EcoFlow Smart Home Panel 10
Power What Matters. Make Every Watt Count
Automatic Backup. Everyday Energy Savings
Your Home’s Energy Under Your Control
Keep essential circuits backed up, check home energy use in the EcoFlow app, and make better use of solar and stored power with your TITAN system.
Automatic Backup for Your Essentials
Keep up to 10 selected circuits powered automatically when the grid goes down.
Know How Much Power Your Home Uses
Check total home energy use in the EcoFlow app—including loads beyond your backup circuits—with CT sensing.
Buy Less Electricity at Peak Rates
Use solar and stored energy to buy less electricity when rates are high.
More Built In. Less Installation Work
10 Circuit Breakers Included|Factory-Prewired Connections|Factory-Prewired Connections
Choose What Stays Powered
Connect up to 10 selected circuits to TITAN + SHP10 for backup power. Check each connected circuit’s power use and turn it on or off in the EcoFlow app.
Keep Everyday Essentials Running
Keep the lights on, the refrigerator running, and essential outlets powered during an outage.
  • EcoFlow Image
  • EcoFlow Image
  • EcoFlow Image
  • EcoFlow Image
  • EcoFlow Image
EcoFlow Image
  • EcoFlow Image
    1
  • EcoFlow Image
    2
  • EcoFlow Image
    3
  • EcoFlow Image
    4
  • EcoFlow Image
    5
Put Stored Energy to Work Across Your Home
While the grid is on, your TITAN + SHP10 system can use stored energy to support household demand beyond the backup circuits. CT sensing measures total home energy use to help the system manage that power.
During an outage, backup power is limited to the selected circuits connected to SHP10.
Ready before the storm. In control through the outage
Prepare for storms, switch to backup automatically, and prioritize the circuits you rely on—all with your TITAN + SHP10 system.
Powered by
Use More of Your Solar. Buy Less at Peak Rates
With compatible rooftop solar, TITAN or TITAN Plus paired with SHP10 can store surplus solar for later. Use stored solar or electricity charged at lower off-peak rates to reduce grid purchases when rates rise.
  • Work With The Grid
  • Rooftop-grade Solar Input
  • Full Power. Lower Bills
AC Coupling requires TITAN or TITAN Plus and a compatible solar installation. Whole-home energy management operates while grid-connected. Savings depend on energy use and electricity rates.
Keep Your System. Add Storage and Backup
Keep your compatible solar or home battery system. Add TITAN + SHP10 for more storage and backup power for selected circuits.
Choose the TITAN System That Fits Your Home
Choose the backup power and solar capacity your home needs, paired with the right SHP10 version.
EcoFlow TITAN Classic + 120V SHP10
Essential 120V Backup
Keep essential 120V circuits powered during an outage, with control in the EcoFlow app.
  • 4 kWOutput
  • 120VVoltage
  • 3.2 kWSolar Input
  • Up to 10Selected Backup Circuits
  • YesWhole-Home Energy Monitoring
  • NoAC Coupling
  • 5–30 kWhSystem Capacity
EcoFlow TITAN + 240V SHP10
Home Backup and Everyday Savings
Back up selected 120V/240V circuits and store surplus energy from compatible rooftop solar to reduce grid purchases.
  • 7.2 kWOutput
  • 120V/240V split-phaseVoltage
  • 4 kWSolar Input
  • YesAC Coupling
EcoFlow TITAN Plus + 240V SHP10
More Solar. More Power for Your Home
Connect up to 8 kW of solar input. Power more of your selected loads with up to 10 kW output when solar and battery work together.*
  • 7.2 kW battery only; up to 10 kW with solar + battery*Output
  • 8 kWSolar Input
  • YesAC Coupling
*Up to 10 kW output on TITAN Plus requires compatible solar input working together with the battery. Battery-only output is up to 7.2 kW.
Smart Home Panel 10 | 10-Circuit Backup & Savings | EcoFlow CA
