EcoFlow DELTA Pro
The portable home battery
3600W-7200W
EV Station
Charging
EV Station Charging
3.6-25kWh
3.6-25kWh
Expandable Ecosystem
Flow Charge<br /> Multiple Charging<br /> Methods
Flow Charge
Multiple Charging
Methods
MultiCharge
6500W
MultiCharge
1600W Solar Input
LFP Battery Chemistry
3.6kWh - 25kWh Expandabale Capacity
Power your home for days.
DELTA Pro's capacity starts at 3.6kWh. Enough for hours of heavy-duty use. It doesn't stop there either, expand all the way to an industry leading 25kWh by adding another unit, Extra Batteries and Smart Generators. That'll keep you going even during extended blackouts.
3.6kWh
10.8kWh
25kWh
A single DELTA Pro has a massive 3.6kWh battery capacity. With a portable luggage-like design, that’s a whole lot of energy to take camping, on road trips, or to keep in your garage.
What can it power?arrow icon
Phone
313Times
Laptop
57Times
Light
4Day
Refrigerator
1-2Day
Electric Drill
3hrs
Microwave
2.5hrs
Electric Kettle
2.2hrs
Electric Oven
2hrs
Air Conditioner
1.8-3.6hrs
Electric Heater
1.5hrs
*The data above is for reference only.
3600W-7200W AC Output
Power pretty much anything.
AC units, kitchen appliances and power tools are all accessible with DELTA Pro. Use a single unit to power up to 4500W¹ of appliances. Need even more power? Chain two units together to hit a record-breaking 7200W output².
¹ With X-Boost mode turned on.
² Requires use of the Double Voltage Hub or Smart Home Panel (both sold separately).
Heading outdoors? Power your whole RV or campsite and rest easy knowing you've got enough power to keep you going for the long-haul. With DELTA Pro's plethora of ports, you can even power up to 14 devices at once.
Introducing
FlowCharge.
Stay prepared no matter what. DELTA Pro introduces FlowCharge. Now, you can charge anytime, anywhere and at the fastest speeds.
  • EcoFlow
    EV Station Charging
    That's a world first.
    Charge up at thousands of AC level 2 EV stations worldwide to get up to 3400W of input. Enough to charge to full in 1.7 hours.
  • EcoFlow
    Solar Panel Charging
    Solar charging. Faster than ever.
    DELTA Pro is compatible with 90% of portable solar panels. And with a 1600W input, you can charge up in as fast as 2.8-5.6 hours. Integrate DELTA Pro with your home using the Smart Home Panel and use your rooftop panels to charge up too.
  • EcoFlow
    The world's fastest wall charge.
    And of course, you can plug in at home to charge while the grid is online. Get a full charge in as fast as 2 hours.
  • EcoFlow
    Smart Home Panel
    Charge at home.
    When integrated with your home circuits via the Smart Home Panel, DELTA Pro charges at a rapid pace of 0-100% of 1.7hrs.
  • EcoFlow
    Car Charging
    Top up on-the-go.
    Plug directly into your car outlet to get a top up on-the-go. Ideal for when you need an extra few percent in a pinch.
  • EcoFlow
    Smart Generator Charging
    Just when you thought you were out of options.
    Use EcoFlow's Smart Generator as a backup for your backup. It's smarter, more efficient and can charge your DELTA Pro in severe outages when you're all out of other options.
MultiCharge
technology.
We've raised the bar when it comes to charging speeds. Combine AC, solar, and the Smart Generator at the same time to get record-breaking 6500W charging speeds.
6500W Multicharge
5000W Multicharge
EcoFlow DELTA Pro
Smart Home Panel Solar Charging Smart Generator
0%
0
Hrs
Other Portable Power Stations
Wall Charging
0%
0
Hrs
* Require DELTA Pro to be connected to a DELTA Pro Smart Extra Battery.
EcoFlowThe Infinity Port
One port to make things simple.
DELTA Pro's unique infinity port combines both AC input and output into one. It doesn't just enable the world's fastest charging and EV station charging, it also serves as a connection point for the Smart Home Panel and Double Voltage Hub. That means less adapters and cables for your setup.
EcoFlowThe Extra Battery Port
It's smarter than it looks.
The extra battery port serves as a way to connect an extra battery, or even the Smart Generator to your DELTA Pro. It can discharge and recharge the Extra Battery simultaneously so you only have to operate one unit, saving you time and effort. The port also communicates with the Smart Generator to enable auto-start up when your battery levels drop to a predefined level.
Battery + Inverter Technology
Built to last.
A battery to stand the test of time.
Batteries come in different shapes, sizes, and chemistries. DELTA Pro picks the best of the bunch for home backup with a LiFePO4 battery chemistry. That'll give you 6500+ cycles¹ so your battery will stand the test of time.
¹Approx. 6500+ cycles at 50% capacity.
And it keeps its cool.
Not only will your battery last years of heavy-duty use, it puts safety first too. Our advanced battery management system regulates voltage, current, and temperature in real time to ensure safe and optimal performance.
Say goodbye to bulky chargers.
DELTA Pro's two-way inverter in built in. That means a sleek, lightweight charging cable without the brick you're used to. It enables X-Stream fast charging and X-Boost technology too. With that, you can power pretty much anything.
Interior & Exterior Design
Let's
get down to
details
DELTA Pro is designed inside and out for ease of use, durability and safety. Take a closer look.
Interior Design
Interior Design
Each wire is secured and plated in copper, a key consideration in case of knocks and jolts, all while providing extra cooling. The 4 fans up auto-regulate to breathe ventilation through the unit for extra cooling.
Exterior Design
Exterior Design
Designed with tough ABS plastic, the exterior of DELTA Pro can take a tumble. As an added measure, we made it fire resistant too.
Portability
With a rugged, luggage-like handle, DELTA Pro can be wheeled around with ease.
Take control
of your energy consumption.
Wired control
DELTA Pro is the first portable power station with a remote control. Mount it up, wire it up and control from a distance.
Wireless control
Use the remote control via bluetooth to control without wires. Or, link the EcoFlow app and control from anywhere with a wi-fi connection.
Learn More
Real-time energy insights on the go.
Monitor
View battery status live anytime, anywhere.
Control even from afar.
Control
Easily turn on/off output and the connected appliances remotely.
Constant updates for optimal user experience.
Constant Updates
Regular upgrades to offer you industry-leading energy management.
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
EcoFlow app
Stay calm and powered on.
When the power's down, AC Always-On ensures a seamless transition from the grid to backup power and unwavering protection of your fridge and other mission-critical appliances.
EcoFlow app
Elevated battery lifespan and safety.
By tuning the charging speed to suit various charging environments, it's safe to use, preventing overloading and prolonging its lifespan.
EcoFlow app
Download the EcoFlow app
EcoFlow app
EcoFlow app
On-unit control
DELTA Pro's tactile buttons on the front of the unit pair with a bright LCD screen to give you all the control and information you need.
You might also like
View more
  • EcoFlow
