Smart Generator
Smart Generator
Live without limits
DC Output
DC
Output Power
1800W
Automatically Start/Stop
Easy Maintenance
Gas Tank
4L
CO
Alarm
The generator that puts preparation first.
For extreme extended blackouts, you might need even more than EcoFlow DELTA Pro or DELTA Max to stay powered. That’s where the Smart Generator comes in to charge them up when you’re all out of other options. It’s up to 25% more efficient than other generators too¹, saving you fuel, fumes, and time.
    +25%
    Charging efficiency
    Smart Generator
    Other Generators
    *25% more efficient than using other generators to charge DELTA Pro/Max due to direct DC-DC connection.
    Recharge & power
    simultaneously.
    While you're charging up your portable power station, you can still use the 1800W outlets on the generator to keep your essentials powered. The 4L gas tank is enough to charge DELTA Max to full twice still leaving some left over to power your essentials in the meantime.
    Safety first.
    The Smart Generator puts safety first. It features a carbon monoxide alarm to signal if you have enough ventilation, and will auto shut off when CO levels are too high. It also has an alarm to let you know when you need to top up the fuel so you're never caught short.
    <p>Smart.</p> <p>Really smart.</p>
    Smart.
    Really smart.
    The EcoFlow Smart Generator isn’t just any generator. When your DELTA Pro/Max falls to a set charge level, the Smart Generator can automatically kick in to charge up your unit, then turn itself off when the job’s done. All this is customizable and controllable within the EcoFlow app too.
      Made with you in mind.
    • EcoFlow
      Generators are traditionally a hassle to maintain. We built the Smart Generator inside and out to remedy this problem.With a single door on the side of the unit, you can access everything for easy maintenance.
    • EcoFlow
      The bright LCD on the front makes it easy to check up on your generator too, it displays output data, run time remaining and more.
    • You might also like
      View more
      • EcoFlow
