Eskom Gauteng Load Reduction: Current Schedules and How to Prepare
Power cuts can still affect parts of Gauteng even when South Africa avoids national loadshedding. Eskom uses load reduction in selected high-demand areas, usually during the morning and evening peaks, to protect overloaded local networks. If your suburb appears on an Eskom Gauteng load reduction schedule, you may need to plan around several hours without electricity. This guide explains why it happens, where to check official schedules, and how to prepare your home.
Current Eskom Gauteng Load Reduction Status and Schedule
By 8 July 2026, Eskom had removed five provinces and more than 1.1 million customers from load reduction schedules. Gauteng still has the highest concentration of areas that continue to face load reduction.
Eskom groups affected Gauteng communities into Blocks A to J. When Eskom schedules your block, you may lose power during one of the usual peak periods:
Morning Peak Window: 05:00 – 09:00
Evening Peak Window: 17:00 – 22:00
The table below summarises the current Eskom load reduction Gauteng schedule from 20 to 31 July 2026:
Date | Morning Peak: 05:00–09:00 | Evening Peak: 17:00–22:00 |
20 July | Block I | Block H |
21 July | Block J | Blocks G and F |
22 July | Block A | Block B |
23 July | Block C | Block D |
24 July | Block F | Blocks I and J |
25 July | Block H | Block G |
26 July | Block J | Blocks I and E |
27 July | Block D | Block C |
28 July | Block A | Blocks B and J |
29 July | Block C | Block D |
30 July | Block G | Block H |
31 July | Block E | Block F |
*Eskom may adjust load reduction arrangements when local network conditions change. Confirm your block and any later updates on the official Eskom Load Reduction page before planning work, cooking or other electricity-dependent tasks.
Which Gauteng Areas Commonly Appear on Load Reduction Schedules?
Eskom changes its block allocations as local network conditions improve or new problems emerge, so the suburb list does not stay exactly the same every month. Even so, several parts of Gauteng continue to appear across current and earlier load reduction schedules, particularly communities around Soweto, Ekurhuleni, Tshwane, the Vaal and the West Rand.
The table below brings together the main areas that regularly feature in Eskom notices and the latest Gauteng schedule:
Part of Gauteng | Suburbs and Townships Commonly Listed |
Soweto | Meadowlands, Dube, Mofolo, Moletsane, Zola, Jabulani, Dobsonville, Mapetla and Chiawelo |
Northern and Western Johannesburg | Cosmo City, Zandspruit, Diepsloot West, Rabie Ridge, Ivory Park and Kaalfontein |
Ekurhuleni | Etwatwa, Wattville, Tsakane, Katlehong South, Vosloorus, Zonkezizwe and surrounding communities |
City of Tshwane | Mabopane, Winterveldt, Ga-Rankuwa, Mathibestad, Ekangala and nearby areas |
The Vaal and Southern Gauteng | Evaton, Sebokeng, Sharpeville, Orange Farm, Stretford and Tshepiso |
West Rand | Kagiso, Westonaria, Bekkersdal, Khutsong and Rietvallei |
*Eskom may move a suburb to another block, limit an outage to certain extensions, or remove a feeder from load reduction after network upgrades. Confirm your exact suburb, extension or unit on the official Eskom Load Reduction page.
Why Gauteng Still Faces Load Reduction?
With national loadshedding still suspended, Gauteng’s local power cuts can seem puzzling. The problem lies in overloaded distribution networks, where some feeders, transformers and mini-substations cannot safely carry community demand.
Overloaded Local Networks
Load shedding and load reduction both interrupt the electricity supply, but the difference between load shedding and load reduction lies in the part of the power system under pressure. Improvements in national generation do not automatically remove pressure from local infrastructure:
Loadshedding | Load Reduction | |
Main problem | National electricity supply cannot meet total demand | A local network carries more demand than its equipment can safely handle |
Areas affected | Broader areas under national stages | Selected feeders, blocks and communities |
Purpose | Keeps the national grid balanced | Protects local transformers, mini-substations and feeders |
Some Gauteng communities have grown faster than their local electricity networks. Where household demand exceeds the capacity of a feeder or transformer, Eskom may temporarily cut supply to reduce the risk of equipment damage and a longer unplanned outage.
Winter Peak Demand
Cold mornings and evenings place extra pressure on Gauteng’s local networks as heaters, geysers, kettles, and electric stoves run simultaneously. These peak electricity times can push already strained equipment beyond its safe operating limit, which is why load reduction usually takes place during the morning and evening peaks.
