EcoFlow Wave
Watch Video
The fastest cooling.
The longest running time.
Sustainable charging.
Smart controls & customization.
KEEP IT COOL
Watch Video
4000BTU (1200W)
Wave goodbye to the heat.
EcoFlow Wave isn’t just portable, it blasts out 4000BTU’s worth of cooling thanks to its inverter compressor too. That’s the most powerful air conditioner of its size.
6㎡
In Iaymen's, it can cool a 6 m² space from 30 to 24°C in 8 minutes-ideal for medium-sized tents,RVs,or small rooms.
Add-on battery & customizable run times
All-night long.
Need to keep your AC running for longer?
Need to keep your AC running for extended periods? Wave can run for 3-12 hours depending on the battery you use*. It can intelligently mix fan and cooling settings to extend runtimes beyond what would usually be possible too. Pop off the extra battery whenever you don't need it for when portability comes first.
*3 hours of straight cooling with the add-on battery (fan and cooling modes can be mixed to extend runtimes). 12 hours of straight cooling with DELTA Pro.
1008Wh
Add-on battery
Solar charging
Powered by nature.
Charge Wave via up to 200W of solar panels & keep topped up without a mains supply. Ideal for when you’re outdoors and off-grid. Using 200W of solar, you can fully charge the add-on battery in 5 hours.
Car outlet charging
Charge on the road.
Need a charge on the way to your campsite? Plug into a car outlet to get a 200W charge to full in 5 hours with the add-on battery.
Wall outlet charging
Or before you head out.
Top up before you head on your trip and plug into any standard wall outlet to get a 600W charge. With that, you’ll be full in just 2 hours with the add-on battery.
DELTA Pro
EcoFlow Wave
DELTA Max
28%
more efficient.
10/16Hr
max run time
28
EcoFlow MH200
Electricity Efficiency
DELTA Pro with EcoFlow Wave
12Hrs
DELTA Max with EcoFlow Wave
6Hrs
Others
Powerfully portable
with tubing to match.
Single ventilation duct
Mount dual ducts
Or use without
It’s the most powerful air conditioner of its size by a long shot. Carry it anywhere and attach tubing for directed, efficient cooling. Ideal for tent doors, RV windows or placing your unit at a distance.
Extend your cold air reach from outside with the snap-on tubes.
Or keep AC inside, while letting hot exhaust go out through the detachable pipes.
Easy maintenance
No water left behind.
Wave redirects any water that you would usually find with portable air conditioners to its heating tube. This allows all the water to evaporate keeping your space perfectly dry.
Easy controls
Satisfyingly simple.
Wave has intuitive dial controls to pump up the cooling or alter runtimes. With a press of the mode button, you can switch between the two dial options.
At a distance?
The EcoFlow app allows you to completely customize how you use your Wave. Prioritize extended 8hr runtimes, or bursts of maximum cooling.
EcoFlow MH200
You might also like
View more
  • EcoFlow
