DELTA Max
Unleash Your Capacity.
Fast<br />Charging
Fast
Charging
Expandable Capacity up to
6048Wh
2400W
Smart Generator for Blackouts
Easy Control App
Easy Control App
Safe Use BMS
Safe Use BMS
Solar Power
800W
Solar Power
  • 0
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 0
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 0
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 0
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
Wh
Expandable Capacity
Delta Max + Extra Battery x
  • 0
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
So you’ll never be in the dark again.
With a large capacity of 2016Wh*, you’re guaranteed peace of mind during a blackout. Expandable with up to two Extra Batteries for a whopping 6048Wh, you can power your home appliances, from your fridge to your microwave, even through extended outages.
*DELTA Max (2000) capacity 2016Wh/DELTA Max (1600) capacity 1602Wh.
2016Wh
4032Wh
6048Wh
Family Use
29kWh/day
Live in total comfort powering your entire home.
5 Hrs
Extended Outage Use
3.6kWh/day
4 lights, a fan, router, a laptop, smartphone charging and refrigerator/freezer.
1.5 Day
Temporary Outage Use
1.88kWh/day
4 lights, a fan, router, a laptop and smartphone charging.
3 Day
RV Use
20kWh/day
7.3 Hrs
Fast
Up to
3600W
Take charging to the max.
Need DELTA Max primed in a rush? Combine multiple charging methods to increase wattage up to 3600W for a lightning-fast charge.
Charging
Fast
charging.
Plug into the grid and fully charge DELTA Max in 1.8 hours using EcoFlow’s X-Stream technology.
Input
2000W*
Full Charge
1.6 Hrs
*DELTA Max (2000) input - 2000W /
DELTA Max(1600)1600 W。
Fast Dual charging
The power of
solar.
Take advantage of EcoFlow’s dual charging technology to rapidly top up in 2 hours with a 3000W input using solar panels and an AC outlet.
Or swap out the wall socket for an EcoFlow Smart Generator and reach max capacity in 2 hours.
Input
3000W
Full Charge
2 Hrs
Fast Dual charging
Speedy
topups
for 4kWh double capacity
Combine AC power with the Smart Generator to get up to 3600W to simultaneously charge DELTA Max and an Extra Battery in only 1.7 hours.
Input
3600W
Full Charge
1.7 Hrs
2400W
Powers99%
of home appliances.
Don’t sacrifice the creature comforts during a blackout. With a DELTA Max, keep up to 13 appliances running at once. Plus, using X-Boost, power high wattage devices of up to 3000W, like space heaters and AC units.
Appliances
you can power.
  • Light
    Light
    • 189   Hrs
  • Refrigerator
    Refrigerator
    • 14   Hrs
  • Microwave
    Microwave
    • 1.5   Hrs
  • Washer
    Washer
    • 3.8   Hrs
  • Electric Frying Pan
    Electric Frying Pan
    • 1.6   Hrs
  • 50" TV
    50" TV
    • 15   Hrs
  • Hair Dryer
    Hair Dryer
    • 1.1   Hrs
  • Coffee Maker
    Coffee Maker
    • 1.9   Hrs
Plugin and Power Up for
Maximum Output.
Up to 800W of Solar Power
Harness the power of the sun.
DELTA Max lets you plug in up to 800W of solar power to recharge in as little as 3.5 hours.
Smart Generator
Power up even during extended blackouts.
Prepare yourself for prolonged outages with emergency backup for your power station. EcoFlow’s Smart Generator vastly extends DELTA Max’s capacity by 10.8kWh*, efficiently kicking in once power gets low and cutting off when DELTA Max reaches max capacity.
*Using two Smart Generators.
EcoFlow app
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
EcoFlow app
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
EcoFlow app
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
EcoFlow app
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
Download the EcoFlow app
EcoFlow app
EcoFlow app
An Advanced BMS.
Multiple levels of
protection.
DELTA Max has tons of built-in safety features that self-regulate voltage, current, and temperature to guarantee the longest battery life possible.
Interior Design
Modular electronic components seamlessly fit together and are easily removed from the case for maintenance. All wires are copper plated and polymer-wrapped to improve cooling, safety, and strength.
Rubber
anti-slip
base.
Fire-resistant shell and strengthened handle.
Exterior Design
Made from safe, robust materials, the sturdy one-piece design can withstand severe knocks and falls. Each port is reinforced to protect against wear and tear.
You might also like
View more
  • EcoFlow
