EcoFlow 110W
EcoFlow 110W
Portable Solar Panel
Portable Solar Panels
Power your everyday appliances at home and off-grid with sustainable solar energy.
    Powerfully ​portable.
    With an industry-leading up to 23% conversion rate, it’s far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
      Self-<br/>supportable.
      Self-
      supportable.
      Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
        Waterproof & durable.
        Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That’s an all-weather ready panel designed to stand the test of time.
          Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.)
          It comes with a carry case too.
          On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
 case too.
            High-Efficiency Solar Cells
            Capture more rays.
            Made using highly efficient monocrystalline silicon cells. And with an exceptional energy conversion rate of up to 23%, you get more energy with every cell.
            Plus, when connected to an EcoFlow solar generator, the Maximum Power Point Tracking (MPPT) algorithm auto-adjusts, guaranteeing a constant and stable power supply.
          • Charge a RIVER Mini in
            2-4 hours
            with 1 x 110W portable solar panel.
          • Charge a RIVER in
            Charge a RIVER in
            3-6 hours
            with 2 x 110W portable solar panels.
          • Charge a RIVER Max in
            3-6 hours
          • Charge a RIVER Pro in
            4-8 hours
          • You might also like
            View more
            • EcoFlow
