How Much Does It Cost to Run a Natural Gas Generator?
In the present day and age, particularly in areas that frequently experience power outages and inclement weather, having a reliable backup power supply is extremely important. Natural gas generators are a viable option for maintaining critical systems during a power failure because of low cost. Then, how much does it cost exactly when running a natural gas generator?
Learning the Fundamentals of Natural Gas Generators
Before answering the question, let's learn something basic about natural gas generators.
What Is a Natural Gas Generator?
A natural gas generator is equipment that converts natural gas into electricity and is a cleaner alternative to standard diesel or gasoline generators.
Single Fuel vs. Dual Fuel Generators
  • Single Fuel Generators: These generators are configured to run on a single fuel type, such as natural gas, gasoline, or diesel. In this context, we’re focusing on natural gas models. Natural gas single fuel generator are typically less expensive upfront compared to dual fuel models but can become limiting if gas supply issues arise.
  • Dual Fuel Generators: These are versatile, able to run on both natural gas and other fuels like liquefied petroleum gas (LPG) or gasoline. This flexibility is valuable in situations where one fuel source may be more expensive or unavailable. The ability to switch between fuel types ensures uninterrupted power.
Dual-fuel generators are a valuable solution for anyone looking for energy security, whether as a backup when conventional power fails or when off-grid.
Key Factors Influencing the Cost of Running a Natural Gas Generator
Several factors come into play when calculating the cost of running a natural gas generator. Understanding these key components will allow you to better estimate your operational costs and help you make an informed decision.
Power Requirements and Fuel Consumption
  • Choosing the Right Generator Based on Power Needs: The size of the generator and its power output should match your needs for energy. The bigger the generator, the more fuel it will use. For example, if you only need to power a few appliances, a small generator will suffice and will cut your operating costs substantially. On the contrary, bigger generators are needed to power a whole house or machinery in industries, which means more fuel usage.
  • Fuel Consumption Calculation: The power rating of a generator has a direct effect on fuel consumption. For example, a standard 10kW generator uses 100 to 150 cubic feet of natural gas per hour at full load. This figure may be different depending on the model and loading conditions. To calculate your operating costs, you need to know how many hours per day or month you are going to operate the generator. You should multiply the fuel consumption by the operating hours to have a better estimate of fuel expenses.
Natural Gas Price Fluctuations
  • Regional Price Differences: The cost of natural gas can vary greatly depending on where you live. In some regions, natural gas is relatively cheap due to abundant local supply, while in others, prices may be higher due to transportation or supply limitations. The price of natural gas can fluctuate seasonally, with winter months typically experiencing higher prices due to increased demand for heating.
  • Impact of Gas Price Changes: When gas prices rise, the operating costs of your generator will increase as well. To help manage these fluctuations, it’s important to keep track of local gas prices and plan accordingly. For example, you might consider investing in a dual-fuel generator, which allows you to switch to a more affordable fuel option when gas prices are high.
Usage Frequency and Run Time
  • Daily vs. Emergency Use: A generator used daily for ongoing power supply will incur higher running costs compared to one used only during power outages.
  • Optimizing Run Time: To minimize costs, it’s essential to operate your generator only when necessary and to choose one that matches your daily power consumption needs without excessive running time.
Calculating the Running Costs of a Natural Gas Generator
Once you understand the main factors, calculating the actual cost of running your generator becomes more manageable.
Let’s say you have a generator that consumes 120 cubic feet of natural gas per hour. If the cost of natural gas is 0.035 CAD per cubic foot, the fuel consumption and costs for different time periods can be calculated as follows:
Fuel Consumption & Costs
Calculation
Amount (CAD)
Hourly Fuel Consumption
120 cubic feet x 0.035 CAD
4.20 per hour
Daily Fuel Consumption (5 hours)
4.20 CAD per hour x 5 hours
21.00 per day
Monthly Fuel Consumption (30 days)
21.00 CAD per day x 30 days
630.00 per month
Annual Fuel Consumption (365 days)
630.00 CAD per month x 12 months
7,560.00 per year
Hidden Expenses in Running a Natural Gas Generator Long-Term
The upfront cost of a generator is just the beginning. Long-term expenses need to be factored in as well.
Long-Term Maintenance Costs
  • Routine Maintenance: You will need to take care of the generator over time. This involves oil changes, air filter replacement, and spark plug servicing. These are routine processes to keep your generator functioning properly and safely. You can expect maintenance costs to be between 100 and 300 CAD annually, depending on the model and usage frequency.
