Best Angle for Solar Panels: Optimal Exposure
Better energy output relies on the angle of your solar panels. Though location affects the optimal tilt, it usually falls between 30° and 40°. Seasonal changes can boost efficiency even further by making sure panels year-round get the most sunshine. Knowing the best angle for solar panels lets you get the most out of your system, allowing for higher savings and better emergency preparedness.
Best Angle for Solar Panels in the UK
In the UK, solar panel angle is best at 30° to 40°. This tilt lets panels have better sunlight exposure throughout the year, increasing efficiency and energy output. Geographic location affects the ideal angle; dwellings further north need somewhat steeper tilts.
Seasonal variations can impact efficiency. A lower tilt of about 20° is the best angle for solar panels UK locations in summer when the sun is higher. A steeper angle of roughly 50° helps energy absorption in winter when the sun is lower. Although some homeowners choose movable mounts to vary angles seasonally, most fixed installations employ an average tilt within the 30°–40° range for year-round efficiency.
Here is a table for the optimum angle for solar panels in various UK sites for reference:
| Location | Optimal Solar Panel Angle (°) |
| Brighton | 38-40 |
| London | 37-40 |
| Bristol | 37-39 |
| Cardiff | 37-39 |
| Manchester | 38-40 |
| Newcastle | 40-44 |
| Edinburgh | 42-44 |
Here is another table that shows the best solar panel angle by postcode UK:
| Postcode Region | Optimal Solar Panel Angle (°) |
| AB (Aberdeen) | 37.8 |
| B (Birmingham) | 38 |
| E (London East) | 35 |
| L (Liverpool) | 38 |
| M (Manchester) | 37.2° |
| NE (Newcastle) | 40 |
| SW (Southwest England) | 36 |
Does the Optimum Angle Change throughout the Year?
Yes, the best direction for solar panels UK does change throughout the year due to the tilt of the Earth’s axis. This tilt causes the sun’s position in the sky to vary over the course of the year, which in turn affects the angle at which sunlight hits a given location.
In summer, the Earth’s northern or southern hemisphere (depending on which one is tilted toward the Sun) experiences longer days and the sun is higher in the sky. This means the optimum angle for solar panels would be steeper, to maximize exposure to the sun.
In winter, the opposite hemisphere is tilted away from the Sun, and the sun is lower in the sky. During this time, the optimum angle would generally be less steep to capture as much sunlight as possible.
Although these changes increase efficiency, most UK households choose a set PV panel angle between 30° and 40° as a balanced strategy for year-round operation. This fixed tilt guarantees panels receive enough sunshine without regular movement required. Those who want to increase energy output, however, can change the tilt at least twice a year, in summer and then in winter.
Best Direction for Solar Panels to Face in the UK
The best roof angle for solar panels UK is orientated southward. This orientation guarantees panels get the most sunshine possible daily, optimizing energy output and efficiency. Most installations find south-facing panels the best option when the sun moves from east to west since they receive the most constant exposure.
East or west-facing panels come second best if a south-facing placement is not feasible. Eighty to eighty-five percent of the energy a south-facing system would create still comes from these orientations.
North-facing solar panels are usually not advised since they can lose up to 30–50% of their efficiency relative to south-facing panels. In some circumstances, though, panels placed on a northwest or northeast-facing roof can still produce a fair amount of power, mainly if extra panels are utilized to offset reduced efficiency.
What to Do If Your Roof Isn’t Angled for Solar Panel Installation
There are still various ways to effectively use solar energy, even if the tilt or orientation of your roof does not fit for solar panels. Although a south-facing roof with a 30°–40° slant is ideal, you might investigate other ideas to enhance solar power production.
Installable on curved or uneven surfaces, flexible solar panels offer one choice. Even if your main roof isn’t suitable, these lightweight, flexible panels can be positioned over other parts of your house. Another choice is a portable solar panel system. These units can be positioned in the sunniest area of your home, say your balcony or garden, and changed for best exposure throughout the day.
Solar roof tiles give homeowners seeking an integrated solution a smooth approach to creating energy without conventional solar panels. They still catch sunlight while blending with your current roofing materials. Still, they usually cost more than ordinary panels.
Should none of these solutions fit your circumstances, you can still install solar panel on home roof using movable mounting racks. These guarantee effective energy generation by letting panels be slanted correctly, even on flat or less-than-ideal rooftops.
For homes with inappropriate roof angles, the EcoFlow 220W Bifacial Portable Solar Panel is a good choice. This high-efficiency panel can gather energy from both sides for best sun absorption with a two-in-one bifacial construction. Its up to 23% conversion rate allows for higher energy conversion than traditional panels. Constructed with robust tempered glass and an IP68 waterproof rating, it also resists extreme weather. Improve your system with this EcoFlow portable solar panel today!
The best angle for solar panels can optimize energy production and reduce power bills. Use the tables above to position your panels for better solar exposure. Should your roof lack the ideal angle, substitutes include portable solar panels, movable mounts, or solar roof tiles can be beneficial. Homeowners can get the most out of the solar setup with EcoFlow solutions. Purchase EcoFlow solar panels today!
What is the best angle for solar panels in the UK?
In the UK, solar panels usually have an optimal angle between 30° and 40°. This variety lets panels gather the most sunshine all year round. While winter calls for a higher tilt of roughly 50°, summer is when a lower tilt of about 20° is optimum. Location also counts since northern areas gain more sun exposure from sharper tilts than southern ones.
At what angle do solar panels lose efficiency?
Installing solar panels in the UK at angles other than the ideal 30–40° south-facing position reduces their efficiency. A small difference, like pointing panels southeast rather than straight south, causes a 5% efficiency reduction. Comparatively to a south-facing system, a north-facing panel at 30–40° loses about 20% of its output. Mounting panels vertically on a south-facing wall will cut output by 30%.
What is the best slope direction for solar panels?
Solar panels would be most suited in the UK on a south-facing slope. This guarantees the best solar exposure all day, optimizing energy output.
Should solar panels be flat or tilted?
Maximum efficiency from solar panels is achieved when they are on an angle orientation instead of laying flat. A slanted panel lowers reflection losses and increases energy output. By contrast, flat panels gather trash and water, which, over time, can obscure sunlight and reduce efficiency. The best year-round solar efficiency in the UK is best from a tilt of 30° to 40°.
