Move with Power
EcoFlow DELTA mini
DELTA mini
10.7KG
Lightweight
900W AC Input
Fast Charging
1400W
882Wh
300W
Solar Input
Safe Use with
BMS
Easy Control
1400W AC Output
Power 90% of devices.
Don't let the size fool you. It can take on some high power appliances and tools. With
X-Boost on, DELTA mini can even handle appliances and tools rated 1800W.
*2200W for 220V–240V regional versions
The world’s fastest charging.
EcoFlow’s patented X-Stream technology brings in 900W from the wall, going from 0–80% in 1 hour. Change the charging speed to fit the need.
Learn more about X-Stream
- 900wAC Input* * Maximum with X-Stream
- 1h0-80% capacity
882Wh Capacity
A pint-sized powerhouse
Power through work. Energize your time outdoors. 882Wh is a whole lot of energy to keep you going no matter what, and an Energy Protection System keeps you charged even during blackouts.
Portable Design
Ready to go.
Our most portable DELTA yet, it's under 24 pounds and easy to carry. Everything's integrated into the unit, so there's no power brick to bring along.
Battery Management System
Play it safe. Go all out.
Confidence comes when you know your battery can take care of its own. The battery management system keeps your portable power station performing its best when voltage, current, and temperature aren’t ideal.
Monitor
Real-time energy insights on the go.
View battery status live anytime, anywhere.
Control
Control even from afar.
Easily turn on/off output and the connected appliances remotely.
Customize
Save more on electricity bills.
Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
Constant Updates
Constant updates for optimal user experience.
Regular upgrades to offer you industry-leading energy management.
You might also like
View more
EcoFlow DELTALearn More
EcoFlow DELTA MaxLearn More
EcoFlow DELTA ProLearn More
