, phones and game consoles on the go without the bulk.
Just note that charging through a power bank is usually slower than plugging into a wall outlet, so be patient.
3. Charge via Your Car or 12V/Lighter Socket
How to charge a laptop without the charger if you are driving? Your car can serve as a convenient charging source. Connect your laptop to the car’s USB port with a USB-C cable and start the engine. The car battery will power your laptop while the engine is running.
If your car has a 12V socket, you can use a power inverter for faster charging. Avoid charging for too long, as it might drain your car battery, and never leave it connected overnight.
Older vehicles without USB ports can still work. Simply use a USB adapter in the cigarette lighter socket to charge your laptop through a USB cable.
4. Charge with HDMI Cables
HDMI cables are often used for connecting laptops to TVs or monitors, but they can sometimes transfer power too. Connect your laptop to a powered device, such as a TV, using an HDMI cable. Some laptops can receive a small amount of power this way.
Not all laptops support HDMI charging, so check your model before trying this method.
5. Charge with a Phone Charger
If you have a phone charger with a USB-C port that supports Power Delivery (PD), you can also charge a laptop with a phone charger. Make sure you're using a high-quality USB-C cable, and be aware that charging will likely be slower and generate more heat than usual.
6. Use a Universal Laptop Charger
If you travel frequently, it's wise to carry a portable laptop charger with universal adapters. These are compatible across the UK, Europe, and the US, and can charge not only laptops but also phones and other electronics.
Common Mistakes and What to Avoid
When trying alternative ways to charge your laptop, safety should always come first. Avoiding a few common mistakes can protect both your device and yourself from damage or risk.
Ignoring Voltage Differences
Different regions and devices use different voltage levels. Plugging in an adapter with the wrong voltage can damage your laptop’s battery or internal components.
Before charging, check your laptop’s input voltage in the manual or on the power label, and make sure the adapter’s output voltage matches it exactly.
How to charge laptop without charger? You can try methods like USB-C PD chargers, car sockets, universal adapters, or HDMI connections, which can keep your laptop powered when no outlet is available.
Always check voltage limits and use certified, high-quality accessories to protect your device from damage. For longer use or multi-device charging, EcoFlow offers the best laptop power bank, built to deliver stable, high-capacity power wherever you work or study.
Can you charge a laptop with a USB?
Yes, you can charge a laptop with a USB cable, but only if it has a USB-C port that supports Power Delivery (PD). Many newer laptops have this feature, but older ones do not.
You’ll need a USB-C to USB-C cable and a PD charger or power bank. Plug it in, and your laptop should start charging.
How to charge a laptop using a phone?
Charging a laptop directly with a phone isn’t typically possible, as phones don’t deliver enough power to charge a larger device like a laptop. However, if you have a phone charger with a USB-C Power Delivery (PD) adapter, and your laptop supports USB-C charging, you can use that setup in emergencies.
Just connect your phone’s PD charger to your laptop using a compatible USB-C cable. Be aware that charging will be slow and may only maintain the current battery level rather than fully recharge it. Still, it can buy you some valuable extra time.
How do I charge my laptop with an HDMI cable?
You can sometimes charge a laptop with an HDMI cable, but it only works on certain models. Most laptops use HDMI to send video and sound, not power.
If your laptop and a TV or monitor both allow power through HDMI, you can try using an HDMI-to-USB adapter. Plug the HDMI end into the TV and the USB end into your laptop.
This will not fully charge your laptop. It only gives a small amount of power to slow down battery drain. Always check your laptop’s manual first to make sure it’s safe to do.
Power Banks