    • Component Wear and Repair Expenses: As your generator ages, parts such as fuel pumps, batteries, and filters will start to degrade. These are expensive repairs that can add up over the years, and you need to factor potential repair costs into your plans for long-term generator use. A quality generator will have a longer lifespan, which reduces the need for frequent repairs.
Shipping and Storage Costs
  • Shipping Fees: For larger generators, shipping costs can add up, especially when buying from distant retailers. These fees can vary based on the size and weight of the generator, so it’s worth considering purchasing from a local dealer to reduce costs.
  • Reducing Shipping Costs: Choosing compact models or buying locally can help you save on transportation fees.
  • Storage Requirements: Larger generators take up more space and may require dedicated storage. If you don’t have the space at home, you may need to pay for storage, adding an extra cost to your total ownership expenses.
Methods of Reducing the Operating Cost of a Natural Gas Generator
Maximizing efficiency and reducing waste can enable you to reduce the overall operating expenses of your natural gas generator. The following are some strategies that you can use.
Choose Efficient Generators
New and high-efficiency models are designed to consume less fuel while delivering the same or even greater power. This can significantly lower your long-term operating costs.
Regular Maintenance
Regular maintenance, such as changing oil, replacing air filters, and checking spark plugs, can ensure your generator runs at optimal efficiency. Even basic maintenance can make a huge difference in fuel consumption. Regular maintenance allows you to catch problems early to avoid expensive repairs and keep the generator running smoothly without wasting fuel.
Selecting High-Efficiency Fuel and Maximizing Usage
Fuel efficiency can be enhanced with the use of high-quality LPG or natural gas. Also, preventing overload of the generator and engaging it at full load for long durations will minimize excess fuel usage.
Using Smart Control Systems
There are multiple generators with intelligent control systems that provide automatic start and stop capabilities in response to power demand. With the automatic shut-off when not required, the generator conserves fuel and minimizes operating expenses. The remote monitoring capabilities provide users with the option to manage the generator through a mobile application, so it only runs when demanded.
The EcoFlow Smart Generator 4000
EcoFlow Smart Generator 4000 (Dual fuel): an inverter generator with 4000W peak output, efficient fuel use, and remote app control. Shop today!
Why Choose the EcoFlow Smart Generator 4000?
The EcoFlow Smart Generator 4000 is designed to provide superior fuel efficiency, flexibility, and smart control features, making it a great option for both residential and commercial use.
  • 40% Fuel Savings: Compared to traditional models, the EcoFlow Smart Generator 4000 saves up to 40% more fuel, providing significant savings in fuel costs. That also means it can reduce emissions. Therefore, the EcoFlow Smart Generator 4000 is also a sustainable choice for those looking to minimize their environmental impact while saving money.
  • Smart Control and Remote Operation: The EcoFlow app allows users to monitor and control the generator remotely, optimizing its operation and minimizing unnecessary fuel consumption.
    • Dual Fuel Design: The EcoFlow Smart Generator 4000 supports LPG and gasoline,the Dual Fuel technolo givies you the flexibility to choose the most cost-effective fuel based on availability and market prices.
Save Money Running a Natural Gas Generator
Running a natural gas generator can be a cost-effective solution for backup power, but it requires careful consideration of various factors such as fuel consumption, maintenance costs, and regional price fluctuations. By opting for efficient generators and implementing cost-saving strategies, you can significantly reduce your overall expenses. The EcoFlow Smart Generator 4000 stands out as a top choice for those looking to save on fuel, reduce emissions, and enjoy flexible fuel options.
Side view of an EcoFlow Smart Generator, showing its silver and black casing with wheels and a fuel door.Side view of an EcoFlow Smart Generator, showing its silver and black casing with wheels and a fuel door.
3 FAQs About Natural Gas Generator
Q1: What is the lifespan of a natural gas generator?
A natural gas generator typically lasts between 10 and 30 years, depending on maintenance and usage. Regular oil changes, air filter replacements, and checks can extend its life. Neglecting maintenance may lead to faster wear and higher repair costs. High-quality generators tend to last longer and require fewer repairs.
Q2: How often should I run my generator to keep it in good condition?
It’s a good idea to run your generator at least once a month for about 30 minutes. This keeps the engine lubricated and prevents parts from freezing. Regular use helps spot issues like clogged fuel lines early. Running it under load ensures it’s ready for emergencies, extending its lifespan.
Q3: What is the difference between LPG and natural gas for a generator?
LPG has a higher energy density than natural gas, meaning it provides more power for the same amount. It’s ideal for areas without natural gas supply. Natural gas is usually cheaper and more available, especially with pipelines. Using LPG may require a different regulator, but natural gas is typically more affordable and convenient where it’s available.
Home Solutions
