Long-Duration Emergency Power Supply for Extreme Weather
Power outages can happen unexpectedly-whether due tto hurricanes, tornadoes, wildfires, storms, or aging grids. EcoFlow's emergency home backup power helps over 5 million families
  • Stay Comfortable
    Stay Comfortable
    Complete power outage emergency kit meeting your long-duration backup needs during extreme weather, keeping your home powered and family comfortable.
  • Less Waiting
    Less Waiting
    Quick installation process can be completed before storms arrive, ensuring your emergency power generator system is ready when needed most.
  • Unlimited Power
    Unlimited Power
    Expandable system provides unlimited backup power capacity, the ultimate solution for power outage preparedness during severe weather and natural disasters.
  • Ultimate Control
    Ultimate Control
    Integrates Weatherbit forecasting to predict storms and charge batteries, then switches to backup power within 20 ms during outages.
Stay Comfortable
Stay Comfortable
Less Waiting
Less Waiting
Unlimited Power
Unlimited Power
Ultimate Control
Ultimate Control
Find Your Versatile Emergency Backup Power For:
Multi-Day
1-4 Days
Hours
The Ultimate Whole-Home Power Command Center
Multi-Day
EcoFlow DELTA Pro Ultra X delivers whole-home backup power*, ready for any emergency situation.
For Over 5-Day Outages
100% Whole-Home* Power
Wide Generator Compatibility
Smart Home Energy Integration
12kW Output / 12kWh Capacity / 10kW Solar Input
1 × EcoFlow DELTA Pro Ultra X Inverter + 2 × Smart Extra Battery
Designed for the ultimate luxury whole-home backup experience.
Learn More
4-48kWh I 4-12kW I Effortless supply switch
EcoFlow DELTA Pro 3 + Transfer Switch
A simple home backup to keep your essential circuits running during blackouts
Add To Cart
Learn More
6-90kWh I 7.2-21.6kW I 0ms downtime
EcoFlow DELTA Pro Ultra + Extra Battery + Smart Home Panel 2
Advanced whole-home backup with intelligent circuit-level management
Add To Cart
Learn More
Essential Backup
For 1-4 Day Outages
Power through a days-long outage—keep your lights, Wi-Fi, and refrigerator running for fresh food and reliable essentials.
Blackout-Ready in 70 min
Plug-and-Play
Energy Conserved on Standby
In-App Energy Management
2048Wh Capacity | 2400W Output | 10ms UPS
EcoFlow DELTA 3 Max
The most lightweight 2kWh portable power station.* Cover your home essentials and outdoor adventures with quiet and reliable power. * Compared with EcoFlow DELTA 2 Max.
Add To Cart
Learn More
3072Wh | 3600W
EcoFlow DELTA 3 Ultra Plus
Run your energy-hungry appliances with industry-leading output, extend runtime for your high-priority items using the smart output priority feature. Supports 6 fast-charging methods.
Add To Cart
Learn More
4-48kWh I 4-12kW I 120V/240V
EcoFlow DELTA Pro 3
The most portable whole home backup power
Add To Cart
Learn More
6-90kWh I 7.2-21.6kW I 120V/240V
The most powerful whole-home backup solution
Add To Cart
Learn More
Whole-Home Backup Kit
Ensure uninterrupted home life for multiple days—work, cook, and unwind without compromise during blackouts.
Plug-and-Play
Compact and Portable
Multiple Outlets
286Wh I 600W
EcoFlow RIVER 3 Plus
Next-gen UPS with longer-lasting LiFePO4
Add To Cart
Learn More
1024Wh | 1800W
EcoFlow DELTA 3 Classic
Ultra-versatile 4 charging options and a 45-minute fast-charge.
Add To Cart
Learn More
1024Wh | 1800W
EcoFlow DELTA 3 Plus
0-80% in 40 mins. Enhanced backup with 10ms UPS and NAS system integration
Add To Cart
Learn More
1536Wh | 1800W
EcoFlow DELTA 3 1500
Same Size, 1.5× Capacity. 0–80% in 60 mins.