The pressure can become more severe in densely populated or fast-growing communities where the local network now serves more households and appliances than it originally accommodated.
Illegal Connections and Meter Tampering
Illegal connections, electricity theft and bypassed meters add demand that Eskom cannot accurately measure or manage. A transformer may therefore carry substantially more electricity than its recorded customer load suggests, increasing the risk of overheating, equipment failure and extended local outages.
Load reduction gives this equipment temporary relief while Eskom installs smart meters, strengthens distribution infrastructure and addresses unsafe connections. These issues remain central to the areas that continue to experience load reduction in Gauteng.
How to Prepare for Eskom Gauteng Load Reduction
Once you know when your block may lose power, plan around the outage window rather than waiting for the electricity to go off. Complete power-heavy tasks early, prepare household essentials and decide which devices must remain powered.
Check the Schedule and Plan Ahead
Confirm the date and block on the official Eskom schedule, then check again on the day of the scheduled cut in case local arrangements change. Before the outage:
Cook meals and boil any water you will need.
Run the washing machine and other power-heavy appliances.
Charge phones, laptops, power banks and rechargeable lights.
Complete online meetings, downloads and other time-sensitive work.
Adjust your geyser timer so it finishes heating outside the scheduled slot.
Switch off sensitive electronics before the cut and reconnect them once the supply has stabilised.
Keep Essential Devices Powered
Not every part of your outage plan requires backup power. A few practical steps can reduce the number of appliances and devices you need to support:
Keep fridge and freezer doors closed to retain cold air.
Place rechargeable lights, drinking water and essential medication within easy reach.
Check the backup batteries in alarms, electric fences and gate motors.
Make sure someone at home knows how to open the gate or garage manually.
Next, identify the devices that genuinely need continuous power during the scheduled window. Common priorities include:
Wi-Fi routers, phones and laptops for communication and remote work where internet service remains available.
Refrigeration for temperature-sensitive food or medication.
Alarm systems, electric fences and gate motors.
Essential medical equipment and indoor lighting.
A compact backup setup may cover a router, phones, a laptop and a few lights. Once you add refrigeration, security equipment or selected kitchen appliances, the required capacity and output increase. A portable power station can then provide a practical way to keep essential devices running during load reduction and maintain basic power for daily needs.
For households requiring scalable storage and better control over essential loads, the EcoFlow DELTA 3 Ultra Plus Power Station offers expandable capacity, high output, and exceptional surge power. Its app-based output priority control allows you to direct electricity to critical appliances first, while its rapid auto-switching capability helps compatible devices remain online during the changeover.
If your home has higher overall energy demands, the EcoFlow DELTA Pro 3 Portable Power Station delivers massive capacity to support multiple heavy appliances at once. It recharges its battery incredibly fast under standard mains conditions, while high solar input capabilities provide an independent recharge method during consecutive or extended outages.
Prepare for Power to Return
When electricity returns, avoid switching every appliance back on immediately. Reconnect devices gradually and check that essential systems have restarted correctly.
Turn on larger appliances one at a time.
Check your router, alarm, electric fence and gate motor.
Confirm that the fridge, freezer and geyser timer are running normally.
Reset any clocks or appliance schedules affected by the outage.
If power does not return after the scheduled slot, check whether nearby homes are also affected and report the fault to your electricity supplier.
Eskom Gauteng load reduction can still disrupt daily routines in parts of Gauteng, even while national loadshedding remains suspended. Checking your block, completing power-heavy tasks early and keeping essential devices running will make each scheduled outage easier to manage.
What if my power stays off after the scheduled slot in Gauteng?
Check whether nearby homes also remain without electricity, then report the outage to your electricity supplier. Eskom customers can use the MyEskom Customer App, contact Alfred on WhatsApp at 08600 37566 or call the same customer service number. If City Power or another municipality supplies your property, log the fault through that distributor instead. Keep the reference number so you can track the repair.
Why can transformer replacement take so long in Gauteng?
Eskom or the municipality may need to inspect the damage, remove illegal connections and address meter tampering before replacing the transformer. Restricted access, safety conditions and equipment availability can also delay restoration.
Can I Claim From Eskom for Surge-Damaged Appliances in Gauteng?
If Eskom supplies your property, you can submit a Supply Related Claim through Eskom CS Online, but compensation is not guaranteed. Keep the outage reference number and supporting evidence such as photos, proof of ownership, repair reports and replacement quotations. If City Power or the City of Tshwane supplies your home, use the relevant municipality’s claims process instead.
