- Overview
- Specs
- Support
Smart Generator
(Dual Fuel)
Introducing the ultimate backup power solution to accompany your DELTA Pro, DELTA Max or Power Kits. The EcoFlow Smart Generator, now with dual fuel support - you get the option of both your usual gas, and with LPG, it's more efficient, and more intuitive than ever.
Huge Capacity Up to 20kWh with LPG
Up to 1800W DC & AC Output
40% Higher Energy Efficiency
Auto Start/Stop
App Control
5 Safety Alerts CO & More
Dual fuel does it better.
Go for gas or propane (LPG). With both fuel options, you'll have access to energy no matter what happens. With LPG as an additional fuel source, you get way more flexibility. When the grid is down, it's ideal as an emergency option for your home or RV as gas is hard to come by. Not only that, you can store it longer and create fewer fumes.
Huge capacity for extended blackouts.
With a 1600W-1800W*¹ output and a 4L gasoline tank, you can generate 5.4kWh in gasoline or even 20kWh with LPG*². That gives you up to 12.5 hours of runtime with LPG alone. Connect that to your DELTA Pro, DELTA Max and Power Kits to charge up when you’re all out of other options. All while using less fuel, producing less noise, and producing fewer emissions.
Gas Specs
LPG Specs
1800W
Rated Output (gas)
4L
Fuel Tank
5.4kWh
Power (gas)
*¹ Gasoline = 1800W (1900W Peak), LPG = 1600W (1700W Peak)
*² Measured with a 20lb LPG tank. The power is not limited to this amount. It depends on the size of the LPG tank.
Save fuel. Maximize efficiency.
When used with your DELTA Pro, DELTA Max or Power Kits, it’s way more efficient than alternatives. Saving fuel, generating fewer emissions, and giving a ton of convenience. With that, you can charge DELTA Max to full in 1.8 hours, or DELTA Pro in 2.7 hours.
Time Saving
Fuel Saving
Environmental Friendly
Noise Reduction
More fuel efficiency.
When charging DELTA Pro, DELTA Max or Power Kits, you can save up to 40% on fuel compared to using other generators & portable power stations. Here’s how it works:
10%
Direct DC-DC charging
30%
X-Stream
Smart Generator (Dual Fuel) charging DELTA Pro or DELTA Max
Saves 40% of fuel*
Other generators charging other portable power stations.
*Fuel consumed at the same full-rated power.
Automatic backup.
When your DELTA Pro, DELTA Max or Power Kits drops to a predetermined battery level, the Smart Generator automatically kicks in. Once maxed out, the engine shuts down to avoid extra fuel waste, emissions, and noise.
Keep your essentials running while charging.
When a blackout hits, it’s important to keep your essentials running. The Smart Generator allows you to not only charge your power station back up, but it also allows you to power your appliances at the same time, outputting up to 1800W*.
*The total output of DC and AC is 1600W in LPG mode *Prioritizes AC output when needed to keep your devices on.
Safety first.
The Smart Generator (Dual Fuel) keeps you in the know with a carbon monoxide detector, fuel alert, engine oil alert, temperature protection, overload avoidance, and a whole lot more. All are clearly visible with indicators on the unit, and all (excluding fuel alert) can trigger an auto-shutdown to keep you and your batteries safe.
CO Alert
Shuts down if there is too much carbon monoxide.
Fuel Alert
Get notified when low on fuel.
Engine Oil Alert
Keep your engine well-oiled with alerts telling you when more is needed, auto-shutting down to prevent damage.
Temperature Protection
Auto shuts down to prevent your battery or engine from overheating. Auto starts to keep the engine warm in cool environments when needed.
Overload Protection
Get alerted when the load hits a certain level. It auto shuts down to prevent overload.
Four ways to start means power comes easy.
When you’re caught short in an outage, ease of use is essential. Start up the Smart Generator (Dual Fuel) via an electric button in 2 seconds flat, far easier than other options on the market, Alternatively, set it to auto-start* in the app, use the app to start it directly, or rely on the manual starter grip in case of failure.
*Auto-start requires use of DELTA Pro, DELTA Max or Power Kits
Auto start
Manual start
APP start
Electric start
Propane has never been this easy.
With LPG, we’ve made it easier than ever. Plug into the LPG inlet without any tools required. Once set up, you can use the generator seamlessly as it auto-switches modes, allowing you to power up in seconds with the electric start button. We’ve gone the extra mile too, with a built-in pressure regulator, it's easier to carry your unit.
Smart Generator
Other
Easy maintenance
and noise reduction.
With a spacious side access maintenance door, you can keep your unit up to the job with repairs and oil changes.
With the built-in noise muffler, it only outputs 56-63db from a 7-meter distance.
What's in the box?
1:User Manual and Warranty Card 2:Spark Plug Socket / Double-Ended Spanner / Breaker Bar / Screwdriver 3:LPG Hose 4:Oil Funnel 5:Extra Battery Connection Cable 6:Smart Generator(Dual Fuel)
123456
You might also like
View more
EcoFlow DELTA 2Learn More
EcoFlow DELTA MaxLearn More
EcoFlow DELTA ProLearn More
EcoFlow RIVER 2Learn More