Add To Cart
Learn More
Power Where Your Generator Can't
EcoFlow portable emergency power supply is ready in seconds, safe for indoor use, and scalable for extended outages. No gas, no noise, no fumes—just reliable, clean power when you need it most.
EF-Picture
Traditional Generators
EF-Picture
EcoFlow Battery Backup
EF-Picture
Home Standby Generators
Hard to operate, manual setup
Plug-and-play, instant power
Month-long installation
Requires regular maintenance and fuel storage
No maintenance, flexible charging options
Gas emissions, outdoor use only
Indoor-safe, no emissions
Gas emissions, fixed outdoor only
Loud and disruptive
Ultra-quiet (<30 dB)
Loud and disruptive
Heavy and bulky
Lightweight and portable for homes, garages, RVs, and more
Permanently installed
No scalability, fixed output
Expandable capacity and scalable output
Fixed capacity once installed
Runs on gas
Solar-compatible, save energy bills and reduce emissions
Runs on gas
Requires additional equipment and professional setup
Seamless home power integration via Inlet Box or Transfer Switch
Permanently installed and requires professional setup
None
0ms auto-switchover, prolonged backup, and energy bill savings with Smart Home Panel 2
None
EF-Picture
EF-Picture
EF-Picture
Loud and disruptive
Heavy and bulky
Runs on gas
None
EF-Picture
Loud and disruptive
Runs on gas
None
Built for Real Emergencies. Certified for Peace of Mind
EcoFlow powers your home through blizzards, heatwaves, and blackouts—backed by industry-leading safety certifications and extreme-condition engineering.
Certified Safe, Inside and Out
UL9540
Whole-system certified for electrical and environmental resilience.
UL9540B
Proven to prevent fire propagation and ensure safe home installations.
Ready for the Worst Weather
Self-Heating Battery
Keeps running below 0°C during winter storms and freezes.
X-Cooling System
Dissipates heat fast, even in scorching summer garages.
SOC Balancing
Intelligently balances charging and discharging across all cells—prevents overheating and extends battery lifespan.
Tough from the Core
Cell-to-Chassis Integration
Built like a tank—engineered to withstand impacts and vibration for long-lasting durability.
IP54-Rated LFP Battery
Sealed tight against dust and water splashes for reliable all-weather performance.
UL9540B Certified
Proven fire safety protection prevents propagation and ensures secure home installations.
Long-Term Reliability, Guaranteed
5-Year Warranty
Backed by EcoFlow's official support for lasting peace of mind.
10+ Years Lifespan
With 4,000 full cycles to 80% capacity, it's built for the long haul—powering your family through thousands of outages.
Sign up to unlock special deals on more EcoFlow backup solutions!
Sign up to unlock special deals on more EcoFlow emergency backup solutions!
Also Available at Trusted Retailers
https://websiteoss.ecoflow.com/upload/image/1749621746281/logo1.png
https://websiteoss.ecoflow.com/upload/image/1749621746664/logo2.png
https://websiteoss.ecoflow.com/upload/image/1749621747856/logo5.png
https://websiteoss.ecoflow.com/upload/image/1753948139636/Canadian_Tire_logo_2022.png
https://websiteoss.ecoflow.com/upload/image/1753948139855/londondrugs.png
https://websiteoss.ecoflow.com/upload/image/1753948211501/tsc%20logo.png
https://websiteoss.ecoflow.com/upload/image/1753948138607/batteries%20expert.jpg
https://websiteoss.ecoflow.com/upload/image/1753948138974/shop%20solar.png
Protect Your Home with Instant Power Backup
Interest-Free Installments
Backup first, pay over time.
In-Store Pickup
Get home backup power at select shops.
Go Now
Customer service
+1(800)-368-8604 (Mon-Fri 9-7, EST)
Free Quote
Global No.1 in Portable Power Station Sales
EcoFlow is the No.1 portable power station brand in the world based on sales and revenue in 2024,* committed to powering a new world.
