How Much Does It Cost to Install an AC System in 2025?
As temperatures rise, having an efficient air conditioning system becomes a key factor in maintaining comfort for your home. In the UK, the demand for air conditioners is increasing, especially during the warmer weathers. However, with various types of systems available and installation costs to consider, many people wonder about the overall expenses involved. In this article, we’ll break down the costs of installing different air conditioning systems and what factors can influence the price.
How Much Does It Cost to Install an AC System?
When installing an air conditioning system in the UK, there are four main types to consider: split systems, ducted air conditioning systems, window units, and portable air conditioners. Each type comes with its own set of benefits, installation requirements, and costs. If you’re unsure which option suits your needs, you might want to explore a detailed comparison: portable air conditioner vs window AC unit.
Portable air conditioners don’t require installation; they can be easily set up right out of the box. Other types, however, do require installation, so the cost to install an AC system will include both the equipment and labor.
If you’re asking how much does an air conditioner cost to install, the price can vary significantly based on the system you choose. Below are some typical costs for each system.
Equipment Costs:
- Split System: £600 to £2,500
- Portable/Freestanding Air Conditioning: £150 to £400
- Window Units: £500 to £1,200
- Ducted Air Conditioning: £500 to £1,200
Labor Costs:
The average air conditioner installation cost for hiring an installer in the UK ranges from £150 to £200 per day. Depending on the equipment size and the complexity of the installation, contractors may work individually or in pairs. If they work in pairs, the daily cost can rise to around £300.
Installing window air conditioners typically takes a full day to ensure proper placement and secure fitting. For other air conditioning systems, installation is usually completed within half a day or less. Labor costs can differ across the UK, with areas like London often having higher rates compared to the north or other regions. If additional electrical work is necessary to accommodate the new system, this will also increase the overall installation cost.
Estimated Total Cost:
| AC Type | Equipment Cost | Labor Cost (Range) | Estimated Total Cost |
| Split System | £600 to £2,500 | £150 to £400 per day (1 day) | £750 to £2,900 |
| Portable/Freestanding AC | £150 to £400 | £0 (no installation) | £150 to £400 |
| Window Unit | £500 to £1,200 | £150 to £400 per day (1 day) | £650 to £1,600 |
| Ducted Air Conditioning | £500 to £1,200 | £150 to £400 per day (0.5-1 day) | £650 to £1,600 |
Factors Affecting the Cost of AC Installation
Your choice of air conditioning system and the size of your property are the primary factors that will determine the overall cost to install an air conditioner. However, several other elements can influence the price as well. Below, we’ve outlined some of the key considerations.
Air Conditioning System Type and Property Size
The type of air conditioning system you choose will directly affect the price. Larger homes require more powerful systems, which increases the air conditioning installation cost. For smaller spaces, such as a bedroom or office, a portable air conditioner can be a more cost-effective and convenient option. These units are ideal for compact spaces and can be easily moved to different rooms as needed. For an eco-friendly, efficient solution, the EcoFlow WAVE is a versatile portable air conditioner perfect for smaller areas. It also offers the flexibility of being powered by a generator during power outages, making it an excellent choice for off-grid locations.
If you live in a tiny house or plan to install a system in a limited space, you may also want to look into options for solar-powered systems. You might ask: Are solar air conditioners essential for small homes or off-grid setups? Increasingly, people now explore the possibility to install solar on tiny house, as it’s a great way to save on energy costs while reducing environmental impact.
Installation Site Access
If the location where the air conditioning system needs to be installed is difficult to access, the installation process will take longer, resulting in higher labor costs. This could involve tricky placements or ensuring your home is cleared and prepared in advance to streamline the installation process.
Electrical Work Needed
Before installing the system, some electrical work might be required, such as adding new wiring or outlets. This will add to the total cost to install an ac system.
Location and Regional Differences
Labor costs can vary depending on where you live. Areas like London or the South West of England typically have higher hourly rates for tradespeople due to the higher cost of living. In contrast, regions such as Scotland or the northern parts of England generally see lower installation costs.
Air Conditioning Maintenance and Repairs
Air conditioning systems don’t last indefinitely, and maintenance or repairs will eventually be necessary. Keep in mind that repairs can be expensive, and in some cases, you might need to replace major components of the system, affecting the long-term cost to install an AC system.
Do You Need a Professional to Install an AC System?
Are solar air conditioners worth it? Given the presence of refrigerants, it’s highly recommended to hire a registered gas safety engineer, plumber, or an air conditioning installation expert for the installation of permanent or semi-permanent systems. The chemicals involved in these systems can be toxic, and the installation process requires specialized knowledge. Therefore, this is not a task suited for DIY.
Installing an air conditioning system yourself can pose serious health risks and could jeopardize the safety of your property. Additionally, a DIY installation may void your home insurance policy, leaving you unprotected if anything goes wrong.
However, if you purchase a portable air conditioner, you can typically install it yourself. These units are usually standalone devices that only require plugging into a power source and adding water or ice. This makes them far simpler to set up without professional assistance.
Installing an air conditioning system can be a significant investment, but it offers numerous benefits, from improved comfort to increased property value. The cost to install an AC system depends on factors such as the type of system, property size, and location. Whether you’re choosing a split system, portable air conditioner, or window air conditioner, it’s important to factor in both equipment and labor costs to get an accurate estimate. Remember, hiring a professional for installation is crucial to ensure safety and efficiency. Ultimately, the right air conditioning system can provide long-term comfort and peace of mind, making it a valuable addition to your home.
How much does it cost to install an AC system?
The cost of installing an air conditioning system varies depending on the type of system and equipment required. In the UK, typical installation costs are as follows: Split System (£750 to £2,900), Portable/Freestanding AC (£150 to £400), Window Unit (£650 to £1,600) and Ducted Air Conditioning (£650 to £1,600). These costs include equipment and labor.
How long does it take to install an AC system?
Installation time varies based on the number of rooms served. For smaller installations this usually takes a few hours, but for larger installations this may extend to 1-2 days.
How much to install a 1.5 ton AC unit?
The typical cost to install a 1.5 ton air conditioning unit in the UK is between £1,000 and £2,500. This includes the cost of the equipment and installation fees, but the final price may vary based on brand, system type and installation complexity.
Is it worth it to install AC?
Installing an air conditioning system is a worthwhile investment, especially in areas with hot climates or during the summer. It improves comfort by providing continuous cooling, can improve indoor air quality, and increase property value. While the upfront cost may seem high, the long-term benefits, such as improved sleep, productivity, and health, often make it a smart decision for many homeowners.