5M+
Global Users Back Up Using EcoFlow
140+
Worldwide Markets' First Choice
1125+
X-Core 3.0 Technological Patents
65+
Media Awards
Their Real-life Prepping Stories
Join our EcoFlow Group to learn more backup power stories from real-life users.
Jason Molnar
Never fell overwhelm because of an unexpected power cut. These are the times I’m proud to be an EcoFlow owner. I am able to function as usual. Internet + Wi-Fi , lights, computer, tv and AC by the Wave2.
Nathan Ornat
I am so absolutely grateful for My Delta Pro ultra, Smart Home Panel 2 and my Delta Pro’s for their ability to get my family and friends through the 5 days we had no power to the house. We were the only ones in my neighborhood with power because I chose to trust Ecoflow with my house.
Tony Fresco
A lot of posts had me scared. Installed this yesterday, updated the firmware to both (lots of errors while updating) but everything is working as it should. Shut my power yesterday 3pm @ 90% 8:30 am 71% left normal use including well pump. Only day 2 but nice so far
Aline Tarullo
Our family went through hurricane Beryl without any hiccup with SHP, 3x DP + 1EB, hooked to 4600w solar array. It was no surprise that we did okay because Ecoflow has been running our house daily for almost a year now. Our electric bill went from $300 to $150. Estimated payoff time is September 2028, when the savings will surpass the $10k investment.
Dee W Aitch
Just wanted to give a rundown of my current Hurricane Beryl power outage using a single Delta Pro and Dual Fuel Smart Generator. We lost power at about 4am, and it's 7:20pm now. I got up around 7am, plugged in my full-sized refrigerator, wifi router, several lamps, and a fan. I'm running propane and have two 30lb tanks, so I'm estimating that I'll be able to sustain this for 10 days before needing more fuel.
Peter Pesaturo
My completed power station. Ready for Hurricane season. I can run the bare necessities for 3 days with no solar or generator. It plugs into a properly installed generator inlet. Can be charged Solar, by generator, or from the grid. The Ecoflow charges exclusively from the 48 volt battery or solar. It will never be charged AC. With solar the Ecoflow will recharge the 48 volt battery. It should make extend power outages much easier.
Hector Salgado
I am in Western NC and we were hit hard by the storm! Glad I got my delta max and delta 2 a few months ago. The combination of solar with a gas generator made all the difference! Generator ran for about 2 hrs in the morning and charged up my eco products for the day. Saving a ton of gas and noise! I had no trouble going 4 days till I got power back. 🙏
Together, We'll Power Through
EcoFlow’s #PowerForAll program empowers communities in emergencies. Stay prepared, stay safe, and protect your loved ones.
EF-Picture
EF-Picture
EF-Picture
EF-Picture
EF-Picture
EF-Picture
Emergency Power During Hurricane Helene
In the wake of catastrophic Hurricane Helene in September, EcoFlow partnered with the Special Forces Charitable Trust and donated 10 portable power stations to help the most vulnerable homes recover after Hurricane Helene in September. EcoFlow has also partnered with the non-profit Red Lightning to preposition donated power stations and solar panels in Florida for future hurricane strikes.
EF-Picture
Shelter Power During Noto Quake
During the 2024 Noto earthquake in Japan, EcoFlow donated 76 portable power stations, 17 solar panels, power banks and disaster preparedness boxes to non-profit organizations and companies in the cities of Nanao, Komatsu, and Kanazawa in Ishikawa Prefecture. These supplies were used in local shelters, providing emergency power for 40,000 affected people.
EF-Picture
EcoFlow Supports Ottenhofen Volunteer Fire Brigade
EcoFlow has donated portable power stations to the Ottenhofen Fire Brigade in Gernany, enhancing disaster response. These devices ensure medical equipment stays operational, provide emergency site lighting, and power essential tools during blackouts.
EF-Picture
Texas Winter Storm
After the 2021 Texas snowstorm triggered widespread power outages, we donated all of the portable power stations in our Texas warehouse to the Houston Food Bank in support of local communities.
